PinePhone - boot from microSD
Hi all!
I have a PinePhone (UBports Edition), and I installed Ubuntu Touch 20.04 on eMMC successfully with JumpDrive after a few failed attempts to boot 20.04 (or even Manjaro ARM Beta33 Phosh) from microSD card.
So my issue now that I'm unable to boot any OS from microSD card. Maybe the problem is that I've installed Tow-Boot on the eMMC before, could it affect the boot process from microSD?
The microSD port is OK, because it can recognize my 2GB microSD with Tow-Boot (and the other one with JumpDrive), but when I put in the 16GB with UT 20.04 or Manjaro, and turn the phone on (with or without holding Volume down), it vibrates once with yellow LED up for a short time, but after that nothing happens.
Any idea?
Thanks in advance!
Tow boot should not have an issue. Did you try flashing from the computer directly to the emmc using jump drive? If not try doing that first.
(03-06-2024, 07:39 AM)aular Wrote: Tow boot should not have an issue. Did you try flashing from the computer directly to the emmc using jump drive? If not try doing that first.
20.04 was installed to eMMC from the computer using JumpDrive, so it's already done. Tow-Boot was installed before that (and I tried to install it after that, as well, but nothing's changed related to microSD boot issue).
Try reinstalling tow-boot to the card again then install to device. What im saying is is try putting a fresh file on the card, the old or current one might be corrupt.
(03-06-2024, 08:53 AM)aular Wrote: Try reinstalling tow-boot to the card again then install to device. What im saying is is try putting a fresh file on the card, the old or current one might be corrupt.
I used the one which was extracted from this file below on two different SD cards (installation was successful on both occasions):
https://github.com/Tow-Boot/Tow-Boot/releases/download/release-2021.10-005/pine64-pinephoneA64-2021.10-005.tar.xz
Do you have an other, well-tried version?
i would still try redownloading towboot again, i had the same issue and a fresh download is what solved it. Even though it would look sucessful, it could still be corrupt
(03-06-2024, 06:37 PM)aular Wrote: i would still try redownloading towboot again, i had the same issue and a fresh download is what solved it. Even though it would look sucessful, it could still be corrupt geometry dash world
Same issue. Any solution?
Another thing i thought about is checking the sd card itself to make sure that it is wiped fully clean meaning empty with no blocks like you just bought it from the store. Using the disk utility included in linux you should be able to see that on the computer. if using windows you can use disk part and mac idk. hope it helps
Hi! I wiped the microSD fully with diskpart and created primary partition via Windows 10, and then put the OS on it, so the issue is not here, I think.
Anyway, I'll try the boot process with another microSD, but this time with Ubuntu Touch 20.04 on it, because I've already put Manjaro ARM to the eMMC.
I put UT 20.04 onto another 16 GB microSD, but the issue is the same. The phone itself can recognize microSD cards (I can access files from other microSDs, or using JumpDrive etc.), but somehow it's unable to boot from it.
UPDATE:
I downloaded Tow-Boot for the third time, put it to the same 2 GB microSD and installed Tow-Boot to PinePhone again, and now it seems the phone has started the booting process (UT 20.04) from the 16 GB microSD Smile I did the same steps now as before, so it's quite interesting...
  Does PinePhone support long-term battery health optimization? roseblack 3 361 48 minutes ago
Last Post: evilbunny
  iso pinephone for sale (USA) elwoodb25 0 3,468 09-24-2025, 09:25 PM
Last Post: elwoodb25
  Why projects like PinePhone matter – feedback and encouragement Gary2003 13 16,656 09-16-2025, 01:13 PM
Last Post: Gary2003
  Can use PlayStation on Pinephone? willharper 7 8,307 09-13-2025, 12:30 AM
Last Post: ChaiLetters
  Pinephone Pro Neural Processing Unit biketool 1 4,995 09-01-2025, 02:05 AM
  Want to buy second hand PinePhone 3G version rudi.timmermans 2 4,517 08-31-2025, 07:18 AM
Last Post: Fish
  Pinephone Pro not in store? bubulux20c 1 2,823 08-08-2025, 02:12 AM
Last Post: P. Siera
  PinePhone Pro EU no warranty P. Siera 0 2,378 07-21-2025, 12:08 AM
Last Post: P. Siera
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 17,275 07-18-2025, 04:24 PM
Last Post: dchang0
  Pinephone visibly losing power while plugged in Hiraghm 2 3,603 05-23-2025, 12:30 PM
