External hard drive problem
I just got my ROCK 64 with the jessie-openmediavault-rock64-0.6.25-193-arm64.img image from https://github.com/ayufan-rock64/linux-b...tag/0.6.25
But the external hard (http://en.sharkoon.com/product/1685/10394#specs) drive isnt recognized.
What is going on? The hard drive works fine with Openmediavault on raspberry pi & OdroidXU4.
root@rock64:~# sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/mtdblock0: 4 MiB, 4161536 bytes, 8128 sectors
Disk /dev/mtdblock1: 256 KiB, 262144 bytes, 512 sectors
GPT PMBR size mismatch (4458495 != 15359999) will be corrected by w(rite).
Disk /dev/mmcblk1: 7.3 GiB, 7864320000 bytes, 15360000 sectors
Disklabel type: gpt
Disk identifier: 824DA7D1-B7E7-49CA-A273-69A1E8B9785F
Device          Start      End  Sectors  Size Type
/dev/mmcblk1p1     64     8063     8000  3.9M Linux filesystem
/dev/mmcblk1p2   8064     8191      128   64K Linux filesystem
/dev/mmcblk1p3   8192    16383     8192    4M Linux filesystem
/dev/mmcblk1p4  16384    24575     8192    4M Linux filesystem
/dev/mmcblk1p5  24576    32767     8192    4M Linux filesystem
/dev/mmcblk1p6  32768   262143   229376  112M Microsoft basic data
/dev/mmcblk1p7 262144 15359966 15097823  7.2G Linux filesystem
At around 900 seconds I powered off and on the HD...
root@rock64:~# dmesg | grep usb
[    0.614193] usbcore: registered new interface driver usbfs
[    0.614793] usbcore: registered new interface driver hub
[    0.615433] usbcore: registered new device driver usb
[    1.161801] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree
[    1.161918] vcc_host1_5v: could not add device link phy-ff450000.syscon:usb2-phy@100.0 err -2
[    1.162519] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree
[    1.162629] vcc_host1_5v: could not add device link phy-ff450000.syscon:usb2-phy@100.1 err -2
[    1.163102] rockchip-usb2phy ff450000.syscon:usb2-phy@100: GPIO lookup for consumer otg-vbus
[    1.163120] rockchip-usb2phy ff450000.syscon:usb2-phy@100: using device tree for GPIO lookup
[    1.163139] of_get_named_gpiod_flags: can't parse 'otg-vbus-gpios' property of node '/syscon@ff450000/usb2-phy@100[0]'
[    1.163155] of_get_named_gpiod_flags: can't parse 'otg-vbus-gpio' property of node '/syscon@ff450000/usb2-phy@100[0]'
[    1.163171] rockchip-usb2phy ff450000.syscon:usb2-phy@100: using lookup tables for GPIO lookup
[    1.163186] rockchip-usb2phy ff450000.syscon:usb2-phy@100: lookup for GPIO otg-vbus failed
[    1.163201] rockchip-usb2phy ff450000.syscon:usb2-phy@100: vbus_drv is not assigned
[    1.164774] rockchip-u3phy ff470000.usb3-phy: GPIO lookup for consumer vbus-drv
[    1.164793] rockchip-u3phy ff470000.usb3-phy: using device tree for GPIO lookup
[    1.164811] of_get_named_gpiod_flags: can't parse 'vbus-drv-gpios' property of node '/usb3-phy@ff470000[0]'
[    1.164829] of_get_named_gpiod_flags: can't parse 'vbus-drv-gpio' property of node '/usb3-phy@ff470000[0]'
[    1.164843] rockchip-u3phy ff470000.usb3-phy: using lookup tables for GPIO lookup
[    1.164858] rockchip-u3phy ff470000.usb3-phy: lookup for GPIO vbus-drv failed
[    1.164872] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned
[    1.165945] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree
[    1.165965] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed
[    1.166405] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree
[    1.166427] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed
[    1.168184] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[    1.601869] usbcore: registered new interface driver udl
[    2.252837] usbcore: registered new interface driver cdc_ether
[    2.252900] usbcore: registered new interface driver rndis_host
[    2.255119] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[    2.255145] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[    2.256290] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree
[    2.256303] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed
