External hard drive problem
I followed these steps: https://forum.pine64.org/showthread.php?...7#pid32107
I added "options usb-storage quirks=0x174c:0x55aa:u" to /etc/modprobe.d/rk3328-usb-storage-quirks.conf. But it is still doesnt work without turning on and off the hard drive on USB 3.0.
Connecting the ExternalHD to the USB2.0 port works immediately.
I'm on: jessie-openmediavault-rock64-0.6.30-208-armhf.img
root@rock64:~# dmesg -wH [Apr 4 11:48] Booting Linux on physical CPU 0x0 [  +0.000000] Initializing cgroup subsys cpuset [  +0.000000] Initializing cgroup subsys cpu [  +0.000000] Initializing cgroup subsys cpuacct [  +0.000000] Linux version 4.4.120-rockchip-ayufan-208 (root@612d9be805e8) (gcc version 7.2.0 (Ubuntu/Linaro 7.2.0-6ubuntu1) ) #1 SMP Sun Apr 1 18:26:21 UTC 2018 [  +0.000000] Boot CPU: AArch64 Processor [410fd034] [  +0.000000] On node 0 totalpages: 523776 [  +0.000000]   DMA zone: 8184 pages used for memmap [  +0.000000]   DMA zone: 0 pages reserved [  +0.000000]   DMA zone: 523776 pages, LIFO batch:31 [  +0.000000] psci: probing for conduit method from DT. [  +0.000000] psci: PSCIv1.0 detected in firmware. [  +0.000000] psci: Using standard PSCI v0.2 function IDs [  +0.000000] psci: MIGRATE_INFO_TYPE not supported. [  +0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07ff3c000 s46248 r8192 d31576 u86016 [  +0.000000] pcpu-alloc: s46248 r8192 d31576 u86016 alloc=21*4096 [  +0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [  +0.000000] Detected VIPT I-cache on CPU0 [  +0.000000] CPU features: enabling workaround for ARM erratum 845719 [  +0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 515592 [  +0.000000] Kernel command line: earlyprintk=uart8250-32bit,0xff130000 rw root=LABEL=linux-root rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=1e:c5:ec:5c:8f:fa eth1addr=1e:c5:ec:5c:8f:1a serial=87d9cb75058e39e cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [  +0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [  +0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [  +0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [  +0.000000] software IO TLB [mem 0x79400000-0x7d400000] (64MB) mapped at [ffffffc079400000-ffffffc07d3fffff] [  +0.000000] Memory: 1967804K/2095104K available (11838K kernel code, 1574K rwdata, 4328K rodata, 1152K init, 752K bss, 127300K reserved, 0K cma-reserved) [  +0.000000] Virtual kernel memory layout:                  modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)                  vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)                    .init : 0xffffff8009050000 - 0xffffff8009170000   (  1152 KB)                    .text : 0xffffff8008080000 - 0xffffff8008c10000   ( 11840 KB)                  .rodata : 0xffffff8008c10000 - 0xffffff8009050000   (  4352 KB)                    .data : 0xffffff8009170000 - 0xffffff80092f9808   (  1575 KB)                  vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)                            0xffffffbdc0008000 - 0xffffffbdc2000000   (    31 MB actual)                  fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)                  PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)                  memory  : 0xffffffc000200000 - 0xffffffc080000000   (  2046 MB) [  +0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [  +0.000000] Hierarchical RCU implementation. [  +0.000000]   Build-time adjustment of leaf fanout to 64. [  +0.000000]   RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [  +0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4 [  +0.000000] NR_IRQS:64 nr_irqs:64 0 [  +0.000000] GIC: Using split EOI/Deactivate mode [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] rockchip_mmc_get_phase: invalid clk rate [  +0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [  +0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [  +0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [  +0.001115] Console: colour dummy device 80x25 [  +0.001983] console [tty0] enabled [  +0.000058] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [  +0.000084] pid_max: default: 32768 minimum: 301 [  +0.000195] Security Framework initialized [  +0.000046] Yama: becoming mindful. [  +0.000066] AppArmor: AppArmor disabled by boot time parameter [  +0.000102] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [  +0.000050] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [  +0.001004] Initializing cgroup subsys io [  +0.000062] Initializing cgroup subsys memory [  +0.000074] Initializing cgroup subsys devices [  +0.000053] Initializing cgroup subsys freezer [  +0.000052] Initializing cgroup subsys net_cls [  +0.000049] Initializing cgroup subsys perf_event [  +0.000052] Initializing cgroup subsys net_prio [  +0.000057] Initializing cgroup subsys hugetlb [  +0.000049] Initializing cgroup subsys pids [  +0.000089] ftrace: allocating 44508 entries in 174 pages [  +0.128638] sched-energy: CPU device node has no sched-energy-costs [  +0.000070] Invalid sched_group_energy for CPU0 [  +0.000041] CPU0: update cpu_capacity 1024 [  +0.000111] ASID allocator initialised with 32768 entries [  +0.006258] Detected VIPT I-cache on CPU1 [  +0.000074] Invalid sched_group_energy for CPU1 [  +0.000007] CPU1: update cpu_capacity 1024 [  +0.000005] CPU1: Booted secondary processor [410fd034] [  +0.000779] Detected VIPT I-cache on CPU2 [  +0.000053] Invalid sched_group_energy for CPU2 [  +0.000007] CPU2: update cpu_capacity 1024 [  +0.000004] CPU2: Booted secondary processor [410fd034] [  +0.000746] Detected VIPT I-cache on CPU3 [  +0.000052] Invalid sched_group_energy for CPU3 [  +0.000005] CPU3: update cpu_capacity 1024 [  +0.000005] CPU3: Booted secondary processor [410fd034] [  +0.000115] Brought up 4 CPUs [  +0.000462] SMP: Total of 4 processors activated. [  +0.000050] CPU: All CPU(s) started at EL2 [  +0.000077] alternatives: patching kernel code [  +0.000324] Invalid sched_group_energy for CPU3 [  +0.000048] Invalid sched_group_energy for Cluster3 [  +0.000040] Invalid sched_group_energy for CPU2 [  +0.000040] Invalid sched_group_energy for Cluster2 [  +0.000041] Invalid sched_group_energy for CPU1 [  +0.000041] Invalid sched_group_energy for Cluster1 [  +0.000041] Invalid sched_group_energy for CPU0 [  +0.000040] Invalid sched_group_energy for Cluster0 [  +0.001014] devtmpfs: initialized [  +0.022222] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [  +0.000115] futex hash table entries: 1024 (order: 4, 65536 bytes) [  +0.000712] xor: measuring software checksum speed [  +0.010024]    8regs     :  1080.000 MB/sec [  +0.010083]    8regs_prefetch:   968.000 