Howto: Getting Bluetooth (serial console) working on Debian
(12-01-2016, 09:06 PM)pfeerick Wrote: hm... on the Debian Mate build, Lenny had already set up all the Bluetooth stuff out of the box... IIRC, there was just a single command you needed to run, and that was the last bit of info in the readme that was on the desktop. I'll see if I still have the image on a card, and see what the command was.
Yes, it appears that way to me as well. There is the BT icon on the top panel of Mate with a drop down menu. I clicked around on a few of the menu items when I first set things up, and it appeared to not really do anything. Since I didn't have any BT devices I wanted to use at the time I didn't pursue it, as I assumed it needed further attention to enable it, when the time came (now) .
It is entirely possible that I overlooked a readme somewhere, but I don't recall seeing anything like that on the desktop.
(12-02-2016, 03:58 AM)HayseedGeek Wrote: Yes, it appears that way to me as well. There is the BT icon on the top panel of Mate with a drop down menu. I clicked around on a few of the menu items when I first set things up, and it appeared to not really do anything. Since I didn't have any BT devices I wanted to use at the time I didn't pursue it, as I assumed it needed further attention to enable it, when the time came (now) .
I'm afraid you did... or deleted it! :-O
Anyway, the pertinent bit was:
Quote:For those of you who have the bluetooth/wifi module
please active the Bluetooth Service via terminal by
executing the following
sudo -i
systemctl enable bluetooth-module.service
reboot
(12-02-2016, 04:16 AM)pfeerick Wrote: I'm afraid you did... or deleted it! :-O
sudo -i
reboot
A rather significant miss on my part. Blush  Thanks for the point in the right direction.
(12-02-2016, 01:03 PM)HayseedGeek Wrote: A rather significant miss on my part. Blush  Thanks for the point in the right direction.
Don't thank me until you say it works... I could be leading you down the garden path!! Tongue Dodgy  Please let me know if it works! Smile
Maybe this is a bit outdated, but i'll give it a try.
I have installed the Bt and while the service is running i get the message:
#power on
No default controller availlable. <--------- ??
#agent on
Agent registered
#default-agent
Default agent request successful
I do see a blue Bt icon but can't connect to any device.
  Wifi / Bluetooth Board Update S265 2 6,963 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,224 03-10-2019, 01:02 AM
Last Post: waqasnasir
  RTL8723bs Bluetooth xalius 21 48,884 03-22-2017, 04:53 PM
Last Post: JulianM
  WIFI & Bluetooth? 7777777 14 39,881 12-24-2016, 05:01 AM
Last Post: Toriless
  Using Bluetooth for Sending serial data Arjun 9 21,967 10-19-2016, 10:19 PM
Last Post: Arjun
  How can you get the WIFI/Bluetooth module separate? GoZone 8 16,994 07-06-2016, 05:23 PM
Last Post: JasperBrown
  WiFi/BT module, no bluetooth riviera89 5 11,079 06-24-2016, 04:32 PM
Last Post: srinivas.s34@gmail.com
  Board doesn't boot when wifi/Bluetooth connected with Lcd screen Krinilssen 4 10,841 06-16-2016, 07:22 AM
Last Post: Krinilssen
  WIFI/Bluetooth Chipset monmoonmooonmoooon 2 7,666 01-20-2016, 06:02 AM
Last Post: monmoonmooonmoooon
