USB TTL cable no longer working
My serial cable no longer works. It used to work.
I connect it to the Euler connector,
Quote:TX: pin 29
RX: pin 30
GND: pin 34
Then on Linux,
cu -l /dev/ttyUSB0 -s 115200
I do not get any response from "cu".
I tried two such cables. Is it possible that the cables got damaged? What can done to deal with this?
Initially I was worried that I bricked the board. However, I managed to boot an image off the microSD card, that had HDMI output.
Have you tried the UART pins on the EXP port? I guess everything is wired to same place, but maybe there is some issue with a a connector.
(03-09-2016, 12:09 PM)janjwerner Wrote: Have you tried the UART pins on the EXP port? I guess everything is wired to same place, but maybe there is some issue with a a connector.
Better use EXP port for UART console cable. The Euler port UART pin has voltage shifter and Euler port do not.
According pinout there is possible to have 6 UARTS (I plan to test this once I have my PINE64 in hands together with modules based on MAX3232 chip from ebay).
https://drive.google.com/a/pine64.com/fi...sp=sharing
1 of UARTs is on PI bus. I'd try this.
pin6   - GND
pin8   - UART_TXD
pin10 - UART_RXD
But don't know what device file each UART will have.
Try check what device files are there containing "tty" under /dev .
pin6   - GND
pin8   - UART_TXD
pin10 - UART_RXD
Combine both Euler and Pi2 bus, the maximum available UART is 4.
[quote pid='3287' dateline='1457557488']
[/quote]
There is also EXP bus and Wifi/BT Connector (J50). I suppose those would work as well (I won't use wifi/BT modul).
(03-09-2016, 03:09 PM)peterz Wrote: [quote pid='3287' dateline='1457557488']
[/quote]
You plan to max out all UART ports :-)
Thanks for the replies.
I use Ubuntu and the appropriate devices are autocreated in /dev/. The default is /dev/ttyUSB0.
I tried two different UART cables, both with the following characteristics,
[46297.049241] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[46297.178108] usb 1-9: New USB device found, idVendor=067b, idProduct=2303
[46297.178116] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[46297.178121] usb 1-9: Product: USB-Serial Controller
[46297.178124] usb 1-9: Manufacturer: Prolific Technology Inc.
[46298.217991] usbcore: registered new interface driver usbserial
[46298.218005] usbcore: registered new interface driver usbserial_generic
[46298.218015] usbserial: USB Serial support registered for generic
[46298.219383] usbcore: registered new interface driver pl2303
[46298.219397] usbserial: USB Serial support registered for pl2303
[46298.219411] pl2303 1-9:1.0: pl2303 converter detected
[46298.220266] usb 1-9: pl2303 converter now attached to ttyUSB0
I tried both the PINs 6/8/10 (GND, TX, RX) on the Euler connector and also PINs 6/7/8 (GND, TX, RX) on the Exp connector.
I did not get any response at speed 115200.
I cannot figure out what changed so that now I do not get any output from the serial cable.
If a solution is found, I will document the whole process on the wiki!
I dont know anything but try to switch rx and tx?
(03-09-2016, 04:40 PM)longsleep Wrote: I dont know anything but try to switch rx and tx?
My suggestion same as longsleep.
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 42,309 10-07-2017, 10:06 PM
Last Post: speedro86
  How to make multicast working on ubuntu and debian brengthdom 3 10,036 09-18-2016, 02:05 PM
Last Post: brengthdom
  Arch working! c0psrul3 1 4,558 05-01-2016, 08:55 PM
Last Post: Leoncito81
  Actual "working" 64 bit distro UnixOutlaw 2 7,551 03-16-2016, 02:25 PM
Last Post: umiddelb
