Happy/Sad. Pine64 arrived; DSI connector damaged
Sad
Hi
I was very excited to finally receive my Pine64 today. I immediately set to work connecting the touch panel -> adapter board  -> connector cable, and then DISASTER! The DSI connector on my board is completely missing the plastic clip  Cry
Edit:
Is this fixable without having to return the board?
How can I get hold of a plastic clip and attempt a repair?
Looks like a couple of the pins are damaged as well, so it's not just the plastic clip. I
Edit 2:
I have attached the best pic I've been able to take. You can see the pins on the right look deformed.
Devastated :-(
(06-21-2016, 05:50 AM)Switchblade Wrote: Hi
Edit:
Edit 2:
Devastated :-(
When you get a lemon... make lemonade !
... make sure you don't have any shorts in that connector (you'll probably need a glass)
Use that board as a PC, and order a new board.
If you are VERY careful, you might be able to pull the connector off with a heat gun... get a new connector from digikey, and then replace it...
... but that's a risk.
  Didn't receive phone, no response from Pine64 at all rn43x 8 17,790 09-11-2021, 01:29 PM
Last Post: hacker
  New to Pine64: should I have expected a tracking number by now? Indieshack 2 7,587 06-19-2020, 03:44 PM
Last Post: Indieshack
  Earth to Pine64, please respond! EvanBeem 43 79,344 02-01-2017, 09:26 PM
  Pine64 sales are useless panoflex 1 5,819 09-22-2016, 06:06 PM
Last Post: pfeerick
  Pine64 2gb + stuff for sale or trade Caleb420 0 4,162 09-22-2016, 01:46 AM
Last Post: Caleb420
  Not Received Any Pine64 maheshsutariya 16 32,399 09-14-2016, 06:15 PM
  PINE64 ABS Playbox Enclosure be available for sale in the shop danlcarr 3 8,727 08-31-2016, 09:28 PM
Last Post: clocey
  Pine64 FS or Trade? birdcatx7 6 13,974 08-29-2016, 01:53 PM
Last Post: MarkHaysHarris777
  Kickstarter Items Recieved Damaged dicecca112 14 29,144 07-27-2016, 11:58 AM
Last Post: dicecca112
Exclamation Got your PINE64 board yet? Post here! shockr 261 432,867 07-27-2016, 12:48 AM
Last Post: vinodmenon80