[    2.256318] ff580000.usb supply vusb_d not found, using dummy regulator
[    2.256418] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree
[    2.256429] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed
[    2.256438] ff580000.usb supply vusb_a not found, using dummy regulator
[    2.269039] dwc2 ff580000.usb: DWC OTG Controller
[    2.269106] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    2.269153] dwc2 ff580000.usb: irq 43, io mem 0xff580000
[    2.269451] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.269461] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.269469] usb usb1: Product: DWC OTG Controller
[    2.269477] usb usb1: Manufacturer: Linux 4.4.114-rockchip-ayufan-193 dwc2_hsotg
[    2.269485] usb usb1: SerialNumber: ff580000.usb
[    2.339882] ehci-platform ff5c0000.usb: EHCI Host Controller
[    2.340258] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[    2.340412] ehci-platform ff5c0000.usb: irq 44, io mem 0xff5c0000
[    2.346124] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    2.346421] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.346432] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.346440] usb usb2: Product: EHCI Host Controller
[    2.346448] usb usb2: Manufacturer: Linux 4.4.114-rockchip-ayufan-193 ehci_hcd
[    2.346455] usb usb2: SerialNumber: ff5c0000.usb
[    2.348661] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    2.348982] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[    2.349160] ohci-platform ff5d0000.usb: irq 45, io mem 0xff5d0000
[    2.404377] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.404387] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.404395] usb usb3: Product: Generic Platform OHCI controller
[    2.404404] usb usb3: Manufacturer: Linux 4.4.114-rockchip-ayufan-193 ohci_hcd
[    2.404411] usb usb3: SerialNumber: ff5d0000.usb
[    2.407569] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    2.407579] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.407587] usb usb4: Product: xHCI Host Controller
[    2.407595] usb usb4: Manufacturer: Linux 4.4.114-rockchip-ayufan-193 xhci-hcd
[    2.407603] usb usb4: SerialNumber: xhci-hcd.9.auto
[    2.409479] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.409661] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[    2.409672] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.409680] usb usb5: Product: xHCI Host Controller
[    2.409688] usb usb5: Manufacturer: Linux 4.4.114-rockchip-ayufan-193 xhci-hcd
[    2.409696] usb usb5: SerialNumber: xhci-hcd.9.auto
[    2.412820] usbcore: registered new interface driver iforce
[    2.412930] usbcore: registered new interface driver xpad
[    2.413499] usbcore: registered new interface driver usbtouchscreen
[    2.460412] usbcore: registered new interface driver uvcvideo
[    2.467045] usbcore: registered new interface driver bfusb
[    2.467181] usbcore: registered new interface driver btusb
[    2.519667] of_get_named_gpiod_flags: parsed 'gpios' property of node '/switches/usb-switch[0]' - status (0)
[    2.520720] usbcore: registered new interface driver usbhid
[    2.520723] usbhid: USB HID core driver
[    2.523452] usbcore: registered new interface driver snd-usb-audio
[   13.435160] usb 5-1: device not accepting address 2, error -62
[   24.283144] usb 5-1: device not accepting address 3, error -62
[   24.320263] usb usb5-port1: attempt power cycle
[   25.360147] usb usb5-port1: cannot disable (err = -32)
[   25.394161] usb usb5-port1: cannot disable (err = -32)
[  889.555166] usb 5-1: device not accepting address 5, error -62
[  900.419178] usb 5-1: device not accepting address 6, error -62
[  900.464160] usb usb5-port1: attempt power cycle
[  901.502224] usb usb5-port1: cannot disable (err = -32)
[  901.549246] usb usb5-port1: cannot disable (err = -32)
Same problem also with the "jessie-openmediavault-rock64-0.6.25-193-armhf.img" image btw...
For starters, perhaps try the release image of OMV instead of pre-release.
