Printing and scanning documents with pinephone?
I want to print and scan papers from a pinephone pro. I know they are linux machines, but can they handel this? I have epson and brother gear.
I don't want to connect through the network and Internet, but through usb or wifi direct.
Thanks.
(06-28-2025, 01:31 AM)Www Wrote: Printing and scanning documents with pinephone?
Thanks.
Yes it works just like any other Linux computer. I use it with Epson ET-something and just works tm.
Thanks.
scanning the current camera stuff works but the missing libs to convert to an image file currently crash the camera app, scour the forum and I recall there was a post for hand-loading the libs.
Thanks.
Thanks. So there is gui software to scan from a scanner. What os and software do you suggest?
Thanks.
Thanks.  Handy to know the camera fails.  I'm trying to hook up a usb printer scanner when need be without going through a second system?
Thanks.
Thanks.
if the printer scanner is in the mainline kernel you should be golden ie if it already works in Debian...
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 999 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 1,804 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 6,075 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 16,885 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,040 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 3,121 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 5,300 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,704 06-29-2025, 02:46 PM
  FM? A future new PinePhone? jebez 1 2,485 06-26-2025, 11:47 AM
Last Post: zetabeta
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 16,474 03-13-2025, 08:40 PM
Last Post: pcb
