Install Atom editor in ubunut mate?
(08-25-2017, 08:47 AM)combs Wrote: It works okay with the armhf setup (exagear is x86 emulation?). Takes 55 seconds to start and become responsive with my pile of windows, tabs, and plug-ins. Timecop looks like a bloodbath, haha.
Typing is maybe a 1/4s lag with lots of syntax highlighting stuff enabled.
Still not the same as a "real computer" but a lot better than it sounds like you're getting with exagear. Just plan on burning like 3 hours to get all the armhf stuff set up.
What OS are you running? Because I use the latest stable 0.6.2 and the performance is horrible. CPU usage is really low (it doesn't even use 15%) but Atom is really slow. 2 second input lag.
I'm running:
Linux pinebook 3.10.105-bsp-1.2-ayufan-77 #1 SMP PREEMPT Sun Jul 9 12:09:30 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
You mentioned using ExaGear, which is a totally different method (and much slower)
So no atom, no VS Studio Code (just doesn't work), no sublime... I get a lot of problems working with this thing properly. Even the typing is hard with the space key randomly not registering properly.
So what else could I use on it to code?
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,924 07-13-2023, 05:43 PM
Last Post: acruhl
  can't install a new OS with sd card. pinebook1080. ObviousHobbit 3 7,616 07-24-2019, 07:52 AM
Last Post: neilman
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 3,555 06-11-2019, 01:36 PM
Last Post: k_mp
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 24,498 05-01-2019, 12:09 PM
Last Post: frank-zappa
  Install OS to LUKS tahf 1 5,735 01-20-2019, 12:47 PM
Last Post: Blutkoete
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 16,111 12-02-2018, 05:37 AM
Last Post: mikee3000
  KDE Install on new Pinebook, howto? Corkonian 8 18,042 11-08-2018, 02:11 PM
Last Post: Luke
  Problems to install qemu on Xenial Mate (for EMMC) demian 1 5,512 03-14-2018, 08:43 AM
Last Post: xalius
  New pinebook owner, media playback how? (was: larger eMMC, what and how to install?) dahni 14 35,340 09-14-2017, 12:04 AM
Last Post: dahni
  Install pygame in Ubuntu Mate pkgAstronaut 2 7,000 08-31-2017, 10:39 PM
Last Post: pkgAstronaut
