After flashing Ubuntu- how to get graphical desktop
I have installed Ubuntu successfully.
However, having downloaded Xubuntu desktop (Sudo apt install xubuntu desktop) I am not able to reboot to the desktop!  I can only boot to terminal.
Can anyone give me the command line to reboot to desktop??
Did you install xorg etc? try
startx
IIRC there is also a desktop install script in /usr/local/sbin.
There are premade images with Mate DE too.
[edit] please read the forum rules and post only once.
Thanks Luke,
So what command would I use run one of the pre-installed desktops? Can you give me the actual command?
(02-01-2018, 02:03 AM)Partymack711 Wrote: Thanks Luke,
From memory, as I don't have a unit at hand:
sudo /usr/local/sbin/install_desktop.sh
The script will ask you to specify which desktop you want.
You have to run one of ayufan's images; on his git you'll also find a Pine A64(+) image with a Mate desktop
Thanks Luke!
On Ayufans Github page I am not seeing a Pine 64 image with any desktop. There is Pinebook images with Mate desktop - but none for Pine64.
Any ideas?
Indeed, you are correct. I think you'll have to install it manually then. If that is not something you want to do then there is always armbian (and other third party images)
Thanks Luke - I’ll try Manual download tonight so.
  Ubuntu server 20.04 request phi0x 2 10,961 12-30-2020, 08:02 PM
Last Post: phi0x
  Install Telegram Desktop in KDE Neon podcastlinux 2 10,428 01-26-2020, 01:43 AM
Last Post: giga
  SPI on ubuntu IlyaM 4 14,576 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,181 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,774 04-16-2018, 03:09 PM
Last Post: Rocklobster
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 928,320 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 13,449 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 15,330 08-03-2017, 03:52 PM
Last Post: Luke
  Ubuntu boot very slow with wifi driver remainder 9 28,148 08-03-2017, 07:23 AM
Last Post: victorssantos
  Recovering root access in Ubuntu Scientomancer 3 10,154 07-28-2017, 02:53 PM
Last Post: Scientomancer
