LINUX Distribution for the newbie
greetings,
I am a complete novice in computing_and for the longest time I detested the linux way of doing things by typing (no offence meant). Now I do want to learn both linux & the arm processors. I would like to start on an accessible distribution that will allow me to do my c programming & compilation, if I ever get even that far.
There is no reason to spend any time to answer this rudimentary question--I did try to find answers to no avail, if anybody could drop a hint I would be greateful.
Regards,
_mgd
Hi
I think that you may want to start with the base image of ubuntu. I would suggest you don't give in to the urge to install a desktop environment at first and just have fun becoming familiar with the CLI (command line). There are many good introductory series on youtube. That said, you can install a desktop environment called Mate running this command:
sudo /usr/local/sbin/install_mate_desktop.sh
It may take a long time to install (dependently on your internet connection speed).
This is just one of the choices you are given - you can find most of the available OS' images here.
Hope this helps.
(12-08-2016, 10:33 AM)Luke Wrote: Thanks Luke. I'll give it a try. Any idea how I could mark this thread as inactive to save peoples' time? (I searched around--no luck).
Regards,
m.
Hi
Hope this helps.
I could delete it or lock it, but I really see no point in doing so unless you insists. Perhaps you'll have further questions or someone else other opinions to offer .... you never know. I suggest we leave it as is.
Have fun exploring Linux. If you have more immediate questions you are always welcome to drop by and chat with me/ us live (see my sig).
A hearty thanks, Luke. You eased my mind on both scores.
Mike
I too am a newb and ive tried nearly every image, and by far have had the best luck with opensuse, I made a mini howto in the newbie area.
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,534 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 96,544 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,373 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,798 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 73,312 01-28-2019, 11:05 PM
Last Post: necrose99
  Real-time linux kernel Artyom 45 124,956 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 10,419 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 9,213 01-30-2018, 10:26 AM
Last Post: Rustproof
  +PINEBOOK: Newbie Trying to Compile RStudio On Pinebook MiningBrutus 3 9,707 08-12-2017, 04:55 PM
Last Post: MarkHaysHarris777
  eta linux image?? firosiro 1 6,750 08-03-2017, 10:05 PM
Last Post: pfeerick
