Rock64 as a retro-gaming console: early impressions
#21
I played the same sequence on android. I feel that performance is better on android after all. But this is not a fair comparison since I am comparing two different emulator cores too. Perhaps performance would be even better using a stand-alone Mupen64 emulator on Android --- I won't be testing that however.
As a side-note, new Lakka image (22/10/2017) has been released for those willing to test.
#22
Which emulator do you recommend for PSX1 games for RockBox that supports (BT) keyboard?
Matsu Player is good and fast, but does not support keyboard, only the controllers.
Retroarch is unusable because it does not respond to keyboard and mouse at all.
#23
(11-26-2017, 06:13 AM)Wizzard Wrote: Which emulator do you recommend for PSX1 games for RockBox that supports (BT) keyboard?
I had no issues with my K400 in Retroarch. In general, I have no interest in stand-alone emulators, so don't know which one delivers best performance.
All controllers I tried (3xCheap-o brands, Xbox 360, PS3, Buffalo, 8BitDo) worked fine in Retroarch - so if you have any controller that should work just fine.
Try unplugging and plugging in again the keyboard once Retroarch starts.
#24
I have no controller except my keyboard and replugging does not solve anything.
I really do not understant that, cause all other emulators work.
#25
I see that these tests were originally ran on a Rock64 with 2gb of memory and emmc storage, but would performance be similar with the 1gb version? It seems like emulation is mostly cpu intensive and I thought this soc would be a good candidate since its a bit faster than an Rpi3, at least I think I've read this chip is a quad core at 1.5ghz while the Rpi3 is at 1.2ghz
#26
(12-08-2017, 04:17 AM)wtfindeed Wrote: I see that these tests were originally ran on a Rock64 with 2gb of memory and emmc storage, but would performance be similar with the 1gb version? It seems like emulation is mostly cpu intensive and I thought this soc would be a good candidate since its a bit faster than an Rpi3, at least I think I've read this chip is a quad core at 1.5ghz while the Rpi3 is at 1.2ghz
It will perform on par with the RPI 3 for the most part. I have been playing with many boards recently, and basically unless you have a much more capable CPU/ GPU combination you wont be playing N64 smoothly. What console games do you want to play ?
#27
(01-10-2018, 08:54 AM)Jonnyc Wrote:
(07-12-2017, 03:50 PM)ayufan Wrote: Wow. Amazing. Thanks for testing that Smile
This is my first reply on the forms I have not yet use the forms I have not yet received my device yet but I am a beginner and besides the accessories that you need for the unit to power it and Wifi how where when why can I get a module emmc from affordably I only seen a 60 some gig on their pine website store I don't want that big one I want a cheap one to get started I don't know if I'm going to get into this or not. So I guess what I'm asking is where can I get the storage adapter module and can you put raspberry Lenox on this device and can retropie work on this device therm I mean three questions.  I wood love to speek to someone one on one
 thanks  jonne
for speak to someone one on one, please check out PINE64 IRC at http://pine64.xyz
#28
Just for curiosity is R64 able to handle Dreamcast and GameCube emulation?
Thanks!
#29
(01-18-2018, 04:51 PM)Danielsan Wrote: Just for curiosity is R64 able to handle Dreamcast and GameCube emulation?
Thanks!
Nope. You'd need a rk3399 box for Dreamcast and an Nvidia shield for smooth(ish) GC emulation.
#30
Thanks!
Thanks again, I saw that for rk3399 and the Nvidia Shield we are in another range of price and I am not interested about that, I am fine with my Rock64. I look forward to have the R64 in my hands, eventually I bought a 128gb sd card.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 4,976 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 23,854 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 14,585 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 15,633 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 3,884 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 8,396 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 9,570 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 8,716 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,187 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,271 10-07-2022, 07:50 PM
Last Post: rookie_267
