linux-headers and quartz64-post-install package conflicts
I booted my Quartz model b for the first time after a couple days of trying different images and sdcards.  I'm very happy with the equipment upgrade from a raspberry pi 1 for the last couple years.  Particularly, when I hooked up USB tethering from my android the Quartz was connected to the internet right away with no tinkering.
uname -a
Linux forbiddenplanet 6.1.12-1-MANJARO-ARM #1 SMP PREEMPT Tue Feb 14 22:16:04 UTC 2023 aarch64 GNU/Linux
When I do a pacman -Syyu to upgrade system or use the gui for adding packages, I get the dependency of conflict linux-headers and quartz64-post-install providing the same file.  When I remove either the linux-headers package or the quartz64-post-install package the model b is unbootable.
/usr/lib/firmware/brcm/brcmfmac43455-sdio.pine64,soquartz-model-a.txt exists in both 'linux-firmware' and 'quartz64-post-install'
Errors occurred, no packages were upgraded.
Is there a way to remove this file from my source packages locally or should I force and install with pacman?
Sincerely,
Nate
You may want to try asking about this issue on the Manjaro ARM forums. Pine64 is not responsible for OS support, and the Manjaro devs are pretty active on their forums, so you'd be more likely to get an answer sooner.
(11-29-2023, 12:02 PM)tophneal Wrote: You may want to try asking about this issue on the Manjaro ARM forums. Pine64 is not responsible for OS support, and the Manjaro devs are pretty active on their forums, so you'd be more likely to get an answer sooner.
Thank you for your response. Will do
  StarPro64 Irradium (based on crux linux) riscv64, aarch64 mara 28 17,186 11-11-2026, 01:07 PM
  Star64 Irradium (based on crux linux) riscv64, aarch64 mara 22 22,003 10-19-2026, 12:27 PM
Wink Where should I post a PineBuds Pro repair and battery replacement guide? waitingpio 3 1,505 08-08-2026, 06:56 PM
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 3,715 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  Hello All! New user - 2 basic Quartz64 questions oldschool 2 5,379 12-14-2023, 12:06 AM
Last Post: oldschool
  PBP Debian 11 GRUB install error zlth 2 5,081 11-18-2022, 07:42 AM
Last Post: zlth
Exclamation Quartz64 model a wont boot AndyNZAUS 0 3,602 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 3,386 05-23-2022, 08:49 AM
Last Post: 98cwitr
  wrong launguage install chadace 1 6,506 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 10,508 03-18-2020, 09:42 AM
