sopine cluster thermal images
So it look like I have a failing module Undecided
They're in order from right to left 0 through 4, and sopine1 is running stupidly hot despite not doing anything as confirmed by the terminal screen cap. The outside modules are the coolest, while 2 and 3 are taking some extra heat.
Fans and forced air are on the way. Heatsinks are at the office, but sopine1 looks like it's toast (sic)
I wish IR cameras were cheaper. I've been wanting one since I started building printers. I wonder why that module is generating so much heat.
bummer :/ you sure its the module that's failing - does it also get hot on the stock baseboard ?
(12-29-2017, 02:16 PM)Luke Wrote: bummer :/ you sure its the module that's failing - does it also get hot on the stock baseboard ?
sadly it's the module, on the baseboard it heats up to over 90C and then goes into thermal shut-down.
Ah well, then RIP Sad
  Selling Clusterboard + 4 sopine xblack86 7 15,064 09-26-2022, 03:09 AM
Last Post: poVoq
  Buy Cluster and Compute Modules jpotter 1 5,734 01-10-2022, 04:01 PM
Last Post: dcdc
  SOPine modules stay off at reboot? PeterKeuning 32 67,993 08-17-2021, 11:11 AM
Last Post: renze
  What's the point of a cluster? guenther 2 8,246 04-07-2021, 10:49 AM
Last Post: guenther
  Add ordinary so-dimm memory to cluster slot? fxSol 1 6,679 03-02-2021, 03:54 AM
Last Post: poVoq
  Is my wooden desk a safe surface to test the cluster board on? ollehar 6 15,299 12-28-2020, 09:41 AM
Last Post: robocone
  Building a new cluster with external storage hvdkooij 2 8,440 11-20-2020, 07:44 AM
Last Post: hvdkooij
  Compatibility between RPi Module and Cluster board leperotero 1 6,196 11-03-2020, 03:40 PM
Last Post: poVoq
  sopine socket power problem cgiraldo 1 5,697 06-17-2020, 02:10 PM
Last Post: cgiraldo
  Is there any way to get a video output from a cluster module? ollehar 4 11,492 06-16-2020, 12:34 PM
Last Post: ollehar
