New pinetab2 - can't charge it
(02-20-2025, 12:33 AM)biketool Wrote:
(02-19-2025, 08:33 AM)tmhorne Wrote:
(02-19-2025, 06:57 AM)biketool Wrote:
(02-18-2025, 07:30 AM)tmhorne Wrote:
(02-17-2025, 12:36 PM)biketool Wrote: I am sure you have tried this, but do you have another USB-C cable to try?
(edit) and if you plug it into a Linux machine does it show up on lsusb?
(edit2) Since the keyboard/case interfaces via a USB docking port can you try removing the case?
Yes, I have tried a different cable and also a different adapter. Same result.
Plugging the tablet into another linux machine to see if it shows up on lsusb? No, I have not. I can try that when I get home from work this afternoon.
Another data point: I played with it last night until the battery died. Then I plugged it in and went to bed and it charged up to 20% overnight. If I look at the battery graph, though, it doesn't look like it charged. Maybe it was just hot when it said 0% and shut down? The graph says it went down to 20 and stayed there. There's definitely something wrong.
Keyboard/case:
I plugged it in with a new adapter and cord that I know work elsewhere. Nothing.
I just removed it from the keyboard/case and plugged it in and it started charging and it even made a "brrring" sound.
I removed the cable, put it back in the case, then re-plugged it in and it started charging. While in the case, it did not make the sound.
So I'm at a total loss. There's definitely a short somewhere and I don't think it's the cable.
the kb case works though? lights up, types, and moves cursor?
I wonder if the other 20% overnight charge is a backup flat battery slow charge mode, have to look at the charge controller data sheet.
Yeah, the keyboard and mouse work when I have it positioned correctly.
I have to make sure it's pushed back all the way and it works.
After I followed your advice and removed it from the keyboard case yesterday, it charged fully in just under 4 hours.
I'll run it down a bit and try to charge it again tonight.
I wonder if the KB forces aUSB 2.1 mode which turns out to be a slow charge I have not really naticed a difference on my pinetab2.
I can't charge it again.
I think the battery drained fully and since it doesn't charge while it's not powered on, I'm stuck.
It can't power on because the battery is dead.
I can't charge the battery because I can't power it on.
Maybe I can disassemble the device, then manually charge the battery a little somehow?
It's not 3 months old and it's a brick.
  Castle Game Engine on PineTab2 now officially available michalis 3 4,488 02-24-2026, 04:39 PM
Last Post: michalis
  No updates on pinetab2 arch danctnix? Ingen 8 4,504 10-16-2025, 02:57 AM
Last Post: TcCoy
  Libre Office on Pinetab2? Anonymous1989 1 1,782 08-07-2025, 09:50 PM
  Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card Bart 4 6,962 05-31-2025, 02:34 PM
Last Post: stevepaesani
  PInetab2, Limit battery charge to less than 100%? rqkeating 0 2,478 06-30-2024, 08:54 PM
Last Post: rqkeating
  New PineTab2 dRateNWAytORy 2 4,571 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 2,486 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 4,375 02-24-2024, 07:14 PM
Last Post: jkboyd
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 3,504 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 6,468 09-25-2023, 08:29 PM
Last Post: bluemage
