How to find software app, on Arch Phosh?
Hi, I have observed online that Arch on the Pinephone Pro has access to a Software app - faciliting the download of software, similar to the same function on the Mobian OS for Pinephone. However, I have noticed that it is not immediately accessible when Arch is installed.
Could anyone please advise me on the method to find and enable this function (the Software app)?
Thanks.
This link may help.
https://www.youtube.com/watch?v=-nbUXABJ...99&index=4
To install the gnome software center.
Open a terminal and type
sudo pacman -Sy
sudo pacman -S gnome-software
The software icon should show up on the "desktop" or app drawer
(05-01-2023, 07:17 AM)mikehenson Wrote: This link may help.
sudo pacman -Sy
Thanks so much. It's been a while since I've set up a linux distro so this video looks great.
That's just the package I was looking for thank you.  Smile
Be warned that GNOME Software relies on PackageKit, which does not work all that well on Arch Linux. Especially system upgrades with GNOME Software or Plasma Discover are not a good idea.
(05-02-2023, 11:42 AM)Kevin Kofler Wrote: Be warned that GNOME Software relies on PackageKit, which does not work all that well on Arch Linux. Especially system upgrades with GNOME Software or Plasma Discover are not a good idea.
Is there a software GUI that is suitable for Arch Phosh?
PPP
pamac-gtk, though you probably have to get it either from AUR (semi-supported) or from Manjaro repositories (unsupported by Arch), since it is not in the official Arch repositories.
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,094 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,086 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  stuck between phosh and plasma aular 0 2,457 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 9,450 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 5,834 01-11-2024, 10:18 PM
  Arch auto mount usb example Lazy_one 2 9,286 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 3,923 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,316 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 5,487 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 7,383 10-23-2022, 01:53 PM
Last Post: Chief