MB/sec [  +0.010083]    32regs    :  1456.000 MB/sec [  +0.010085]    32regs_prefetch:  1224.000 MB/sec [  +0.000043] xor: using function: 32regs (1456.000 MB/sec) [  +0.000073] pinctrl core: initialized pinctrl subsystem [  +0.000482] regulator-dummy: no parameters [  +0.001100] NET: Registered protocol family 16 [  +0.004551] cpuidle: using governor ladder [  +0.004028] cpuidle: using governor menu [  +0.000062] Registered FIQ tty driver [  +0.000766] vdso: 2 pages (1 code @ ffffff8008c16000, 1 data @ ffffff8009174000) [  +0.000104] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [  +0.000732] DMA: preallocated 1024 KiB pool for atomic allocations [  +0.019041] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 [  +0.000153] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 [  +0.000133] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 [  +0.000146] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 [  +0.051286] raid6: int64x1  gen()   191 MB/s [  +0.017014] raid6: int64x1  xor()   142 MB/s [  +0.017175] raid6: int64x2  gen()   316 MB/s [  +0.017115] raid6: int64x2  xor()   242 MB/s [  +0.017168] raid6: int64x4  gen()   472 MB/s [  +0.017106] raid6: int64x4  xor()   312 MB/s [  +0.017205] raid6: int64x8  gen()   386 MB/s [  +0.017213] raid6: int64x8  xor()   304 MB/s [  +0.017211] raid6: neonx1   gen()   351 MB/s [  +0.017105] raid6: neonx1   xor()   316 MB/s [  +0.017241] raid6: neonx2   gen()   539 MB/s [  +0.017123] raid6: neonx2   xor()   445 MB/s [  +0.017155] raid6: neonx4   gen()   742 MB/s [  +0.017166] raid6: neonx4   xor()   556 MB/s [  +0.017208] raid6: neonx8   gen()   761 MB/s [  +0.017153] raid6: neonx8   xor()   566 MB/s [  +0.000044] raid6: using algorithm neonx8 gen() 761 MB/s [  +0.000040] raid6: .... xor() 566 MB/s, rmw enabled [  +0.000041] raid6: using intx1 recovery algorithm [  +0.000593] mpp venc_srv: mpp_probe enter [  +0.000072] mpp venc_srv: init success [  +0.000428] rockchip-pm rockchip-suspend: not set sleep mode config [  +0.000049] rockchip-pm rockchip-suspend: not set wakeup-config [  +0.000047] rockchip-pm rockchip-suspend: not set pwm-regulator-config [  +0.001086] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' [  +0.000052] vcc_phy: no parameters [  +0.000327] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV [  +0.000095] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-sys[0]' [  +0.000030] vcc_sys: 5000 mV [  +0.000348] reg-fixed-voltage vcc-sys: vcc_sys supplying 5000000uV [  +0.000388] of_get_named_gpiod_flags: parsed 'gpio' property of node '/sdmmc-regulator[0]' - status (0) [  +0.000081] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000024] vcc_sd: unable to resolve supply [  +0.000014] vcc_sd: 3300 mV [  +0.000254] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000024] vcc_sd: regulator get failed, ret=-517 [  +0.000094] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000022] vcc_sd: unable to resolve supply [  +0.000017] reg-fixed-voltage sdmmc-regulator: vcc_sd supplying 3300000uV [  +0.000299] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-5v-regulator[0]' - status (0) [  +0.000068] reg-fixed-voltage vcc-host-5v-regulator: Looking up vin-supply from device tree [  +0.000062] vcc_host_5v: supplied by vcc_sys [  +0.000052] vcc_sys: could not add device link regulator.4 err -2 [  +0.000084] vcc_host_5v: at 5000 mV [  +0.000331] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000027] vcc_sd: unable to resolve supply [  +0.000018] reg-fixed-voltage vcc-host-5v-regulator: vcc_host_5v supplying 0uV [  +0.000333] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host1-5v-regulator[0]' - status (0) [  +0.000069] reg-fixed-voltage vcc-host1-5v-regulator: Looking up vin-supply from device tree [  +0.000058] vcc_host1_5v: supplied by vcc_sys [  +0.000054] vcc_sys: could not add device link regulator.5 err -2 [  +0.000072] vcc_host1_5v: at 5000 mV [  +0.000301] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000027] vcc_sd: unable to resolve supply [  +0.000018] reg-fixed-voltage vcc-host1-5v-regulator: vcc_host1_5v supplying 0uV [  +0.000983] iommu: Adding device ff350000.vpu_service to group 0 [  +0.000149] iommu: Adding device ff351000.avsd to group 1 [  +0.000174] iommu: Adding device ff360000.rkvdec to group 2 [  +0.000129] iommu: Adding device ff330000.h265e to group 3 [  +0.000124] iommu: Adding device ff340000.vepu to group 4 [  +0.000136] iommu: Adding device ff370000.vop to group 5 [  +0.000139] iommu: Adding device ff3a0000.iep to group 6 [  +0.001249] rk_iommu ff360480.iommu: can't get aclk [  +0.000063] rk_iommu ff360480.iommu: can't get hclk [  +0.001966] SCSI subsystem initialized [  +0.000416] usbcore: registered new interface driver usbfs [  +0.000122] usbcore: registered new interface driver hub [  +0.000189] usbcore: registered new device driver usb [  +0.000202] media: Linux media interface: v0.10 [  +0.000098] Linux video capture interface: v2.00 [  +0.000164] pps_core: LinuxPPS API ver. 1 registered [  +0.000068] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [  +0.000103] PTP clock support registered [  +0.002080] Advanced Linux Sound Architecture Driver Initialized. [  +0.001040] Bluetooth: Core ver 2.21 [  +0.000102] NET: Registered protocol family 31 [  +0.000041] Bluetooth: HCI device and connection manager initialized [  +0.000055] Bluetooth: HCI socket layer initialized [  +0.000048] Bluetooth: L2CAP socket layer initialized [  +0.000082] Bluetooth: SCO socket layer initialized [  +0.000832] NetLabel: Initializing [  +0.000045] NetLabel:  domain hash size = 128 [  +0.000039] NetLabel:  protocols = UNLABELED CIPSOv4 [  +0.000109] NetLabel:  unlabeled traffic allowed by default [  +0.000682] rockchip-cpuinfo cpuinfo: Serial          : 87d9cb75058e39e1 [  +0.001340] clocksource: Switched to clocksource arch_sys_counter [  +0.106827] NET: Registered protocol family 2 [  +0.000960] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [  +0.000373] TCP bind hash table entries: 16384 (order: 7, 524288 bytes) [  +0.000758] TCP: Hash tables configured (established 16384 bind 16384) [  +0.000290] UDP hash table entries: 1024 (order: 4, 98304 bytes) [  +0.000193] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes) [  +0.000553] NET: Registered protocol family 1 [  +0.000723] RPC: Registered named UNIX socket transport module. [  +0.000054] RPC: Registered udp transport module. [  +0.000039] RPC: Registered tcp transport module. [  +0.000041] RPC: Registered tcp NFSv4.1 backchannel transport module. [  +0.000068] PCI: CLS 0 bytes, default 64 [  +0.000378] Trying to unpack rootfs image as