(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
Hi, I just updated && upgraded and docker 1.13.1 seems to have a kernel related issue.
Running any image will result in a:
docker: Error response from daemon: Could not check if docker-default AppArmor profile was loaded: open /sys/kernel/security/apparmor/profiles: no such file or directory.
ERRO[0006] error getting events from daemon: net/http: request canceled
The profiles folder does not exist.
Do you have any clue?
I have the Pine64LTS board mounted in the playbox with the LCD screen. There is no SD card slot on the board. I have the eMMC burner and a 64GB eMMC which is actually only 60.xGB according to etcher and Apple Pi-Baker. Will this package work with my setup? If not which one would you recommend. I downloaded and burned a Sopine image. The machine boots to the Sopine Logo screen and stops. I let is run for over 24 hours with no luck. Got the Sopine power supply so it's not that.
Thanks,
Mike
(01-02-2018, 03:31 PM)mcrognale Wrote: I have the Pine64LTS board mounted in the playbox with the LCD screen. There is no SD card slot on the board. I have the eMMC burner and a 64GB eMMC which is actually only 60.xGB according to etcher and Apple Pi-Baker. Will this package work with my setup? If not which one would you recommend. I downloaded and burned a Sopine image. The machine boots to the Sopine Logo screen and stops. I let is run for over 24 hours with no luck. Got the Sopine power supply so it's not that.
Thanks,
Mike
Quote:There is no SD card slot on the board
There is on the underside of the board.
And no, only SoPine/LTS images are supported due to different RAM configuration. But there are many good images available for the LTS board. What do you want to run on it exactly ?
If you want ubuntu, then try armbian. You can install XFCE or Mate manually or using armbian's script if you want a desktop...
I wanted to run Android. Is that even available? I will look at the board again. But I bought the eMMC burner device in order to do the programming directly. Is there an Android image that will work? Thanks for taking the time to answer me.
Armbian downloaded and burned to the eMMC using etcher. waiting to see if it boots. so far, 10 minutes now, nothing.
i think you need an image that was made specifically for emmc. if you burn a sd card image to emmc it will not work. look for sopine/lts for emmc.
Doing that now.
I have just downloaded and burned image SD of Xenial Mate image from the etcher application on this site - I presume this is longsleeps image?
I am s noob and wondered after boot what are the key things I should do? There is advice around extending the hard drive partition and running Sudo_update etc.
Are these activities still needed and can anyone bullet point them out? I’m hoping to set it up later today
Thanks b
(01-31-2018, 07:10 AM)Partymack711 Wrote: Hi,
Thanks b
Hey, those images are very old at this point.
You should use ayufan's images instead.
Because longsleep's images are very outdated at this point, I am locking this tread to avoid confusion for newcomers.
Everyone should be using either ayufan's A64 Linux images or maintained third party OS images henceforth.
Massive thanks to longsleep for getting Linux one the Pine A64(+) off the ground!
  Ubuntu server 20.04 request phi0x 2 10,930 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,311 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 7,826 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 40,850 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,376 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,538 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,156 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,758 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,416 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 13,431 08-23-2017, 09:28 AM
Last Post: gilbertotcc
