eMMC upgrade
Has anyone tried to replace stock eMMC (16Gb or 32Gb) with a bigger eMMC (in a phone repair shop for example)? Is it possible? What models are compatible?
(07-15-2023, 02:08 PM)EuvzO8 Wrote: Has anyone tried to replace stock eMMC (16Gb or 32Gb) with a bigger eMMC (in a phone repair shop for example)? Is it possible? What models are compatible?
That would not make sense IMO. The eMMC is soldered with ball grid array and would be quite involved and costly to swap it. MicroSD cards cost almost nothing and you can adjust your mount points to transfer data (such as personal files, applications etc.) to it.
The main reason is speed. SD cards are noticeably slower on OG PP (even with faster cards). than eMMC. With vccq mod eMMC speeds can be around 125MB/s, but SD card achieves approximately 23 MB/s. This is five times slower.
https://wiki.pine64.org/wiki/PinePhone_F...d_SD_cards?
The eMMC is slightly faster, can be twice as fast. The vccq mod is not advised, only works with some eMMCs, is highly risky and you make all images incompatible, so I would estimate there are less than a dozen people in total who made the mod, out of tens of thousands of sold PinePhones.
You can put stuff relevant for speed on the eMMC, like people used to do with their system on SSDs when the capacity was low. Everything else makes no reasonable economical sense.
[quote pid="119203" dateline="1691994961"]
[/quote]
JFYI I've tried vccq mod and have performance measurements before and after for 16/2 PP. Here is my comparison of eMMC performance with SD card performance.
0. SD card (Sandisk Extreme Pro UHS-I U3 V30 A2 + ADP)
Quote:root@mobian:/home/mobian# hdparm -t -T /dev/mmcblk0
/dev/mmcblk0:
Timing cached reads:  802 MB in  2.00 seconds = 400.36 MB/sec
Timing buffered disk reads:  66 MB in  3.07 seconds =  21.51 MB/sec
1. eMMC speed (default, no vccq mod)
Quote:mobian@mobian:~$ sudo hdparm -t -T /dev/mmcblk2
/dev/mmcblk2:
Timing cached reads:  942 MB in  2.00 seconds = 470.48 MB/sec
Timing buffered disk reads: 242 MB in  3.02 seconds =  80.08 MB/sec
80.08/21.51 = 3.72 times faster than SD
2. eMMC speed (with vccq mod)
Quote:root@mobian:/home/mobian# hdparm -t -T /dev/mmcblk2
/dev/mmcblk2:
Timing cached reads:  894 MB in  2.00 seconds = 446.58 MB/sec
Timing buffered disk reads: 358 MB in  3.01 seconds = 118.98 MB/sec
118.98 / 21.51 = 5.53 times faster than SD
SD card is considerably slower than eMMC.
Quote:You can put stuff relevant for speed on the eMMC, like people used to do with their system on SSDs when the capacity was low. Everything else makes no reasonable economical sense.
This is what I'm doing right now. 16Gb isn't that big. I do understand, that BGA replacement is risky and costly operation. But maybe someone tried that.
(08-14-2023, 02:14 AM)EuvzO8 Wrote: [quote pid="119203" dateline="1691994961"]
/dev/mmcblk0:
/dev/mmcblk2:
/dev/mmcblk2:
[/quote]
What did you do to get the vccq mod to work? I added the the files and it boots properly and says it is updated to new speed but, i still get hdparm at 86mb/s.
I am running arch but am just looking for other non PM os knowledge.
Info i used: https://github.com/dreemurrs-embedded/Pi...issues/263
  Firmware update only did partial upgrade? Agent24 2 782 09-26-2026, 05:04 PM
Last Post: Agent24
  emmc speed via usb? joe1 0 3,349 04-27-2024, 08:07 PM
Last Post: joe1
  RAM corruption, possible eMMC corruption alnyan 3 6,016 08-24-2022, 03:07 AM
Last Post: JeremyWadsworth
  Emmc yvan 1 3,635 07-07-2022, 08:16 AM
Last Post: Chief
  Any experiences with hardware mod to improve eMMC speeds? kqlnut 9 14,052 04-19-2022, 02:36 PM
Last Post: kk22
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 3,290 06-22-2021, 10:03 AM
  Where is the Pinephone eMMc? tgz 12 22,513 02-10-2021, 06:24 PM
Last Post: dsimic
  Pine phone eMMC read speeds ? bcnaz 14 27,440 11-20-2020, 02:52 AM
Last Post: LinAdmin2
  Does the BH mainboard upgrade allow a USB PD dock? _hg_ 3 7,316 11-08-2020, 09:37 AM
Last Post: arvizu
  eMMC won't flash RodMyers 3 8,702 09-12-2020, 06:38 PM
Last Post: SwordfishII
