USB 3 2.5" SATA Case
I've just ordered my Rock64.  I have read on the armbian forums that the USB3 port can max out the Gig NIC which is great.  I was just wondering what USB 3 / 2.5 inch cases to look out for?  Is there a certain chipset I should look out for in the specs?
Thanks.
Ideally you'd want to get a USB 3.0 -> SATA using the JMS578, just like this one offered in the store
I have, however, used a few different USB 3.0 cases and (I feel I may get myself in trouble writing this) I honestly cannot see any difference in performance using a mechanical 2TB HDD. Better you read the tkaiser's post on the subject.
Thanks.
I would like to find a case that I can put my 2.5" SATA HDD in.... There are so many out there. I did see that Armbian thread about the JM578, but hoped there are other chipset that also work well under USB 3.0
  DeskPi case alternative for ROCK64 v1k699 2 11,868 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 3,647 05-13-2025, 07:32 AM
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,036 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 25,653 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 25,153 07-07-2021, 05:50 AM
Last Post: Rocklobster
Heart Best quick/easy way to control case fan speed? idillicah 4 10,813 06-24-2021, 09:14 AM
Last Post: CounterPillow
  USB3 SATA ReleaseTheGeese 2 4,666 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  USB3 to SATA cable - Firmware Eule 0 3,291 03-03-2020, 01:31 PM
Last Post: Eule
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 4,445 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 22,888 07-09-2019, 06:15 AM
Last Post: merwone
