USB Audio?
Does anyone know if USB Audio works with the Android OS? I have a Logitech G930 headset I would like to connect to the Pine. My wireless keyboard and mouse worked as soon as they were plugged in, but the headset's not working. I've seen that people using Samsung Phones have gotten it to work using an OTG connectors. Is there some sort of audio input setting in the OS?
With the headset plugged in; do you see anything in audio settings that might help...
I can attest that USB DACs work on Android with USB Audio player PRO.
I tested Audioquest DF and Schiit Modi and work like a charm.
However, I haven't found a way to use them as audio interfaces. There is no such option under Audio Settings.
Needs to be enabled in the kernel. I've enabled it before but had issues with sound not coming out of headphone jack. Can load the module manually of course.
Backer #6878
shipment status: arrived
  3,5mm audio out not working MikkoL 9 22,791 11-22-2020, 06:42 AM
Last Post: Little_Johnny
  Android audio Danbrack 0 3,509 03-24-2018, 10:51 PM
Last Post: Danbrack
  <•••> and no audio on my android is Help PoppaLeague 0 3,253 09-10-2017, 01:32 AM
Last Post: PoppaLeague
  Microphone / Audio In iammackinnon 4 10,053 04-24-2017, 07:03 AM
Last Post: kenjiru
  Android 6.0 TV analog audio Ophir 2 7,650 02-02-2017, 03:55 PM
Last Post: Ophir
Information Audio Passthrough in SPMC Working czechr08 8 27,188 11-02-2016, 06:54 PM
Last Post: czechr08
  USB audio g_t_j 9 18,257 08-21-2016, 10:20 AM
Last Post: lifeke
  Passthrough Audio Netflix and Plex Android User 4127 10 20,470 07-26-2016, 12:01 PM
Last Post: CaptainZalo
  Audio from Headphone Jack and Camera Issue cybernak 1 5,326 05-23-2016, 11:02 AM
