06-05-2018, 09:11 AM
		I'm a little surprised it doesn't actually.  I've got half a dozen of them, in a Pi they just work.  Garden variety USB wifi adapter, comes in big or small depending on the antenna size, $4-15 on eBay.
ifquery --list shows only lo
lsmod shows:
dmesg | grep rtl shows:
A cell phone is my only internet connection, through the wifi hotspot. So I can't just apt-get anything yet. I can mount the SD in a reader on a Pi and get things on and off that way. The firmware seems to be there.
I have an interfaces file that generally works fine under Debian consisting of
that didn't work, the stock one didn't work.
lsmod shows:
Module                  Size  Used by
rtl8xxxu               73728  0
rtl8192cu              94208  0
rtl_usb                24576  1 rtl8192cu
rtl8192c_common        65536  1 rtl8192cu
rtlwifi                98304  3 rtl_usb,rtl8192c_common,rtl8192cu
usblp                  20480  0
ip_tables              24576  0
x_tables               32768  1 ip_tables
autofs4                40960  0
uas                    20480  0
usb_storage            61440  1 uasdmesg | grep rtl shows:
[    7.043104] rtl8192cu: Chip version 0x10
[    7.137326] rtl8192cu: MAC address: 48:02:2a:9d:4d:57
[    7.137346] rtl8192cu: Board Type 0
[    7.137584] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[    7.137706] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[    7.138374] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[    7.139636] usbcore: registered new interface driver rtl8192cu
[    7.150127] usbcore: registered new interface driver rtl8xxxu
[    7.162122] rtl8192cu 1-1:1.0 wlx48022a9d4d57: renamed from wlan0
[    8.852083] rtl8192cu: MAC auto ON okay!
[    8.880483] rtl8192cu: Tx queue select: 0x05
[    9.458969] rtl8192cu: MAC auto ON okay!
[    9.488545] rtl8192cu: Tx queue select: 0x05
[  352.137643] rtl8192cu: MAC auto ON okay!
[  352.188560] rtl8192cu: Tx queue select: 0x05
[  668.148896] rtl8192cu: MAC auto ON okay!
[  668.203780] rtl8192cu: Tx queue select: 0x05
[  889.037179] rtl_usb: reg 0x102, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x90e1317
[  889.037224] rtl_usb: reg 0x422, usbctrl_vendorreq TimeOut! status:0xffffffed value=0xf000690e
[  889.037267] rtl_usb: reg 0x542, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x324072c
[  889.037439] rtl_usb: reg 0x102, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x1a0335
[ 1186.287879] rtl8192cu: Chip version 0x10
[ 1186.395365] rtl8192cu: MAC address: 48:02:2a:9d:4d:57
[ 1186.395406] rtl8192cu: Board Type 0
[ 1186.395544] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 1186.395620] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 1186.396401] ieee80211 phy1: Selected rate control algorithm 'rtl_rc'
[ 1186.425928] rtl8192cu 1-1:1.0 wlx48022a9d4d57: renamed from wlan0
[ 1186.461059] rtl8192cu: MAC auto ON okay!
[ 1186.492930] rtl8192cu: Tx queue select: 0x05
[ 1187.071627] rtl8192cu: MAC auto ON okay!
[ 1187.101405] rtl8192cu: Tx queue select: 0x05
[ 1530.115320] rtl8192cu: MAC auto ON okay!
[ 1530.158109] rtl8192cu: Tx queue select: 0x05
[ 1846.131275] rtl8192cu: MAC auto ON okay!
[ 1846.187095] rtl8192cu: Tx queue select: 0x05A cell phone is my only internet connection, through the wifi hotspot. So I can't just apt-get anything yet. I can mount the SD in a reader on a Pi and get things on and off that way. The firmware seems to be there.
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet dhcp
  wireless-essid Moto_lte
