Upgrade to Mobian (Trixie) Staging
Does apt installing  millipixels  make the pro camera work for you?
(11-27-2024, 05:05 AM)biketool Wrote: This is my /etc/apt/sources.list (I added a #commented out my added staging line until ready to use)
deb http://ftp.debian.org/debian trixie main non-free-firmware
#deb http://ftp.debian.org/debian staging main non-free-firmware
You are missing trixie security repo. How to securely and anonymously upgrade to trixie  over tor https://forum.pine64.org/showthread.php?...#pid123596
(12-04-2024, 06:44 PM)vusra Wrote: Does apt installing  millipixels  make the pro camera work for you?
Thanks (extra thanks for TOR method vs clearnet), it has been over a decade since I have had to be good at tweaking apt sources, switch main to staging or trixie to staging to select that repo?
https://www.debian.org/releases/
If  apt sources targets  testing  it will always be  2 5 or 10 days behind unstable.  If apt sources targets trixie, it will be the same as testing until trixie is released in half a year. Once trixie is released, it will become the new stable.
https://wiki.debian.org/DebianTesting
I ended up in a no-boot situation today so I turned on tow-boot to blue light special and dl'ed my /home.
installed the weekly from https://images.mobian.org/rockchip/installer/weekly/
installed my apps and restored my /home over tow-boot USB disk access mode and I am back.
the UI is a bit cruder than trixie but I have a camera now so that is good.
Phone audio is better than normal, welcome sid/unstable nice to know you!
  Mobian MMS/SMS text problem bcnaz 16 37,252 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,441 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 64,553 12-24-2025, 12:11 AM
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,040 12-23-2025, 04:34 AM
  camera not usable with trixie? JChdeL 0 940 12-05-2025, 01:45 AM
Last Post: JChdeL
  trixie update poll questions suggestions j_s 5 2,570 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 71,265 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,196 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 335,129 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 2,887 06-15-2025, 04:19 PM
Last Post: j_s
