bookworm vs trixie discussion for mobian in pinephone regular.
#31
(09-16-2024, 04:27 AM)anonymous Wrote: Someone who uses a Pinephone Pro daily told me a few days ago that he has been able to send and receive MMS flawlessly for months despite the use of multiple APNs. Is it possible with Trixie but on a Pinephone (i.e not a Pinephone Pro) too?
i somewhat recently tested mms messages, and they worked. however, there was a catch, it was related to apn addresses somehow, i don't remember specifics.
tested phones and os's:
pp pro with archlinux, danct.
pp reg with mobian trixie.
Exclamation
Does your mobile operator use 2 distinct Access Point Names for the Internet and MMS?
By the way, I still get freezes and crashes when playing music even in command line with "play".
(09-19-2024, 05:10 AM)anonymous Wrote: Does your mobile operator use 2 distinct Access Point Names for the Internet and MMS?
yes, and maybe the catch was that you use mms settings' apn into internet connection's apn. of course, this will disable internet.
(09-19-2024, 05:10 AM)anonymous Wrote: By the way, I still get freezes and crashes when playing music even in command line with "play".
it sounds like something is messed up in a sound system. mobian uses wireplumber, but that could be messed up.
following command lists available audio interfaces, some work better than others. i don't know what "play" uses as a default.
mpv --ao=help
Actually, I can receive MMS by choosing the MMS APN.
The "mpv" command isn't found Confused The same music file occasionally hangs, I haven't found the culprit.
(09-19-2024, 02:43 PM)anonymous Wrote: The "mpv" command isn't found Confused The same music file occasionally hangs, I haven't found the culprit.
mpv needs to be installed first. maybe in gui, aptitude or apt-get. update system before.
# install something in mobian
sudo apt-get install mpv
keep in mind that mpv does not fix the issue, you just have some options to troubleshoot slightly better.
Now it prints the available audio outputs, i.e pipewire, pulse, alsa, jack, sdl, null and pcm.
(09-24-2024, 08:04 AM)anonymous Wrote: Now it prints the available audio outputs, i.e pipewire, pulse, alsa, jack, sdl, null and pcm.
now you could test different audio outputs for troubleshooting, does all of them jam or crash.
mpv -ao={something} file.some
practically it is only worth testing alsa, pipewire and pulse. pcm creates a file. null does nothing. i don't know directly what jack and sdl do, but probably gives an error.
I was using bookworm on my pinephone, try upgrading to trixie and broke it. But then reinstalled the weekly image for trixie with installer. Can't tell how magical the progress has been, so much improvement on phosh, adaptive screen light now works good and beatiful new keyboard. Just one thign, where are the arrows whn using the terminal keyboard? I miss it.
(10-15-2024, 04:25 AM)user641 Wrote: I was using bookworm on my pinephone, try upgrading to trixie and broke it. But then reinstalled the weekly image for trixie with installer. Can't tell how magical the progress has been, so much improvement on phosh, adaptive screen light now works good and beatiful new keyboard. Just one thign, where are the arrows whn using the terminal keyboard? I miss it.
in my view, new keyboard was horrible, and i needed to put sort of old squeekboard back. it needed some catches, because of dependencies of old packages.
It displayed "Audio device underrun detected" once. Does it help?
  Mobian MMS/SMS text problem bcnaz 16 24,252 09-15-2025, 02:42 AM
Last Post: georgegohl888
  cryptocurrency on mobian/pinephone biketool 33 54,818 06-30-2025, 02:57 PM
  XLibre for Mobian Hiraghm 1 1,636 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 259,450 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,447 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 1,831 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,228 05-06-2025, 02:19 AM
  troubleshooting sleep/wake button on trixie biketool 5 1,958 05-04-2025, 08:11 PM
  mobian calamares fail merom 2 2,273 04-29-2025, 02:10 PM
Last Post: mdk
  New camera app gnome-snapshot working on trixie? vusra 4 2,117 04-11-2025, 02:53 AM
Last Post: vusra
Users browsing this thread: 7 Guest(s)