Same result.
https://github.com/ayufan-rock64/linux-b...ses/latest  -->
jessie-openmediavault-rock64-0.5.15-136-armhf.img
Is there a problem with the chipset?  ASMedia ASM1053
[    0.588101] usbcore: registered new interface driver usbfs
[    0.588706] usbcore: registered new interface driver hub
[    0.589315] usbcore: registered new device driver usb
[    1.107739] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree
[    1.107760] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/host-port failed
[    1.108395] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree
[    1.108415] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed
[    1.108832] rockchip-usb2phy ff450000.syscon:usb2-phy@100: GPIO lookup for consumer otg-vbus
[    1.108848] rockchip-usb2phy ff450000.syscon:usb2-phy@100: using device tree for GPIO lookup
[    1.108889] of_get_named_gpiod_flags: parsed 'otg-vbus-gpios' property of node '/syscon@ff450000/usb2-phy@100[0]' - status (0)
[    1.109627] rockchip-u3phy ff470000.usb3-phy: GPIO lookup for consumer vbus-drv
[    1.109643] rockchip-u3phy ff470000.usb3-phy: using device tree for GPIO lookup
[    1.109675] of_get_named_gpiod_flags: parsed 'vbus-drv-gpios' property of node '/usb3-phy@ff470000[0]' - status (0)
[    1.110073] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree
[    1.110091] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed
[    1.110616] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree
[    1.110635] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed
[    1.112207] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[    1.618779] usbcore: registered new interface driver cdc_ether
[    1.619676] usbcore: registered new interface driver rndis_host
[    1.622431] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[    1.623213] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[    1.624895] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree
[    1.624915] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed
[    1.624933] ff580000.usb supply vusb_d not found, using dummy regulator
[    1.625948] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree
[    1.625966] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed
[    1.625981] ff580000.usb supply vusb_a not found, using dummy regulator
[    1.782396] dwc2 ff580000.usb: DWC OTG Controller
[    1.783052] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    1.794720] dwc2 ff580000.usb: irq 40, io mem 0x00000000
[    1.806352] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.817899] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.829376] usb usb1: Product: DWC OTG Controller
[    1.840537] usb usb1: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 dwc2_hsotg
[    1.852021] usb usb1: SerialNumber: ff580000.usb
[    1.924423] ehci-platform ff5c0000.usb: EHCI Host Controller
[    1.935841] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[    1.947351] ehci-platform ff5c0000.usb: irq 41, io mem 0xff5c0000
[    1.964182] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    1.975431] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.986415] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.997293] usb usb2: Product: EHCI Host Controller
[    2.007844] usb usb2: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 ehci_hcd
[    2.018626] usb usb2: SerialNumber: ff5c0000.usb
[    2.072398] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    2.082934] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[    2.093459] ohci-platform ff5d0000.usb: irq 42, io mem 0xff5d0000
[    2.158419] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.168795] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.179236] usb usb3: Product: Generic Platform OHCI controller
[    2.189540] usb usb3: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 ohci_hcd
[    2.199964] usb usb3: SerialNumber: ff5d0000.usb
[    2.275864] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    2.286667] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.297596] usb usb4: Product: xHCI Host Controller
[    2.308371] usb usb4: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 xhci-hcd
[    2.319431] usb usb4: SerialNumber: xhci-hcd.8.auto
[    2.376856] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.388508] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[    2.400005] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.411566] usb usb5: Product: xHCI Host Controller
[    2.422872] usb usb5: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 xhci-hcd
[    2.434506] usb usb5: SerialNumber: xhci-hcd.8.auto
[    2.472223] usbcore: registered new interface driver usbtouchscreen
[    2.719678] usbcore: registered new interface driver uvcvideo
[    2.841823] usbcore: registered new interface driver bfusb
[    2.853276] usbcore: registered new interface driver btusb
[    3.068897] of_get_named_gpiod_flags: parsed 'gpios' property of node '/switches/usb-switch[0]' - status (0)
[    3.084684] usbcore: registered new interface driver usbhid
[    3.092108] usbhid: USB HID core driver
[    3.099617] usbcore: registered new interface driver snd-usb-audio
[   13.319225] usb 5-1: device not accepting address 2, error -62
[   24.167216] usb 5-1: device not accepting address 3, error -62
[   35.015184] usb 5-1: device not accepting address 4, error -62
[   45.863209] usb 5-1: device not accepting address 5, error -62
[   45.901328] usb usb5-port1: unable to enumerate USB device
Do a dmesg -wH when the drive is disconnected, and then capture the results when you plug in/power on the drive... shoulve give a better idea what the kernel and drivers think of it.
Discussion also on: https://github.com/ayufan-rock64/linux-build/issues/140
Only powering off and on the external hard drive a few times seems to make it work. But it doesnt work by default when (re)booting.
Anyone any ideas?
