LCD panel compatibility?
Another website carries the lcd panel FY07024DI26A30-1-fpc1_a , which is almost the same model number as the panel you are going to be providing, FY07024DI26A30-D
Are they interchangeable?
I can't find a datasheet for the one I'm talking about so I can't compare pinout, but I think you might have contact with the manufacturer?
I really want my panel here on time to start experimenting.
(01-24-2016, 06:22 PM)Glychee Wrote: Another website carries the lcd panel FY07024DI26A30-1-fpc1_a , which is almost the same model number as the panel you are going to be providing, FY07024DI26A30-D
I have no idea whether interchangeable due to lacking information. Please note tat beside LCD panel, you also need to consider touch panel which in general need to install at factory level for alignment calibration.
  7 inch LCD touch panel is upside down? joshpl 2 5,327 12-07-2023, 06:18 AM
Last Post: stormwyrm
  LCD panel Driver IC MIPIguy 1 5,687 08-12-2017, 05:04 PM
  I2C Touch Panel mbt28 0 3,641 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD touch panel emits low power Naccies 4 10,810 01-09-2017, 07:45 PM
  Lcd panel's pixels are not square bokeer 0 3,198 11-22-2016, 08:08 PM
Last Post: bokeer
  LCD Panel not working at all treize 7 16,945 09-19-2016, 10:24 PM
Last Post: billjon
  LCD Panel Connected but does not work maipercaso 1 5,147 08-20-2016, 08:14 PM
Last Post: MarkHaysHarris777
Photo Running Out Of Options LCD Panel Just Not Working AUDIOTEK 4 9,080 07-27-2016, 06:34 PM
Last Post: AUDIOTEK
  LCD Panel MikeJewski 1 5,561 02-09-2016, 10:56 AM
Last Post: Ghost
  LCD Panel Viewing Angle? KPhillisJr 1 5,272 01-21-2016, 06:52 PM