initramfs... [  +0.380299] Freeing initrd memory: 4928K [  +0.001303] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [  +0.001697] kvm [1]: 8-bit VMID [  +0.000045] kvm [1]: Hyp mode initialized successfully [  +0.000581] kvm [1]: interrupt-controller@ff814000 IRQ46 [  +0.000426] kvm [1]: timer IRQ3 [  +0.004303] audit: initializing netlink subsys (disabled) [  +0.000143] audit: type=2000 audit(0.990:1): initialized [  +0.001386] HugeTLB registered 2 MB page size, pre-allocated 0 pages [  +0.013523] VFS: Disk quotas dquot_6.6.0 [  +0.000354] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [  +0.003203] squashfs: version 4.0 (2009/01/31) Phillip Lougher [  +0.002364] NFS: Registering the id_resolver key type [  +0.000137] Key type id_resolver registered [  +0.000042] Key type id_legacy registered [  +0.000067] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [  +0.001247] fuse init (API version 7.23) [  +0.001412] JFS: nTxBlock = 8192, nTxLock = 65536 [  +0.010138] SGI XFS with ACLs, security attributes, realtime, no debug enabled [  +0.003189] Key type big_key registered [  +0.000166]              TEE Core Framework initialization (ver 1:0.1) [  +0.000109] TEE armv7 Driver initialization [  +0.000666] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [  +0.000052] TEE core: Alloc the misc device "opteearmtz00" (id=0) [  +0.000420] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62) [  +0.005823] NET: Registered protocol family 38 [  +0.000116] Key type asymmetric registered [  +0.000052] Asymmetric key parser 'x509' registered [  +0.000425] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [  +0.000346] io scheduler noop registered [  +0.000056] io scheduler deadline registered (default) [  +0.000117] io scheduler cfq registered [  +0.001889] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree [  +0.000172] vcc_host1_5v: could not add device link phy-ff450000.syscon:usb2-phy@100.0 err -2 [  +0.000662] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree [  +0.000167] vcc_host1_5v: could not add device link phy-ff450000.syscon:usb2-phy@100.1 err -2 [  +0.000542] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up vbus-supply from device tree [  +0.000023] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up vbus-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed [  +0.000027] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator [  +0.001149] rockchip-u3phy ff470000.usb3-phy: Looking up vbus-supply from device tree [  +0.000026] rockchip-u3phy ff470000.usb3-phy: Looking up vbus-supply property in node /usb3-phy@ff470000 failed [  +0.000028] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator [  +0.000565] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree [  +0.000020] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed [  +0.000495] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree [  +0.000021] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed [  +0.001804] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully [  +0.000807] phy phy-ff430000.hdmiphy.4: Looking up phy-supply from device tree [  +0.000021] phy phy-ff430000.hdmiphy.4: Looking up phy-supply property in node /hdmiphy@ff430000 failed [  +0.003268] rk-vcodec vpu_combo: Looking up vcodec-supply from device tree [  +0.000025] rk-vcodec vpu_combo: Looking up vcodec-supply property in node /vpu_combo failed [  +0.000024] rk-vcodec vpu_combo: no regulator for vcodec [  +0.000396] rk-vcodec vpu_combo: failed on clk_get clk_cabac [  +0.000060] rk-vcodec vpu_combo: failed on clk_get clk_core [  +0.000136] platform ff350000.vpu_service: probe device [  +0.000108] platform ff350000.vpu_service: vpu mmu dec ffffffc078834810 [  +0.000463] platform ff350000.vpu_service: allocator is drm [  +0.000138] platform ff350000.vpu_service: checking hw id 0 [  +0.001095] platform ff351000.avsd: probe device [  +0.000176] platform ff351000.avsd: vpu mmu dec ffffffc078834810 [  +0.000455] platform ff351000.avsd: allocator is drm [  +0.000098] platform ff351000.avsd: checking hw id 6731 [  +0.002339] rk-vcodec vpu_combo: could not find power_model node [  +0.000061] rk-vcodec vpu_combo: init success [  +0.000496] rk-vcodec ff360000.rkvdec: Looking up vcodec-supply from device tree [  +0.000038] rk-vcodec ff360000.rkvdec: vcodec regulator not ready, retry [  +0.001110] probe device ff330000.h265e [  +0.000467] mpp_dev ff330000.h265e: try to get iommu dev ffffffc078836410 [  +0.000613] mpp_dev ff330000.h265e: resource ready, register device [  +0.000662] probe device ff340000.vepu [  +0.000454] mpp_dev ff340000.vepu: try to get iommu dev ffffffc078836c10 [  +0.000512] mpp_dev ff340000.vepu: resource ready, register device [  +0.003600] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330 [  +0.000066] dma-pl330 ff1f0000.dmac:  DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [  +0.001321] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled [  +0.003192] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 13, base_baud = 1500000) is a 16550A [  +0.118813] console [ttyS2] enabled [  +0.002191] [drm] Initialized drm 1.1.0 20060810 [  +0.004426] [drm] Rockchip DRM driver version: v1.0.0 [  +0.000823] rockchip-drm display-subsystem: devfreq is not set [  +0.001096] rockchip-vop ff370000.vop: invalid resource [  +0.000532] rockchip-vop ff370000.vop: failed to get vop lut registers [  +0.000614] rockchip-vop ff370000.vop: invalid resource [  +0.000514] rockchip-vop ff370000.vop: failed to get vop cabc lut registers [  +0.001000] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008cdc448) [  +0.001240] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports [  +0.000659] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver [  +0.000905] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2) [  +0.002278] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008cd3310) [  +0.000821] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [  +0.000619] [drm] No driver support for vblank timestamp query. [  +0.000687] rockchip-drm display-subsystem: failed to parse display resources [  +0.227641] rockchip-vop ff370000.vop: [drm:vop_crtc_enable] Update mode to 1920*1080 [  +0.088289] Console: switching to colour frame buffer device 240x67 [  +0.068350] rockchip-drm display-subsystem: fb0:  frame buffer device [  +0.007665] usbcore: registered new interface driver udl [  +0.004030] Unable to detect cache hierarchy for CPU 0 [  +0.002734] brd: module loaded [  +0.012158] loop: module loaded [  +0.001031] lkdtm: No crash points registered, enable through debugfs [  +0.003398] rockchip-spi ff190000.spi: no high_speed