Touchscreen display mods
Hello all,
I'm looking for some answers you may be able to help me with. I have a screen from a Kindle Fire HD7 and curious whether or not it can be adapted for use with my Pine+?
I also have a smaller non touchscreen LCD from an old baby monitor that I would like to try.
Any help would be most appreciated!
No
Unfortunatley, unless you are really, really lucky that one of those dispays has a compatiable LCD controller, there is little chance of it working with the pine64. Running character displays like a 16x2 LCD are pretty easy, as they are pretty simple, and there are a lot of guides on using them. Due to the complexity of colur displays (such as the Kindle one) (ie. having to controll every pixel individualy, specifying colour, intenity etc,), and not knowing the protocol that a particular display controller might use, or even the pinout order of the ribbon cable (which you can't bypass if it uses a on-ribbon controller IC, it will be hard at best to get the display to do anything, let alone anything useful. The guys are pine64 did the hard work of matching a display wwith the pine64 and setting up the necessary code to get it working in a plug an play manner, hiding the complexity of the software interface and connection from us users! Big Grin
  Search Compatible 10.1" touchscreen alfredo78 0 3,486 07-06-2018, 03:48 AM
Last Post: alfredo78
  Larger LCD touchscreen stephen fleming 3 7,513 06-13-2017, 03:16 AM
Last Post: mbt28
  Armbian display manager issues modsbyus 0 4,437 02-08-2017, 06:18 PM
Last Post: modsbyus
  8inch display compatible to FY07024DI26A30-D mbt28 0 3,619 01-26-2017, 10:07 AM
Last Post: mbt28
  lcd and hdmi dual display jodybrown99 8 18,032 11-12-2016, 08:07 PM
Last Post: Chisel_86
  Trouble with LCD display jdmwrx94 3 7,797 07-25-2016, 12:21 PM
  Touchscreen support? NoahJ 12 24,604 07-09-2016, 12:01 PM
Last Post: yodermk
  Large multi touch touchscreen for P64? vedranius 5 11,719 05-20-2016, 09:43 PM
Bug Raspberry Pi 7" Touchscreen Display not work? Paara 2 8,321 05-05-2016, 08:47 AM
  Touchscreen monitor to use lefartenshisten 1 5,448 04-30-2016, 10:47 PM
Last Post: MichaelMeissner
