Windows 10 IoT finally released on Pine A64 platform
#21
(08-04-2016, 07:27 PM)tllim Wrote: The Pine A64 already passed the Windows 10 Azure IoT certification: https://azure.microsoft.com/en-us/docume...gurations/
For the Pine A64 Windoiws IoT installation process, please refer to https://github.com/Azure/azure-iot-sdks/...-csharp.md
For the Pine A64 Window IoT code, please download from Pine64 file server: http://files.pine64.org/os/win10-iot/Win...Pine64.ffu
For developer that interest on the Pine A64 Windows IoT SDK, please stays tune. We will release the UEFI source code and Win10 BSP SDK package in few weeks time Smile
Links for azure  and  github not working. Code link downloads.
Save
#22
Hi all,
Using windows10IoT_pine64_RS1_20161121.ffu (OS Version: 10.0.14393.0), cant seem to get it to boot with WiFi/Bt module, BSOD every time.
Remove the module and it starts up fine.
Windows Update installs: 10.0.10595
and then when rebooting, it just hangs.
This is what I get on the console.
��%���5jR�AXP NumberOfHandles = 1                 �U͉ɂJ�с�QIQ�"""jԤ�5�!�����
open hci clock usbc_no:1, is_ohci:1
parser fetch usbc1 usb_drv_vbus_gpio failed
Loading driver�SunxiEthDxeEntryPoint: phy mode = rgmii
gmac_rgmii_select
Loading drive�no key pressed
Sunxi BootCmd = boot-normal
Loading drive�Loading�Loading dr�Loading d�Loading driver at �Loading driv�Loading drive�[PWM Msg]:request pwm success,pwm-base=0x0, pwm_number=1,pwm = 16.
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
[Disp Msg]:board_display_device_open_lcd
[Disp Msg]:boot_disp.output_mode=4
[Disp Msg]:disp0 device type(0) enable
lcd_panel_fun[0].cfg_open_flow is NULL
enable power vcc-dsi-33, ret=0
disp_sys_register_irq, irqNo=121, Handler=0xBE592F09, pArg=0xBE316810
lcd_panel_fun[0].cfg_panel_info is NULL
disp 0, clk: pll(330000000),clk(330000000),dclk(55000000) dsi_rate(55000000)
    clk real:pll(330000000),clk(330000000),dclk(82500000) dsi_rate(148500000)
[Disp Msg]:board_display_device_open_hdmi
[Disp Msg]:disp1 device type(0) enable
attched ok, mgr1<-->device0, type=4, mode=4
disp_sys_register_irq, irqNo=119, Handler=0xBE5989E5, pArg=0xBE316610
plugin
[Disp Error]:fetch script data boot_disp.output_full fail
[Disp Msg]:screen_id =1, screen_width =1280, screen_height =720
[Disp Msg]:frame buffer address BF000000
[Disp Msg]:bitcount = 32
[Disp Msg]:screen_id =0, screen_width =1024, screen_height =600
Loading driver a�Loading driver �Loading driver at 0x�Loading drive�Loading dri�Loading driver�Loading driver at 0x000BE1AF000 EntryPoint=0x000BE1B26A1 Fat.efi
Loading driv�Driver CB933912-DF8F-4305-B1F9-7B44FA11395C was discovered but not load�+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+L[���M[�+ML[�+L[���Sk�E�jمɥ
������꽽ѵr�ɵ��5jRT����݁��с������5jR�Loading driver�ACPI: LoadAcpiFromVolume() failed to open directory
ACPI: Loading ArmBgrt.acpi
read file is NULL
read file is NULL
ACPI: Loading ArmCsrt.acpi
ACPI: Loading ArmDbg2.acpi
ACPI: Loading ArmDsdt.aml
ACPI: Loading ArmFacp.acpi
ACPI: Loading ArmGtdt.acpi
ACPI: Loading ArmMadt.acpi
ACPI: Loaded 7 tables
Install ACPI table by partition file success
no battery exist
read file is NULL
read file is NULL
read file is NULL
Read Logo file Fail, Please Check file exist
show Bootlogo error: Unsupported
  PEI    644 ms
  DXE   1577 ms
  BDS    333 ms
Total Time = 2554 ms
try removeable media boot
Any ideas what is wrong?
Cheers
-Anders
#23
(02-06-2017, 08:35 AM)carlberg Wrote: Hi all,
I have reported the exact same problem. Unfortunately sofar
no one has reported or followed up since.
if anyone with the right sources could help out is very much appreciated.
Mod Edit: Post restored - was not a duplicate
#24
hi , I removed the duplicate (very lengthy post) and edited the last post with a code block.
Please keep lengthy log posts or code within a code block for other user's readability.
Thanks.
Wink
#25
That was my post which you removed...
In short, I already reported earlier the same as carlberg's findings: WiFi + BT add-on causes crash of PINE64 on boot. Just bumping this thread up to confirm his finding.
Only, seems to me we're shouting into a void here... or is there progress of any kind on Windows IoT for PINE64?
#26
quisiera saber si a alguien le funciona el sistema operativo de w10 iot en la pine64+ 2gb..
No me arranca a mi , el archivo .ffu no me sirve...no es autoarrancable..
gracias espero sus respuesta ...saludos desde latinoamerica..
I would like to know if someone works on the w10 IoT operating system on the pine64 + 2gb ..
It does not boot me, the .ffu file is not useful ... it is not self-extracting ..
Thank you, I hope your answers ... Greetings from Latin America ...
  Windows 10 IoT Enterprise? roybridge 1 20,500 03-06-2019, 02:42 PM
  Windows IoT BSP dvescovi 16 42,435 09-02-2018, 06:35 PM
Sad Windows 10 iot ffu lawrencejd 1 8,098 07-19-2018, 10:40 PM
Last Post: KNERD
  Win10 IoT (PINE A64(+)) 10.0.15063.0_20170602 pineadmin 30 75,339 05-18-2018, 07:05 AM
Last Post: dkryder
  +LTS/SOPINE Can Win10 IOT be used on PINE A64-LTS? uart 1 7,410 03-09-2018, 11:25 PM
  unable to deploy my application to the Pine using Visual Studio 2017 Matthew 9 22,000 03-08-2018, 04:20 AM
Last Post: zio69
  Will Windows 10 work with the new Rock board? WhiskerBiscuit 2 9,798 09-03-2017, 07:22 PM
  Windows 10 and .Net Core running for a day hugob 2 10,437 08-23-2017, 11:17 AM
Last Post: hugob
Star Windows IoT BSP on Github!!!! Add UEFI src code! Leeway213 5 17,665 06-25-2017, 07:42 PM
Last Post: Leeway213
  Pine 64 on 512MB embedder 3 12,109 12-19-2016, 07:56 PM
Last Post: Toriless