pinctrl state [  +0.002123] m25p80 spi32766.0: gd25q128 (16384 Kbytes) [  +0.000781] 2 ofpart partitions found on MTD device spi32766.0 [  +0.000785] Creating 2 MTD partitions on "spi32766.0": [  +0.000698] 0x000000008000-0x000000400000 : "loader" [  +0.002691] 0x0000007c0000-0x000000800000 : "vendor" [  +0.005660] force_sf_dma_mode is ignored if force_thresh_dma_mode is set. [  +0.000986] rk_gmac-dwmac ff540000.ethernet: Looking up phy-supply from device tree [  +0.000223] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input). [  +0.000953] rk_gmac-dwmac ff540000.ethernet: TX delay(0x24). [  +0.000764] rk_gmac-dwmac ff540000.ethernet: RX delay(0x18). [  +0.000776] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no). [  +0.001063] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed [  +0.000924] rk_gmac-dwmac ff540000.ethernet: clock input from PHY [  +0.005829] rk_gmac-dwmac ff540000.ethernet: init for RGMII [  +0.000925] stmmac - user ID: 0x10, Synopsys ID: 0x35 [  +0.000676]  Ring mode enabled [  +0.000422]  DMA HW capability register supported [  +0.000595]  Normal descriptors [  +0.000470]  RX Checksum Offload Engine supported (type 2) [  +0.000707]  Wake-Up On Lan supported [  +0.000571]  Enable RX Mitigation via HW Watchdog Timer [  +0.000949] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@ff540000[0]' - status (0) [  +0.075262] libphy: stmmac: probed [  +0.000529] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [  +0.000840] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01) [  +0.002838] Rockchip WiFi SYS interface (V1.00) ... [  +0.000912] usbcore: registered new interface driver cdc_ether [  +0.000860] usbcore: registered new interface driver rndis_host [  +0.003523] phy phy-ff470000.usb3-phy.2: u3phy u2 power on [  +0.000801] phy phy-ff470000.usb3-phy.3: u3phy u3 power on [  +0.002239] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree [  +0.000029] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed [  +0.000028] ff580000.usb supply vusb_d not found, using dummy regulator [  +0.000993] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree [  +0.000019] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed [  +0.000018] ff580000.usb supply vusb_a not found, using dummy regulator [  +0.013707] dwc2 ff580000.usb: DWC OTG Controller [  +0.000751] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1 [  +0.001015] dwc2 ff580000.usb: irq 43, io mem 0xff580000 [  +0.001067] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [  +0.012827] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [  +0.012691] usb usb1: Product: DWC OTG Controller [  +0.012306] usb usb1: Manufacturer: Linux 4.4.120-rockchip-ayufan-208 dwc2_hsotg [  +0.012588] usb usb1: SerialNumber: ff580000.usb [  +0.013577] hub 1-0:1.0: USB hub found [  +0.012531] hub 1-0:1.0: 1 port detected [  +0.014016] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [  +0.012803] ehci-pci: EHCI PCI platform driver [  +0.012497] ehci-platform: EHCI generic platform driver [  +0.015353] ehci-platform ff5c0000.usb: EHCI Host Controller [  +0.013151] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2 [  +0.013193] ehci-platform ff5c0000.usb: irq 44, io mem 0xff5c0000 [  +0.017746] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00 [  +0.012834] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [  +0.012538] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [  +0.012493] usb usb2: Product: EHCI Host Controller [  +0.012161] usb usb2: Manufacturer: Linux 4.4.120-rockchip-ayufan-208 ehci_hcd [  +0.012337] usb usb2: SerialNumber: ff5c0000.usb [  +0.013214] hub 2-0:1.0: USB hub found [  +0.011994] hub 2-0:1.0: 1 port detected [  +0.012636] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [  +0.012045] ohci-platform: OHCI generic platform driver [  +0.012564] ohci-platform ff5d0000.usb: Generic Platform OHCI controller [  +0.012519] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3 [  +0.012224] ohci-platform ff5d0000.usb: irq 45, io mem 0xff5d0000 [  +0.066683] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [  +0.011756] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [  +0.011659] usb usb3: Product: Generic Platform OHCI controller [  +0.011590] usb usb3: Manufacturer: Linux 4.4.120-rockchip-ayufan-208 ohci_hcd [  +0.011783] usb usb3: SerialNumber: ff5d0000.usb [  +0.012824] hub 3-0:1.0: USB hub found [  +0.011630] hub 3-0:1.0: 1 port detected [  +0.013182] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [  +0.012135] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4 [  +0.012118] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00210010 [  +0.012042] xhci-hcd xhci-hcd.9.auto: irq 181, io mem 0xff600000 [  +0.011904] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [  +0.011837] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [  +0.011829] usb usb4: Product: xHCI Host Controller [  +0.011535] usb usb4: Manufacturer: Linux 4.4.120-rockchip-ayufan-208 xhci-hcd [  +0.011849] usb usb4: SerialNumber: xhci-hcd.9.auto [  +0.012949] hub 4-0:1.0: USB hub found [  +0.011871] hub 4-0:1.0: 1 port detected [  +0.012389] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [  +0.012353] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5 [  +0.012503] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM. [  +0.012640] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003 [  +0.012345] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [  +0.012397] usb usb5: Product: xHCI Host Controller [  +0.012176] usb usb5: Manufacturer: Linux 4.4.120-rockchip-ayufan-208 xhci-hcd [  +0.012519] usb usb5: SerialNumber: xhci-hcd.9.auto [  +0.013549] hub 5-0:1.0: USB hub found [  +0.012389] hub 5-0:1.0: 1 port detected [  +0.015099] usbcore: registered new interface driver iforce [  +0.012637] usbcore: registered new interface driver xpad [  +0.012931] usbcore: registered new interface driver usbtouchscreen [  +0.013808] i2c /dev entries driver [  +0.015734] rk808 1-0018: Pmic Chip id: 0x8050 [  +0.013450] rk808 1-0018: source: on=0x40, off=0x00 [  +0.019031] rk808 1-0018: Looking up vcc1-supply from device tree [  +0.000236] DCDC_REG1: supplied by vcc_sys [  +0.012338] vcc_sys: could not add device link regulator.6 err -2 [  +0.002698] vdd_logic: 712 <--> 1450 mV at 1100 mV [  +0.000588] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000064] vcc_sd: unable to resolve supply [  +0.000041] rk808 1-0018: Looking up vcc2-supply from device tree [  +0.000199] DCDC_REG2: supplied by vcc_sys [  +0.012105] vcc_sys: could not add device link regulator.7 err -2 [  +0.002189] vdd_arm: 712 <--> 1450 mV at 1100 