Pine A64+ 2GB can´t boot
I bought this board at the beginning from kickstarter, but I can´t find time to test it until now.
The problem is that the board can´t boot (I test with Android and linux) and if I connect to the serial console using PINE64 USB SERIAL CONSOLE/PROGRAMMER I get this:
HELLO! BOOT0 is starting!
boot0 commit : 8
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM driver version: V1.0
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 552 MHz
DRAM zq value: 003b3bbb
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1500 mv
DRAM DQS gate training error
DRAM init error!
initializing SDRAM Fail.
¿It's a hardware problem o can I solve it?
I have an open ticket in support platform, but I have not any respone.
Thanks in advance,
Fernando
Moin moin,
what image are you trying to boot? Are you using a power supply that can deliver 2.5A+ at 5V?
I tried android 6 from ayufan and Debian Base 3.10.65 BSP.
And yes, I use a power supply that can deliver 3.0A at 5V
(03-28-2017, 03:37 AM)xalius Wrote: Moin moin,
Enviado desde mi LG-D802 mediante Tapatalk
Try the troubleshooting steps.
It will be easier to determine whats causing the issue.
Edit: the debian image you've used is very outdated. If you need debian then please try Armbians variant ... you can also use ubuntu base
(03-29-2017, 05:27 AM)Luke Wrote: Try the troubleshooting steps.
I had review the troubleshootings steps with no luck:
  • Tried several Cards
  • Tried several images
  • Make the images from Windows and Linux
  • Test power supply
  • Deatach all but power supply and SD Card
I have seen that in the first versions of the board there were problems with the SDRAM, and it appear very similar as my problem (DRAM DQS gate training error), that is why I ask for others things that can cause that error .
I would be grateful if someone from Pine64 support would tell me how to proceed with a replacement board.
  Pine a64+ power supply davidspencer 0 1,969 03-18-2026, 01:02 AM
Last Post: davidspencer
  Pine A64+ lost 7" screen functionality after kernel 6.1 Learnincurve 0 1,446 12-10-2025, 09:03 AM
Last Post: Learnincurve
  Pine 64 installer OS list blank spamsucks 1 13,088 04-08-2025, 08:16 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 6,623 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 3,636 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 10,837 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,037 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 7,887 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 8,155 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 13,229 12-06-2020, 03:53 PM
Last Post: junkyj753
