Received a bad LCD, can't get support.
So, I received a bad LCD.  The cable on the back of the LCD arrived with a small tear in it.  I've tried over and over to get support from pine64 staff with about a half dozen emails, and support tickets but haven't gotten any help.  Does anyone know if I can easily replace the cable myself?  I really want to use my LCD and am fairly sure I'll never get support from pine64 to get it fixed.
Thanks!
(09-26-2016, 12:28 PM)bryanlyon Wrote: Does anyone know if I can easily replace the cable myself?
If you had the equipment and skillset to do this, you wouldn't be asking- so absolutely not. And good luck finding any computer or cellphone repair shop that will even consider taking the job, believe me, I tried everyone in town when I tore the cable on my original LCD screen trying to get it set up.
has anyone taken the aluminum panel on the back of the lcd off? i'm thinking there might be a connector underneath that would give a point to replace the cable?
I presume you have already emailed support ? You can also drop tllim a PM - support can be slow to repsond
Information LCD Support on Linux pfeerick 8 28,133 02-08-2021, 03:30 PM
Last Post: HBeserra
  Linux Support UnixOutlaw 69 147,452 03-18-2017, 07:25 PM
Last Post: apple4ever
  Touch screen support shariq_2001 14 32,913 12-07-2016, 07:47 AM
Last Post: Luke
  Touchscreen support? NoahJ 12 26,059 07-09-2016, 12:01 PM
Last Post: yodermk
  LVDS support Flood_of_SYNs 2 10,044 12-22-2015, 05:08 PM
Last Post: balornt
