I've got a emmc to sd adapter to write image
I don't know why I can only boot once. If I just unplug the power, I cannot boot the second time when I power it on.
I use a Linux image which is called stretch-minimal-rock64-0.4.16-83-arm64.
(08-28-2017, 04:29 PM)fbms Wrote: I don't know why I can only boot once. If I just unplug the power, I cannot boot the second time when I power it on.
Actually, when I boot the board on the second time I have to unplug the HDIM wire and replug it into the board. I don't know it's a problem of my TV ( I use a TV) or it's a problem of the Linux image. Anyway if you meet the same problem just try what I said.
I also use ‘USB image tool’ to write the image. It works great.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,655 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 6,946 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,232 08-19-2021, 06:46 PM
Last Post: bcnaz
  USB3 to Ethernet adapter giuseppe 0 3,232 11-11-2020, 05:48 PM
Last Post: giuseppe
  Download IDB fail when trying to flash Android image cherkasoff 0 8,916 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 27,228 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 48,791 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 177,489 02-06-2019, 04:02 PM
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,622 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 3,852 02-04-2019, 07:36 AM
Last Post: LMM
