07-05-2018, 06:27 PM
Using SD Formatter have you set Size Adjustment to On
If you've messed up your eMMC Card - Solved
07-11-2018, 02:08 PM
Having decided that I quite like Armbian, in my attempts to find a good desktop OS, I also decided to put it on my eMMC card, which took me straight back to the problem I had before. The eMMC card appears as a 32mb card to both Xubuntu and Win10.
I tried both SD Formatter and DISKPART, but neither would register a card above 32mb neither would they format it or ‘clean’ it. Gparted would neither delete this 32mb partition nor create a new partition table, so I was stumped. Once again I flashed Aufan’s image to an SD Card and using the pin shortening method, booted into bionic-lxde, with the eMMC installed onto the Rock64 board. It seems that the pin shorting method will only work on a newly flashed image. Gparted saw all the partitions on the eMMC so I deleted them, and created a new 64GB ext4 partition. Back to Xubuntu and Win10 for flashing Armbian onto the eMMC. Neither OS would see anything other than a 32mb partiton, despite all that I had just carried out. I tried to go back and use the Code: /usr/local/bin/rock64_reset_emmc.shemmc reset trick, but suddenly I could no longer boot into the SD Card with the eMMC installed, no matter what distro I used. The two pin shorting out trick no longer worked, for some reason. I tried deleting the SP1 flash, but this made no difference either. If I could have gone to a local shop to buy an eMMC card, I would have done so. If anyone else ends up in this predicament, I don’t know what they should do. I was in the good position of owning an Odroid XU4 so using the eMMC recovery utility, Odroid eMMC recovery I installed Odroid Android. After doing this and running it on the Odroid, I was able to use Etcher and load Armbian onto my eMMC Card. It is booting and running fine. All this took me most of the day. Surely there is a better way. isn’t there, to recover an eMMC Card? The Rock 64 4GB has so much promise as a desktop computer, but maybe it is just early days, or is it just me that struggles?
PinePhone Beta 2GB/16GB Arch Linux ARM danctnix from3 Oct 2025
(was Postmarket OS v24.12) PineTab2 Arch Danctnix 6.4.2 |
| problem with debian emmc boot | G4zCDzWb | 10 | 31,327 |
11-01-2024, 04:32 PM Last Post: bits |
| Debian installation via sd card | oaFJSADBKV | 0 | 2,787 |
10-12-2024, 10:24 AM Last Post: oaFJSADBKV |
| Buildroot 2021.08 not booting from SD card | jimmy | 1 | 5,136 |
11-08-2021, 02:25 AM Last Post: hunderteins |
| Debian (Vanilla) on Rock64 and eMMC - how ? | as365n4 | 4 | 10,116 |
09-21-2020, 04:33 AM Last Post: as365n4 |
| Display limited to 800x600 [SOLVED] | Averell | 16 | 32,627 |
06-05-2020, 11:07 PM Last Post: ab1jx |
| Nextcloudpi SD card fills up. | default_user8 | 13 | 29,397 |
12-04-2019, 01:30 PM Last Post: Rocklobster |
[SOLVED] Alpine Linux won't boot | rock7 | 1 | 11,655 |
10-22-2019, 04:30 PM Last Post: rock7 |
| Clone the SD to eMMC | tagyro | 1 | 5,629 |
02-06-2019, 06:55 AM Last Post: evilbunny |
| Repair corrupt root filesystem on emmc | David82 | 1 | 6,563 |
01-31-2019, 01:11 PM Last Post: Tozzi |
| Migrate Linux from microSD to onboard eMMC | elik745i | 7 | 16,895 |
11-03-2018, 08:23 AM Last Post: mara |
