A Btrfs Image for Arch SXMO on the Pinephone Pro
In order to recover from the unmaintained Manjaro Plasma distribution for the Pinephone Pro, I attempted to convert the Manjaro distribution to use the DanctNIX Arch repositories. But, although I found a cookbook list of steps to convert from Manjaro, the cookbook did not specify correctly how to renew the Arch keys. And I am not sure if the DanctNIX repository is included.
So I did not persist, and then gave Rhino Linux a tryout.
The keyboard symbols became a priority for me, so I tried to fix the issue on the Mobian Phosh partition. I could only manage to fix the missing symbols on the Linux console screens.
Next, I installed a btrfs image of DanctNIX SXMO for the Pinephone Pro. The main partition needed extension using gparted on a USB connection, and the btrfs format had to be explicitly extended. The complete re-installation of the Arch keys was needed. The required Zathura package was not preinstalled, and Megapixels and Surf do not work. The btrfs snapshots are not preconfigured. A bluetooth mouse will not install, but it is kind of an alien idea to SXMO.
But the keyboard symbols work!
(10-08-2023, 12:40 PM)mburns Wrote: In order to recover from the unmaintained Manjaro Plasma distribution for the Pinephone Pro, I attempted to convert the Manjaro distribution to use the DanctNIX Arch repositories. But, although I found a cookbook list of steps to convert from Manjaro, the cookbook did not specify correctly how to renew the Arch keys. And I am not sure if the DanctNIX repository is included.
Arch keys are generated by
sudo pacman-key --init sudo pacman-key --populate archlinux
Then you should sync the packages and update the keyring
sudo pacman -Sy sudo pacman -S archlinux-keyring
Then do a whole system update
sudo pacman -Syu
If you need to add the DanctNIX repository. Add it to the /etc/pacman.conf
Source: https://github.com/dreemurrs-embedded/Pi...nf.aarch64
$sudo nano /etc/pacman/conf #Add these line to the bottom of the file [danctnix] Server = https://p64.arikawa-hi.me/aarch64/danctnix/
Then you should sync the packages again
The mouse problem was apparently my fault. I did not setup the mouse correctly for pairing.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,066 10-20-2025, 07:01 AM
  Bare metal on Pinephone Pro alain 0 3,585 08-19-2025, 07:58 AM
Last Post: alain
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 7,912 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 2,803 05-03-2025, 11:02 AM
  the camera apps does not work on arch linux sxmo moriartyo 0 2,361 04-21-2025, 03:08 AM
Last Post: moriartyo
  freeBSD is booted on pinephone pro with console output zetabeta 5 5,816 04-18-2025, 12:56 AM
Last Post: teekay
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 5,911 02-26-2025, 02:15 AM
Last Post: TOF
  Anyone gotten latest Ubuntu Touch to work on PinePhone Pro? dchang0 4 9,234 12-22-2024, 04:21 PM
Last Post: dchang0
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,230 10-28-2024, 10:46 AM
Last Post: Jite
  Arch Linux Arm DanctNIX complete setup mikehenson 3 10,722 08-06-2024, 07:45 PM
Last Post: kbm
