Linux gkrellm launch
Video
I like to use Gkrellm2 on linux Desktop, the one plugin I use the most is gkrellmlaunch, it allows me to get everything done from a simple light weight interface. However, it is never included in distributions, I will attach same for access.
Here is a little script I fire from launch.
#!/bin/bash
# updater designed to keep system at latest state & clean
echo 'The following will be completed, Autoremove will require response.'
echo
echo 'Update, Upgrade, Dist-Upgrade, Autoremove and Clean'
echo
read -n1 -r -p "Press SPACE to continue or Ctrl+C to exit ... " key
echo
if [ "$key" = '' ]; then
   echo "Continuing ..."
fi
echo
sudo apt-get update && sudo apt-get -y upgrade && sudo apt-get -y dist-upgrade && sudo apt-get autoremove && sudo apt-get clean
echo 'Have a nice day!'
.gz   gkrellmlaunch.so.tar.gz (Size: 31.15 KB / Downloads: 767)
It looks like gkrellmlaunch.so failed to upload. I will pack it and try again.
jhawk
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,335 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 95,593 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,174 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,633 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 72,423 01-28-2019, 11:05 PM
Last Post: necrose99
  Real-time linux kernel Artyom 45 123,275 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 10,323 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 9,111 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 6,653 08-03-2017, 10:05 PM
Last Post: pfeerick
  Can I run Alpine Linux on Pine64? douglasmiranda 3 12,342 08-01-2017, 07:20 AM
Last Post: cztian
