USB -> eMMC is now available.
The title says it all ... link
How would you install a OS on the eMMC using this? Can you skip the sd card completely? Would love a tutorial.
(11-22-2017, 05:53 AM)Tony32 Wrote: How would you install a OS on the eMMC using this? Can you skip the sd card completely? Would love a tutorial.
just plug in the eMMC in to the USB converter, plug the usb converter in your pc, use Pine64Installer to flash the eMMC Wink
Just DD as you normally would to SD
Thanks for the quick replies! I ordered the Rock64 today. I wonder if its possible to dual boot easily like with NOOBs.
When using the USB-eMMC with PINE64 Installer, should you use the "microSD" or the microSD to eMMC" images?
(02-13-2018, 03:49 PM)GeerGuy Wrote: When using the USB-eMMC with PINE64 Installer, should you use the "microSD" or the microSD to eMMC" images?
MicroSD
Thumbs Down
When I install my new 16GB eMMC into the USB adapter and plug into a USB port I get the following error message:
Location is not available
F:\ is not accessible
Incorrect function.
Using Windows 10.
The red LED is on.
Any ideas?
(02-17-2018, 01:33 AM)GeerGuy Wrote: When I install my new 16GB eMMC into the USB adapter and plug into a USB port I get the following error message:
Incorrect function.
Using Windows 10.
The red LED is on.
Any ideas?
if the eMMC module has not been formatted or format as EXT4, then need to reformat before able to file access under Windows OS environment.
[note] Mostly is EXT4 format due to factory always loaded Android OS for device functional testing.
I used a Linux computer and it worked fine, Thanks
Is it possible to use the USB-eMMC Adapter in Windows?
Even after programming it once with a Linux computer, it still does not show up in Windows.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,751 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 7,134 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,406 08-19-2021, 06:46 PM
Last Post: bcnaz
  Receiving errors about eMMC (?) acasta 11 27,704 09-24-2019, 10:26 PM
Last Post: ridgarou
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 180,720 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 3,936 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 6,401 06-25-2018, 03:20 AM
Last Post: Auggoncalves
  Debian to eMMC? Hoerli 7 15,496 05-06-2018, 05:41 PM
Last Post: pfeerick
  [SOLVED] stuck at emmc dr_dre 10 23,465 04-29-2018, 05:10 PM
Last Post: pfeerick
  eMMC errors MrFawlty 8 14,969 04-02-2018, 09:33 PM