It seems to be reproducible by turning on and off the external hard drive a few times:
[  +0.006130] usb usb5-port1: cannot disable (err = -32)
[  +1.222895] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.007061] usb usb5-port1: cannot disable (err = -32)
[  +1.301986] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.006539] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:26] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.006334] usb usb5-port1: cannot disable (err = -32)
[ +22.915402] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000997] usb usb5-port1: cannot disable (err = -32)
[ +25.746442] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000975] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:27] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000993] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:28] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000994] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:29] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000973] usb usb5-port1: cannot disable (err = -32)
[ +19.414341] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000826] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:30] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[Mar27 20:31] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000989] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:33] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000625] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:34] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000662] usb usb5-port1: cannot disable (err = -32)
[ +41.853443] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001120] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:35] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001126] usb usb5-port1: cannot disable (err = -32)
[ +29.718343] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.000927] usb usb5-port1: cannot disable (err = -32)
[  +1.204267] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001954] usb usb5-port1: cannot disable (err = -32)
[  +9.059169] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001089] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:36] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001125] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:37] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001346] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:38] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001323] usb usb5-port1: cannot disable (err = -32)
[  +1.196744] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001487] usb usb5-port1: cannot disable (err = -32)
[ +38.355296] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001314] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:40] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001371] usb usb5-port1: cannot disable (err = -32)
[ +29.995103] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001101] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:41] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001330] usb usb5-port1: cannot disable (err = -32)
[ +19.989129] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001335] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:42] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.001341] usb usb5-port1: cannot disable (err = -32)
[  +1.202664] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.018718] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:44] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.019053] usb usb5-port1: cannot disable (err = -32)
[ +40.660799] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.018685] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:46] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.019019] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:47] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.006564] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:48] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.018923] usb usb5-port1: cannot disable (err = -32)
[Mar27 20:49] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.019101] usb usb5-port1: cannot disable (err = -32)
[ +16.277967] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.006342] usb usb5-port1: cannot disable (err = -32)
[Mar27 21:30] xhci-hcd xhci-hcd.8.auto: port 0 resume PLC timeout
[  +5.742867] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +5.232322] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +0.218864] usb 5-1: device not accepting address 2, error -62
[Mar27 21:31] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +5.232182] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +0.207003] usb 5-1: device not accepting address 3, error -62
[  +5.409325] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +0.207016] usb 5-1: Device not responding to setup address.
[  +0.206919] usb 5-1: device not accepting address 4, error -71
[  +0.006232] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.006210] usb usb5-port1: cannot disable (err = -32)
[  +5.365865] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +5.216288] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +0.207000] usb 5-1: device not accepting address 5, error -62
[  +0.027109] usb usb5-port1: unable to enumerate USB device
[ +18.534735] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +5.216250] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +0.206943] usb 5-1: device not accepting address 6, error -62
[  +5.395727] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +5.229836] xhci-hcd xhci-hcd.8.auto: Timeout while waiting for setup device command
[  +0.218966] usb 5-1: device not accepting address 7, error -62
[  +0.018411] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  +0.018858] usb usb5-port1: cannot disable (err = -32)
[Mar27 21:32] usb 5-1: new SuperSpeed USB device number 8 using xhci-hcd
[  +0.029930] usb 5-1: New USB device found, idVendor=174c, idProduct=55aa
[  +0.018513] usb 5-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[  +0.013358] usb 5-1: Product: External HDD
[  +0.006015] usb 5-1: Manufacturer: 01234567890123456789012345678901234567890123
[  +0.006308] usb 5-1: SerialNumber: 201308070213
[  +0.059266] usb-storage 5-1:1.0: USB Mass Storage device detected
[  +0.007795] usb-storage 5-1:1.0: Quirks match for vid 174c pid 55aa: 400000
[  +0.006389] scsi host0: usb-storage 5-1:1.0
[  +0.006746] usbcore: registered new interface driver usb-storage
[  +0.010794] usbcore: registered new interface driver uas
[  +6.364552] scsi 0:0:0:0: Direct-Access     WDC WD32 01ABYS-01B9A0    13.0 PQ: 0 ANSI: 5
[  +0.007974] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[  +0.007000] sd 0:0:0:0: [sda] Write Protect is off
[  +0.006170] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[  +0.000435] sd 0:0:0:0: [sda] No Caching mode page found
[  +0.006158] sd 0:0:0:0: [sda] Assuming drive cache: write through
[  +0.080574]  sda: sda1
[  +0.007636] sd 0:0:0:0: [sda] Attached SCSI disk
[  +1.791350] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl
[Mar27 21:33] ip6_tables: (C) 2000-2006 Netfilter Core Team
I bought another external HD (WD Elements Desktop) but there seems the be the same problem.
