Firmware update only did partial upgrade?
I have a PinePhone Manjaro Edition and it's working alright with PostmarketOS, but I do have some issues with SMS, particularly larger messages getting "jammed" and not receiving, until I manually delete them from the queue, wait some amount of time (sometimes even a day) and it will start working again. I thought this might be some modem firmware issue as I am running a very old version.
The original modem firmware was EG25GGBR07A08M2G_01.001.01.001
I tried updating to 01.002.01.002 with the fastboot command, but it only seems to have half worked, or something.
I used the information here: https://github.com/the-modem-distro/pine...LASHING.md
I got a message like this with a warning:
~/Downloads $ fastboot flash modem NON-HLOS.ubi && fastboot reboot
Warning: skip copying modem image avb footer (modem partition size: 0, modem image size: 41025536).
Sending 'modem' (40064 KB)                        OKAY [  1.281s]
Writing 'modem'                                    OKAY [ 12.747s]
Finished. Total time: 14.051s
Rebooting                                          OKAY [  0.018s]
Finished. Total time: 0.073s
When the modem rebooted, the version number was not 01.002.01.002, but 01.002.01.001 instead.
I tried upgrading to 01.003.01.003 and it's the same problem.
The given echo command to set the modem into fastboot did not work for me, I get an error that /dev/ttyUSB2 could not be created:
/bin/ash: can't create /dev/ttyUSB2: Permission denied
I used the following instead:
~ $ echo "AT+QFASTBOOT" | sudo atinout
- /dev/ttyUSB2 - > ./fboot.txt
doas (user@pine64-pinephone) password:
EOF from modem
Does anyone know what to do? Thanks!
(09-25-2026, 06:02 PM)Agent24 Wrote: I have a PinePhone Manjaro Edition and it's working alright with PostmarketOS, but I do have some issues with SMS, particularly larger messages getting "jammed" and not receiving, until I manually delete them from the queue, wait some amount of time (sometimes even a day) and it will start working again. I thought this might be some modem firmware issue as I am running a very old version.
You did not need atinout for this.
It seems you did the job as normal user, but must open a root terminal (sudo su) before fastboot ....
I think I've figured it out - I found the recovery script here:
https://github.com/Biktorgj/quectel_eg25...flashstock
Which shows flashing individual modules of the firmware.
#!/bin/sh
echo "Sending AT+QFASTBOOT..."
sudo sh -c 'echo -ne "AT+QFASTBOOT\r" > /dev/ttyUSB2'
echo "Sending OEM STAY in case the custom bootloader is installed"
fastboot oem stay
echo "Waiting to settle..."
sleep 2
echo "Start flashing!"
fastboot flash aboot update/appsboot.mbn || exit "Failed to flash the bootloader"
fastboot flash:raw boot update/mdm9607-boot.img || exit "Failed to flash main kernel"
fastboot flash:raw recovery update/mdm9607-boot.img || exit "Failed to flash recovery kernel"
fastboot flash system update/mdm9607-sysfs.ubi || exit "Failed to flash the system partition"
fastboot flash recoveryfs update/mdm9607-recovery.ubi || exit "Failed to flash the recovery partition"
fastboot flash modem update/NON-HLOS.ubi || exit "Failed to flash ADSP firmware"
fastboot reboot
echo "Done!"
Again, the command to set the modem into flashing mode didn't work, so I used the other one, and manually ran each flashing command.
The firmware version string reported by the modem is now as expected: 01.003.01.003
Time will tell if it has made any difference to the SMS receive issue...
(09-26-2026, 08:15 AM)Gumur Wrote: You did not need atinout for this.
Ahh thanks, I will try it next time.
Sorry I did not notice you had replied, I didn't get a notification email...
But I think the real problem was that first command was only flashing one part/module of the firmware, not the whole thing?
  eMMC upgrade EuvzO8 5 7,427 11-08-2023, 11:58 PM
Last Post: brken
  firmware udate Quectel EG25-G modem alwi 7 15,536 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 8,268 07-06-2022, 12:35 PM
  camera firmware problems kqlnut 25 42,918 09-02-2021, 07:49 PM
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 3,237 06-22-2021, 10:03 AM
  WIFI not available after anx7688 update failure frimmel 21 36,465 05-11-2021, 02:45 AM
Last Post: frimmel
  Fail safe way to update ANX7688 firmware scholbert 24 45,885 04-01-2021, 01:28 PM
Last Post: zborgerd
  Pinephone mainboard v1.2 documentation update? scholbert 1 4,995 01-18-2021, 09:01 PM
Last Post: bokomaru
  New motherboard - ANX firmware won't flash. --- 17 26,282 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  Update to 3GB/32GB mainboard not working tlo 2 6,719 11-09-2020, 04:40 PM
Last Post: tlo
