Rhino Linux does not seem ready for the PinePhone Pro.
I installed the rhino image file on the internal chip. It booted well enough, very showy compared to Mobian. (I have the PinePhone Keyboard installed.)
On reboot, the status panel was not present, neither was the virtual keyboard. I could not adjust the screen magnification from 100%, or add a Bluetooth mouse. With work, the Linux console could be quite usable. I did not have the knowledge of XFCE4 to recover the panel, virtual keyboard, or mouse.
This update command works:
$ pacstall -Up
(08-24-2023, 08:15 AM)mburns Wrote: I installed the rhino image file on the internal chip. It booted well enough, very showy compared to Mobian. (I have the PinePhone Keyboard installed.)
$ pacstall -Up
If it's all gone pair shaped I also regularly use "onboard" - Simple On-screen Keyboard to get me out of trouble with touch screens on Pi's ? Just tried it on Mobian on PPP but just crashes out with a GTK error ? Don't know if it's available / works on PPP in Rhino ?
Can you run "xfce4-panel" from terminal ?
xfce4-panel
I've accidentally removed the xfce4 panel once with a Xubuntu PC build so not sure if that will help in Rhino ?
Again possibly useless noting you can't get a Bluetooth mouse however a USB C connected mouse ?
If you could get to the xfce menu I think "panel" might help in the search bar at the top of the menu with it's settings / restore ?
Or running "terminal" from there and "xfce4-panel" from the open terminal ?
Taken from this ;
https://www.reddit.com/r/linuxquestions/..._xfce_how/
Possibly not helpful in Rhino but thought I'd throw my 5 cent's in anyway Wink
The difficulty with the mouse connection was my failure to setup the mouse correctly for pairing.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,017 10-20-2025, 07:01 AM
  Bare metal on Pinephone Pro alain 0 3,573 08-19-2025, 07:58 AM
Last Post: alain
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 7,880 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 2,792 05-03-2025, 11:02 AM
  the camera apps does not work on arch linux sxmo moriartyo 0 2,348 04-21-2025, 03:08 AM
Last Post: moriartyo
  freeBSD is booted on pinephone pro with console output zetabeta 5 5,782 04-18-2025, 12:56 AM
Last Post: teekay
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 5,871 02-26-2025, 02:15 AM
Last Post: TOF
  Anyone gotten latest Ubuntu Touch to work on PinePhone Pro? dchang0 4 9,186 12-22-2024, 04:21 PM
Last Post: dchang0
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,216 10-28-2024, 10:46 AM
Last Post: Jite
  Arch Linux Arm DanctNIX complete setup mikehenson 3 10,676 08-06-2024, 07:45 PM
Last Post: kbm