mV [  +0.000568] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000063] vcc_sd: unable to resolve supply [  +0.000041] rk808 1-0018: Looking up vcc3-supply from device tree [  +0.000250] DCDC_REG3: supplied by vcc_sys [  +0.012030] vcc_sys: could not add device link regulator.8 err -2 [  +0.001353] vcc_ddr: at 5000 mV [  +0.000556] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000057] vcc_sd: unable to resolve supply [  +0.000041] rk808 1-0018: Looking up vcc4-supply from device tree [  +0.000197] DCDC_REG4: supplied by vcc_sys [  +0.011883] vcc_sys: could not add device link regulator.9 err -2 [  +0.001367] vcc_io: 3300 mV [  +0.000549] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [  +0.000057] vcc_sd: supplied by vcc_io [  +0.012019] rk808 1-0018: Looking up vcc5-supply from device tree [  +0.000053] LDO_REG1: supplied by vcc_io [  +0.011736] vcc_io: could not add device link regulator.10 err -2 [  +0.002474] vdd_18: 1800 mV [  +0.001055] rk808 1-0018: Looking up vcc5-supply from device tree [  +0.000062] LDO_REG2: supplied by vcc_io [  +0.011585] vcc_io: could not add device link regulator.11 err -2 [  +0.002481] vcc18_emmc: 1800 mV [  +0.001056] rk808 1-0018: Looking up vcc6-supply from device tree [  +0.000238] LDO_REG3: supplied by vcc_sys [  +0.011551] vcc_sys: could not add device link regulator.12 err -2 [  +0.002486] vdd_10: 1000 mV [  +0.001096] rk808 1-0018: register rk8050 regulators [  +0.011948] gpiochip_find_base: found new base at 510 [  +0.000216] gpiochip_add_data: registered GPIOs 510 to 511 on device: rk8xx-gpio [  +0.000018] rk8xx-gpio rk8xx-gpio: register rk8050 gpio successful [  +0.014023] input: rk8xx_pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/input/input0 [  +0.022781] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [  +0.012977] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff800a334000 [  +0.014430] IR NEC protocol handler initialized [  +0.011872] IR RC5(x/sz) protocol handler initialized [  +0.011849] IR RC6 protocol handler initialized [  +0.011693] IR JVC protocol handler initialized [  +0.011669] IR Sony protocol handler initialized [  +0.011652] IR SANYO protocol handler initialized [  +0.011577] IR Sharp protocol handler initialized [  +0.011521] IR MCE Keyboard/mouse protocol handler initialized [  +0.000014] IR XMP protocol handler initialized [  +0.001035] usbcore: registered new interface driver uvcvideo [  +0.000006] USB Video Class driver (1.1.1) [  +0.000771] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio1-supply from device tree [  +0.000194] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio2-supply from device tree [  +0.000801] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio3-supply from device tree [  +0.000127] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio4-supply from device tree [  +0.000596] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio5-supply from device tree [  +0.000087] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio6-supply from device tree [  +0.000136] rockchip-iodomain ff100000.syscon:io-domains: Looking up pmuio-supply from device tree [  +0.005551] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com [  +0.000025] Bluetooth: Virtual HCI driver ver 1.5 [  +0.000221] Bluetooth: HCI UART driver ver 2.3 [  +0.000010] Bluetooth: HCI UART protocol H4 registered [  +0.000004] Bluetooth: HCI UART protocol LL registered [  +0.000005] Bluetooth: HCI UART protocol ATH3K registered [  +0.000187] usbcore: registered new interface driver bfusb [  +0.000118] usbcore: registered new interface driver btusb [  +0.000541] cpu cpu0: cpu_leakage=9 [  +0.000041] cpu cpu0: cpu_leakage=9 [  +0.000020] cpu cpu0: cpu_leakage-volt-sel=1 [  +0.000070] cpu cpu0: Looking up cpu-supply from device tree [  +0.000878] cpu cpu0: Looking up cpu-supply from device tree [  +0.000293] cpu cpu0: Looking up cpu-supply from device tree [  +0.002458] sdhci: Secure Digital Host Controller Interface driver [  +0.000004] sdhci: Copyright(c) Pierre Ossman [  +0.000010] Synopsys Designware Multimedia Card Interface Driver [  +0.002011] dwmmc_rockchip ff520000.dwmmc: IDMAC supports 32-bit address mode. [  +0.000058] dwmmc_rockchip ff520000.dwmmc: Using internal DMA controller. [  +0.000017] dwmmc_rockchip ff520000.dwmmc: Version ID is 270a [  +0.000102] dwmmc_rockchip ff520000.dwmmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo [  +0.000037] dwmmc_rockchip ff520000.dwmmc: 'clock-freq-min-max' property was deprecated. [  +0.000021] dwmmc_rockchip ff520000.dwmmc: Looking up vmmc-supply from device tree [  +0.000167] dwmmc_rockchip ff520000.dwmmc: Looking up vqmmc-supply from device tree [  +0.000795] dwmmc_rockchip ff520000.dwmmc: GPIO lookup for consumer wp [  +0.000009] dwmmc_rockchip ff520000.dwmmc: using device tree for GPIO lookup [  +0.000016] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff520000[0]' [  +0.000010] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff520000[0]' [  +0.000007] dwmmc_rockchip ff520000.dwmmc: using lookup tables for GPIO lookup [  +0.000012] dwmmc_rockchip ff520000.dwmmc: lookup for GPIO wp failed [  +0.011250] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [  +0.011099] dwmmc_rockchip ff520000.dwmmc: 1 slots initialized [  +0.001124] dwmmc_rockchip ff500000.dwmmc: IDMAC supports 32-bit address mode. [  +0.000062] dwmmc_rockchip ff500000.dwmmc: Using internal DMA controller. [  +0.000016] dwmmc_rockchip ff500000.dwmmc: Version ID is 270a [  +0.000091] dwmmc_rockchip ff500000.dwmmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo [  +0.000038] dwmmc_rockchip ff500000.dwmmc: 'clock-freq-min-max' property was deprecated. [  +0.000017] dwmmc_rockchip ff500000.dwmmc: Looking up vmmc-supply from device tree [  +0.000220] dwmmc_rockchip ff500000.dwmmc: Looking up vqmmc-supply from device tree [  +0.000135] dwmmc_rockchip ff500000.dwmmc: GPIO lookup for consumer cd [  +0.000009] dwmmc_rockchip ff500000.dwmmc: using device tree for GPIO lookup [  +0.000015] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@ff500000[0]' [  +0.000012] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@ff500000[0]' [  +0.000008] dwmmc_rockchip ff500000.dwmmc: using lookup tables for GPIO lookup [  +0.000009] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO cd failed [  +0.000014] dwmmc_rockchip ff500000.dwmmc: GPIO lookup for consumer wp [  +0.000008] dwmmc_rockchip ff500000.dwmmc: using device tree for GPIO lookup [  +0.000010] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff500000[0]' [  +0.000010] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff500000[0]' [  +0.000007] dwmmc_rockchip ff500000.dwmmc: using lookup tables for GPIO lookup [  +0.000009] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO wp failed [  +0.011157] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [  +0.011089] dwmmc_rockchip ff500000.dwmmc: 1 slots initialized [  +0.000323] sdhci-pltfm: SDHCI platform and OF driver helper [  +0.001005] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/standby-led[0]' - status (0) [  +0.000870] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/power-led[0]' - status (0) [  +0.000441] of_get_named_gpiod_flags: parsed 'gpios' property of node '/switches/usb-switch[0]' - status (0) [  +0.000640] hidraw: raw HID events driver (C) Jiri Kosina [  +0.001632] usbcore: registered new interface driver usbhid [  +0.000006] usbhid: USB HID core driver [  +0.000555] ashmem: initialized [  +0.001778] rockchip-dmc dmc: Looking up center-supply from device tree [  +0.000396] rockchip-dmc dmc: unable to get devfreq-event device : dfi [  +0.003724] usbcore: registered new interface driver snd-usb-audio [  +0.002793] rk3328-codec ff410000.codec: spk_depop_time use default value. [  +0.005933] rockchip-pinctrl pinctrl: pin gpio0-27 already requested by vcc-host1-5v-regulator; cannot claim for ff030000.spdif [  +0.000015] rockchip-pinctrl pinctrl: pin-27 (ff030000.spdif) status -22 [  +0.000014] rockchip-pinctrl pinctrl: could not request pin 27 (gpio0-27) from group spdifm0-tx  on device rockchip-pinctrl [  +0.000008] rockchip-spdif ff030000.spdif: Error applying setting, reverse things back [  +0.002465] u32 classifier [  +0.000025] Netfilter messages via NETLINK v0.30. [  +0.000107] ip_set: protocol 6 [  +0.000377] Initializing XFRM netlink socket [  +0.001238] NET: Registered protocol family 10 [  +0.002344] NET: Registered protocol family 17 [  +0.000048] NET: Registered protocol family 15 [  +0.000134] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [  +0.000051] Bridge firewalling registered [  +0.000248] Bluetooth: RFCOMM socket layer initialized [  +0.000106] Bluetooth: RFCOMM ver 1.11 [  +0.000029] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [  +0.000017] Bluetooth: HIDP socket layer initialized [  +0.000114] 8021q: 802.1Q VLAN Support v1.8 [  +0.000052] [WLAN_RFKILL]: Enter rfkill_wlan_init [  +0.000645] [BT_RFKILL]: Enter rfkill_rk_init [  +0.000428] Key type dns_resolver registered [  +0.002083] mmc_host mmc1: Bus speed (slot 0) = 25000000Hz (slot req 25000000Hz, actual 25000000HZ div = 0) [  +0.000171] mmc1: new SDHC card at address 0001 [  +0.000351] Registered cp15_barrier emulation handler [  +0.000025] Registered setend emulation handler [  +0.001028] mmcblk1: mmc1:0001 ASTC 7.32 GiB [  +0.000778] registered taskstats version 1 [  +0.004388] Btrfs loaded, integrity-checker=on [  +0.000195] BTRFS: selftest: Running btrfs free space cache tests [  +0.000048] BTRFS: selftest: Running extent only tests [  +0.000032] BTRFS: selftest: Running bitmap only tests [  +0.000036] BTRFS: selftest: Running bitmap and extent tests [  +0.000051] BTRFS: selftest: Running space stealing from bitmap to extent [  +0.001778] BTRFS: selftest: Free space cache tests finished [  +0.000008] BTRFS: selftest: Running extent buffer operation tests [  +0.000000] BTRFS: selftest: Running btrfs_split_item tests [  +0.000097] BTRFS: selftest: Running find delalloc tests [  +0.004466]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 [  +0.474998] BTRFS: selftest: Running btrfs_get_extent tests [  +0.000429] BTRFS: selftest: Running hole first btrfs_get_extent test [  +0.000066] BTRFS: selftest: Running outstanding_extents tests [  +0.000134] BTRFS: selftest: Running qgroup tests [  +0.000005] BTRFS: selftest: Qgroup basic add [  +0.000185] BTRFS: selftest: Qgroup multiple refs test [  +0.454980] rk-vcodec ff360000.rkvdec: Looking up vcodec-supply from device tree [  +0.000176] rk-vcodec ff360000.rkvdec: parent devfreq retry [  +0.009300] rockchip-dmc dmc: Looking up center-supply from device tree [  +0.000249] rockchip-dmc dmc: current ATF version 0x101! [  +0.008333] rockchip-dmc dmc: read tf version 0x101! [  +0.010204] rockchip-dmc dmc: ddr_leakage=9 [  +0.006987] rockchip-dmc dmc: ddr_leakage-volt-sel=1 [  +0.007404] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [  +0.013663] devfreq dmc: Couldn't update frequency transition information. [  +0.006370] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' [  +0.000011] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' [  +0.000546] asoc-simple-card hdmi-sound: i2s-hifi <-> ff000000.i2s mapping ok [  +0.006995] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [  +0.000012] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [  +0.020741] asoc-simple-card sound: rk3328-hifi <-> ff010000.i2s mapping ok [  +0.006386] asoc-simple-card sound: snd-soc-dummy-dai <-> ff010000.i2s mapping ok [  +0.007295] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' [  +0.000012] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' [  +0.000457] asoc-simple-card spdif-sound: dit-hifi <-> ff030000.spdif mapping ok [  +0.006844] rk-vcodec ff360000.rkvdec: Looking up vcodec-supply from device tree [  +0.000085] rk-vcodec ff360000.rkvdec: parent devfreq is ok [  +0.006123] rk-vcodec ff360000.rkvdec: rkvdec_leakage=9 [  +0.005598] rk-vcodec ff360000.rkvdec: rkvdec_leakage-volt-sel=1 [  +0.005939] rk-vcodec ff360000.rkvdec: probe device [  +0.005454] rk-vcodec ff360000.rkvdec: vpu mmu dec ffffffc078835c10 [  +0.005839] rk-vcodec ff360000.rkvdec: allocator is drm [  +0.005442] rk-vcodec ff360000.rkvdec: checking hw id 3410 [  +0.006028] rk-vcodec ff360000.rkvdec: init success [  +0.007451] rk808-rtc rk808-rtc: setting system clock to 2016-01-21 08:50:20 UTC (1453366220) [  +0.005757] of_cfs_init [  +0.005116] of_cfs_init: OK [  +0.016020] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 415; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-2ed8b386', rk_ko_ver is '5', built at '18:22:05', on 'Apr  1 2018'. [  +0.007302] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9 [  +0.005838] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000 [  +0.005774] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000 [  +0.005628] mali-utgard ff300000.gpu: resource[2].start = 0x0x0000000000000012 [  +0.005543] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000013 [  +0.005495] mali-utgard ff300000.gpu: resource[4].start = 0x0x0000000000000014 [  +0.005455] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000015 [  +0.005407] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000016 [  +0.005372] mali-utgard ff300000.gpu: resource[7].start = 0x0x0000000000000017 [  +0.005366] mali-utgard ff300000.gpu: resource[8].start = 0x0x0000000000000018 [  +0.005379] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 617; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali. [  +0.006443] mali-utgard ff300000.gpu: gpu_leakage=9 [  +0.005265] mali-utgard ff300000.gpu: gpu_leakage-volt-sel=1 [  +0.005356] mali-utgard ff300000.gpu: Looking up mali-supply from device tree [  +0.001899] Mali: Mali device driver loaded [  +0.006579] ALSA device list: [  +0.005111]   #0: HDMI [  +0.004966]   #1: I2S [  +0.004906]   #2: SPDIF [  +0.005090] of_dma_request_slave_channel: dma-names property of node '/serial@ff130000' missing or empty [  +0.005689] ttyS2 - failed to request DMA [  +0.005655] Freeing unused kernel memory: 1152K [  +0.034275] random: systemd-udevd: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.003414] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000159] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000045] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000285] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000277] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000291] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000307] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000519] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.000928] random: udevadm: uninitialized urandom read (16 bytes read, 12 bits of entropy available) [  +0.022855] devfreq ff300000.gpu: Couldn't update frequency transition information. [  +1.692309] vendor storage:20160801 ret = -1 [  +2.110067] xhci-hcd xhci-hcd.9.auto: Timeout while waiting for setup device command [Apr 4 11:49] xhci-hcd xhci-hcd.9.auto: Timeout while waiting for setup device command [  +0.215948] usb 5-1: device not accepting address 2, error -62 [  +5.400174] xhci-hcd xhci-hcd.9.auto: Timeout while waiting for setup device command [  +5.231945] xhci-hcd xhci-hcd.9.auto: Timeout while waiting for setup device command [  +0.216878] usb 5-1: device not accepting address 3, error -62 [  +0.036071] usb usb5-port1: attempt power cycle [  +1.022138] xhci-hcd xhci-hcd.9.auto: Cannot set link state. [  +0.015920] usb usb5-port1: cannot disable (err = -32) [  +0.016017] xhci-hcd xhci-hcd.9.auto: Cannot set link state. [  +0.006891] usb usb5-port1: cannot disable (err = -32) [  +0.023448] md: linear personality registered for level -1 [  +0.011203] md: multipath personality registered for level -4 [  +0.011145] md: raid0 personality registered for level 0 [  +0.011334] md: raid1 personality registered for level 1 [  +0.009638] async_tx: api initialized (async) [  +0.010897] md: raid6 personality registered for level 6 [  +0.006018] md: raid5 personality registered for level 5 [  +0.005749] md: raid4 personality registered for level 4 [  +0.015652] md: raid10 personality registered for level 10 [  +0.624340] EXT4-fs (mmcblk1p7): mounted filesystem with writeback data mode. Opts: (null) [  +0.831086] systemd[1]: System time before build time, advancing clock. [  +0.190941] ip_tables: (C) 2000-2006 Netfilter Core Team [  +0.043932] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [  +0.009101] systemd[1]: Detected architecture arm64. [  +0.038731] systemd[1]: Set hostname to <rock64>. [  +1.651795] systemd[1]: Listening on Device-mapper event daemon FIFOs. [  +0.021356] systemd[1]: Listening on Journal Socket. [  +0.009805] systemd[1]: Reached target Swap. [  +0.010123] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [  +0.009993] systemd[1]: Listening on LVM2 metadata daemon socket. [  +0.010047] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [  +0.009910] systemd[1]: Listening on RPCbind Server Activation Socket. [  +0.010219] systemd[1]: Listening on Journal Audit Socket. [  +0.009292] systemd[1]: Created slice User and Session Slice. [  +0.009955] systemd[1]: Created slice System Slice. [  +0.011822] systemd[1]: Starting Remount Root and Kernel File Systems... [  +0.012924] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling... [  +0.011836] systemd[1]: Created slice system-getty.slice. [  +0.012708] systemd[1]: Mounting Debug File System... [  +0.011625] systemd[1]: Starting Create list of required static device nodes for the current kernel... [  +0.009891] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [  +0.009619] systemd[1]: Reached target Encrypted Volumes. [  +0.009267] systemd[1]: Listening on udev Control Socket. [  +0.009514] systemd[1]: Created slice system-serial\x2dgetty.slice. [  +0.008303] systemd[1]: Listening on udev Kernel Socket. [  +0.008718] systemd[1]: Created slice system-syncthing.slice. [  +0.008360] systemd[1]: Listening on fsck to fsckd communication Socket. [  +0.011047] systemd[1]: Mounting Huge Pages File System... [  +0.009948] systemd[1]: Mounting NFSD configuration filesystem... [  +0.028822] systemd[1]: Listening on Journal Socket (/dev/log). [  +0.010206] systemd[1]: Mounting POSIX Message Queue File System... [  +0.007994] systemd[1]: Listening on LVM2 poll daemon socket. [  +0.015188] systemd[1]: Starting Restore / save the current clock... [  +0.011661] systemd[1]: Starting Nameserver information manager... [  +0.012229] systemd[1]: Mounting RPC Pipe File System... [  +0.007226] systemd[1]: Listening on Syslog Socket. [  +0.011362] systemd[1]: Starting Journal Service... [  +0.008244] systemd[1]: Reached target Slices. [  +0.008512] systemd[1]: Created slice system-systemd\x2dfsck.slice. [  +0.018103] systemd[1]: Starting Load Kernel Modules... [  +0.016110] systemd[1]: Mounted NFSD configuration filesystem. [  +0.008265] systemd[1]: Mounted RPC Pipe File System. [  +0.008024] systemd[1]: Mounted Huge Pages File System. [  +0.007976] systemd[1]: Mounted Debug File System. [  +0.007942] systemd[1]: Mounted POSIX Message Queue File System. [  +0.008929] systemd[1]: Started Remount Root and Kernel File Systems. [  +0.009836] systemd[1]: Started Create list of required static device nodes for the current kernel. [  +0.011409] systemd[1]: Started Restore / save the current clock. [  +0.014143] systemd[1]: Started Load Kernel Modules. [  +0.012071] systemd[1]: Started Nameserver information manager. [  +0.019636] systemd[1]: Time has been changed [  +0.008938] systemd[1]: Started LVM2 metadata daemon. [  +0.011048] systemd[1]: Starting Apply Kernel Variables... [  +0.010470] systemd[1]: Mounting Configuration File System... [  +0.013069] systemd[1]: Mounting FUSE Control File System... [  +0.021026] systemd[1]: Starting Create Static Device Nodes in /dev... [  +0.027046] systemd[1]: Starting Initial Check File System Quotas... [  +0.040499] systemd[1]: Starting udev Coldplug all Devices... [  +0.014054] systemd[1]: Starting Load/Save Random Seed... [  +0.011243] systemd[1]: Starting pNFS block layout mapping daemon... [  +0.011774] systemd[1]: Mounted FUSE Control File System. [  +0.007920] systemd[1]: Mounted Configuration File System. [  +0.008255] systemd[1]: Started Journal Service. [  +0.083529] systemd-journald[305]: Received request to flush runtime journal from PID 1 [  +1.196664] FAT-fs (mmcblk1p6): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [  +0.031520] FAT-fs (mmcblk1p6): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ +11.499992] random: nonblocking pool is initialized [  +5.747796] xhci-hcd xhci-hcd.9.auto: Timeout while waiting for setup device command [  +5.231993] xhci-hcd xhci-hcd.9.auto: Timeout while waiting for setup device command [  +0.217917] usb 5-1: device not accepting address 5, error -62 [  +0.016687] xhci-hcd xhci-hcd.9.auto: Cannot set link state. [  +0.016775] usb usb5-port1: cannot disable (err = -32) [  +0.968641] usb 5-1: new SuperSpeed USB device number 6 using xhci-hcd [  +0.028982] usb 5-1: New USB device found, idVendor=174c, idProduct=55aa [  +0.017095] usb 5-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 [  +0.017049] usb 5-1: Product: External HDD [  +0.016795] usb 5-1: Manufacturer: 01234567890123456789012345678901234567890123 [  +0.017223] usb 5-1: SerialNumber: 201308070213 [  +0.080534] usb-storage 5-1:1.0: USB Mass Storage device detected [  +0.009429] usb-storage 5-1:1.0: Quirks match for vid 174c pid 55aa: c00000 [  +0.012170] scsi host0: usb-storage 5-1:1.0 [  +0.014324] usbcore: registered new interface driver usb-storage [  +0.014634] usbcore: registered new interface driver uas [  +6.266770] scsi 0:0:0:0: Direct-Access     WDC WD32 01ABYS-01B9A0    13.0 PQ: 0 ANSI: 5 [  +0.021096] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB) [  +0.018004] sd 0:0:0:0: [sda] Write Protect is off [  +0.016951] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00 [  +0.006667] sd 0:0:0:0: [sda] No Caching mode page found [  +0.007142] sd 0:0:0:0: [sda] Assuming drive cache: write through [  +0.063202]  sda: sda1 [  +0.008882] sd 0:0:0:0: [sda] Attached SCSI disk [  +0.796793] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl [  +2.960428] rk_gmac-dwmac ff540000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [Apr 4 11:50] NFSD: starting 90-second grace period (net ffffff8009287800)
Any ideas how to fix this...?
(03-30-2018, 03:50 AM)k8Va Wrote: I bought another external HD (WD Elements Desktop) but there seems the be the same problem.
So it isnt a problem with this specific external HD.
Any help?
It appears that this problem with HDD not being detected on USB 3.0 happens only to 3.5" drives only.
(03-31-2018, 06:24 AM)frewind Wrote: Try connecting it to the USB2 ports and see what results you get. I've found the USB3 implementation on Linux/OVM to be very temperamental. The only thing I have found to work without an issue is my ORICO drive enclosure.
This model? http://www.orico.cc/goods.php?id=6310  It has the same chipset as the vendor USB3 SATA connector (link).
https://www.aliexpress.com/item/Black-JM...autifyAB=0
When your external hard drive is not detected in Windows Explorer then you may check it in the Disk Management. To check & repair your Toshiba hard drive, follow the below step:
  • Type disk management in a search bar & right-click on unallocated space and select “New simple volume” >> “next”
  • Choose the volume size >> “next” again
  • Assign the Hard drive letter & path >> next to complete the process
  • Next, click on “next” >> “new simple volume” >> “finish” option
  • Wait until the process finishes.
I hope the steps mentioned above will definitely help you to fix Toshiba external hard drive not showing up.
My PinePhone would not detect either a USB hard disk drive or SD card USB adapter when plugged into my dock so I was going through the suggestions in this thread. Although I've always hot plugged the dock into the PinePhone first and then connected the USB device afterwards (keyboard and mouse) and they were detected and immediately usable, this did not work with USB drives.
I found that the USB hard disk and USB SD card adapter both worked perfectly if I reboot the PinePhone after connecting the powered dock to it. After the reboot, I plug-in the USB drive. I'm running Mobian (https://images.mobian-project.org/pineph...113.img.gz) and I last did a apt get dist-upgrade about a week ago.
I post here just in case someone stumbles upon this thread and finds the above information helpful.
Also
uname -a Linux mobian 5.9-sunxi64 #1 SMP PREEMPT Thu Nov 26 09:29:57 UTC 2020 aarch64 GNU/Linux
(12-08-2020, 03:37 PM)calinb Wrote: My PinePhone would not detect either a USB hard disk drive or SD card USB adapter when plugged into my dock so I was going through the suggestions in this thread. Although I've always hot plugged the dock into the PinePhone first and then connected the USB device afterwards (keyboard and mouse) and they were detected and immediately usable, this did not work with USB drives.
Also
You need to fdo hard reset
I bought a USB C Charger, "FIVOF 65W GaN Tech Fast Charging", from Amazon (not currently available) a month ago and I've not had trouble with either my SD cards, USB DVD drives, or my Seagate USB hard disk since then. I don't know if it is the cure, because I also apt dist-upgrade daily but my dock USB connection has been working great since I upgraded my power supply to 65W from the previous power supply that came with my old Motorola G4-plus. I had to get a new USB-C to USB-C cable for the new charger too.
  problem with debian emmc boot G4zCDzWb 10 31,263 11-01-2024, 04:32 PM
Last Post: bits
  Rock64 Debian 11 (Bullseye) install problem jbize 15 25,566 10-12-2023, 05:14 PM
Last Post: tpaul
  Looking for guidance on setting up with external RTC Ditchmagnet 0 2,547 05-13-2022, 05:22 PM
Last Post: Ditchmagnet
Sad Rock64 crash randomly during usb 3 copy with RAID1 drive phalae 24 58,347 09-14-2020, 10:48 AM
Last Post: BrownLuther007
  Arch Linux Arm - external RTC problem max 1 5,498 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 11,270 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 8,799 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 7,407 01-20-2020, 12:25 PM
Last Post: kf5zmi
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 12,228 05-26-2019, 10:28 PM
Last Post: Wizardknight
  ROCK64 Kernel compilation problem cao 0 4,037 01-21-2019, 01:21 AM
Last Post: cao
