Error On Initial Setup
I have made several attempts to set up the system, but I keep encountering an error during the repository update process, causing the initial setup to fail. My internet connection is stable, and I have tried using different high-quality power sources and multiple SD cards. I suspect that the problem lies with the sources.list file. Could any developers investigate this matter, please?
Platform details:
Hardware: Pine64 A64+ 2GB
Operating System: 1.4.1 Openhabian Image
(11-21-2023, 11:37 AM)HankLubowitz Wrote: I have made several attempts to set up the system, but I keep encountering an error during the repository update process, causing the initial setup to fail. My internet connection is stable, and I have tried using different high-quality power sources and multiple SD cards. I suspect that the problem lies with the sources.list file. Could any developers investigate this matter, please?
Platform details:
Please check if you wrote in the correct section. You mentioned a PINE A64 single board computer in your post but you ask in the section of the laptop "Pinebook Pro". Also bug reports should be put on the bug tracker of the distribution you ask about, not on a random forum.
You will have a lot bigger success with https://www.armbian.com/pine64/ + installing OpenHab as a docker instance. Openhabian only works well on Rpi.
  BIOS setup ergox 1 3,862 11-15-2022, 12:54 PM
  Error trying to update Manjaro software boosterh 5 8,920 08-31-2022, 10:28 PM
Last Post: shulamy
  extlinux.conf file error, can it be edited in bootloader? Abandoned Brain 2 6,810 09-26-2021, 01:28 PM
Last Post: Abandoned Brain
  Error Log has a few scetchy things. Manjaro Xfce SpaceLord 0 4,166 05-23-2021, 10:49 AM
Last Post: SpaceLord
Sad Help me w/ my Pinebook Pro setup Lyrixcaz 4 8,474 03-11-2021, 12:58 PM
Last Post: moonwalkers
  Error when running pinebook-pro-keyboard-updater NoahB 13 25,411 07-29-2020, 06:33 PM
Last Post: guiltydoggy
  pinebook pro manjaro xfce pacman network error thumbsup 1 5,406 07-11-2020, 02:32 PM
Last Post: thumbsup
Question Where is fusermount? (rclone mount error) davemaps 1 4,935 07-02-2020, 01:04 AM
Last Post: hvdkooij
  Remote-viewer "Bus Error" wingmanjd 6 12,688 06-09-2020, 07:29 AM
Last Post: wingmanjd
  Error when trying to install local package with pkcon koenigs 0 3,517 05-11-2020, 03:22 AM
Last Post: koenigs
