[Warning: root device does not exist] Can not install generic kernel on ROCK 64?
I thought about upgrading the kernel, as a result of searching with apt-cache, there was a package named linux - image - 4.15.0 - 10 - generic and I tried to install it,
And it was displayed. I tried restarting terribly, but running the uname -a did not bring up the kernel version.
The OS is ununtu bionic. The friend's PC had lubuntu artful and the CPU was amd64, but I feel that this message was still there even here. What should I do?
apt's log
Preparing to unpack .../linux-image-4.15.0-10-generic_4.15.0-10.11_arm64.deb ...
Examining /etc/kernel/preinst.d/
Done.
Unpacking linux-image-4.15.0-10-generic (4.15.0-10.11) ...
Setting up linux-image-4.15.0-10-generic (4.15.0-10.11) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.15.0-10-generic /boot/vmlinuz-4.15.0-10-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.15.0-10-generic /boot/vmlinuz-4.15.0-10-generic
update-initramfs: Generating /boot/initrd.img-4.15.0-10-generic
Using DTB: rockchip/rk3328-rock64.dtb
Couldn't find DTB rk3328-rock64.dtb in /usr/lib/linux-image-4.15.0-10-generic or /etc/flash-kernel/dtbs
Installing  into /boot/dtbs/4.15.0-10-generic/rockchip/rk3328-rock64.dtb
cp: cannot stat '': No such file or directory
run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.15.0-10-generic.postinst line 1052.
[1mdpkg:[0m error processing package linux-image-4.15.0-10-generic (--configure):
 installed linux-image-4.15.0-10-generic package post-installation script subprocess returned error exit status 2
Errors were encountered while processing:
Original text
カーネルをアップグレードしようと思いapt-cacheで検索した結果、linux-image-4.15.0-10-genericというパッケージがあったのでインストールしようと思ったのですが、
と表示されてしまいました。恐る恐る再起動してみましたが、uname -aを実行してもカーネルのバージョンは上がっていませんでした。
OSはununtu bionicです。友人のPCにはlubuntu artful が入っていて、CPUはamd64でしたが、こちらでもこのメッセージが出ていたことがあった気がします。どうすればよいのですか?
aptのログ
Done.
Running depmod.
  Rock 64 failure / kernel panic n0021913 2 6,492 07-07-2022, 01:16 PM
Last Post: anchor00
  OMV - Updates and Plug-in install broken MotoTom 0 5,952 06-26-2022, 01:21 PM
Last Post: MotoTom
Tongue RockPro64 Ethernet NOP After Debian 11 Install... MattDralle 1 4,667 10-30-2021, 06:10 AM
Last Post: Rocklobster
  Rock64 kernel panics clay 15 23,734 10-17-2021, 06:30 PM
  Rock 64 seem like a dead end munocat 3 8,338 03-21-2019, 10:13 PM
Last Post: thewonderer
  Rock 64 a failure..very disappointed arxaios 5 11,358 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  How can I install tvheadend server un rock64? gedas07 12 22,530 08-25-2018, 01:06 PM
Last Post: gedas07
  Install seems to always corrupt Lenny 2 5,446 06-02-2018, 10:05 AM
Last Post: Lenny
  [Issue] All Rock leds are blinking Chispolas 6 13,958 04-18-2018, 09:12 PM
Last Post: pfeerick
  Rock64 kernel compilation - configs acrobatbob 0 3,464 04-06-2018, 02:55 AM
Last Post: acrobatbob