So it isnt a problem with this specific external HD.
Any help?
As is this post: https://forum.pine64.org/showthread.php?...3#pid34403
With the stretch-minimal-rock64-0.6.28-197-arm64.img image the usb harddrive seems to be working without problems.
Are you connecting the drive via USB3?
Try connecting it to the USB2 ports and see what results you get. I've found the USB3 implementation on Linux/OVM to be very temperamental. The only thing I have found to work without an issue is my ORICO drive enclosure.
I just tried a Seagate Expansion Desktop Drive (2TB version). This is not recognise at boot, but if I flip the power off and on again to the drive, it is then recognised, can be mounted and works without issue, I do get one error thrown to the logs as follows....
[   48.758215] usb 5-1: new SuperSpeed USB device number 2 using xhci-hcd
[   48.770282] usb 5-1: New USB device found, idVendor=0bc2, idProduct=3321
[   48.770311] usb 5-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[   48.770332] usb 5-1: Product: Expansion Desk
[   48.770352] usb 5-1: Manufacturer: Seagate
[   48.770371] usb 5-1: SerialNumber: NA4KN4P8
[   48.879816] usbcore: registered new interface driver usb-storage
[   48.901411] scsi host0: uas
[   48.901830] usbcore: registered new interface driver uas
[   48.905890] scsi 0:0:0:0: Direct-Access     Seagate  Expansion Desk   0604 PQ: 0 ANSI: 6
[   48.907634] sd 0:0:0:0: [sda] Spinning up disk...
[   49.908061] .......ready
[   55.914183] sd 0:0:0:0: [sda] 488378645 4096-byte logical blocks: (2.00 TB/1.82 TiB)
[   55.914209] sd 0:0:0:0: [sda] 16384-byte physical blocks
[   55.932960] sd 0:0:0:0: [sda] Write Protect is off
[   55.932997] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
[   55.933465] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   55.933658] xhci-hcd xhci-hcd.8.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
[   55.935075] xhci-hcd xhci-hcd.8.auto: @00000000f3866720 00000000 00000000 1b000000 01038001
[   55.962435]  sda: sda1
[   55.965923] sd 0:0:0:0: [sda] Attached SCSI disk
When I plug it into the USB2 ports, it recognised as boot and is immediately available with no error thrown.
I have another drive enclosure which is recognised but throws lots of "xhci-hcd xhci-hcd.8.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring" errors, but I made this behave by adding a quirks option for the kernel module "options usb-storage quirks=0480:b202:u" I'm no kernel or device driver expert, but this option forces the USB driver to set the device class to "usb-storage" for USB device 0480:b202. I read a post on here suggesting you blacklist the UAS kernel module, but it did not fix the problem with that enclosure.
I'll play around a bit more with the Seagate drive over the following days to see if I can get anywhere with it.
Blacklisting UAS for WD and Seagate of the shelf enclosures usually fixes a lot of issues with USB3, current models seem to contain USB3/SATA bridges that need quirks to work with Linux's XHCI driver and UAS.
  problem with debian emmc boot G4zCDzWb 10 30,721 11-01-2024, 04:32 PM
Last Post: bits
  Rock64 Debian 11 (Bullseye) install problem jbize 15 24,482 10-12-2023, 05:14 PM
Last Post: tpaul
  Looking for guidance on setting up with external RTC Ditchmagnet 0 2,474 05-13-2022, 05:22 PM
Last Post: Ditchmagnet
Sad Rock64 crash randomly during usb 3 copy with RAID1 drive phalae 24 57,295 09-14-2020, 10:48 AM
Last Post: BrownLuther007
  Arch Linux Arm - external RTC problem max 1 5,354 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 11,044 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 8,588 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 7,253 01-20-2020, 12:25 PM
Last Post: kf5zmi
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 11,893 05-26-2019, 10:28 PM
Last Post: Wizardknight
  ROCK64 Kernel compilation problem cao 0 3,941 01-21-2019, 01:21 AM
Last Post: cao
Users browsing this thread:
