QEMU with Alpinelinux
Information
Alpinelinux in QEMU
I have used the introduction from astr0baby and a few other internet sources and came up with a working solution to boot Alpinelinux in QEMU on the Pinebook Pro. The settings are relatively simple and should work with other target ISOs in a similar way. There is no graphics support, yet. The host distro used here is Manjaro. There might be some differences with other distros. Mind you, this describes how to run an arch64 ISO on an arch64 system.
Install Qemu and create a folder to keep all files together:
pacman -S qemu-base
pacman -S qemu-img
mkdir qemu
Copy the ISO of Alpinelinux to your qemu folder.  I have used the Standard ISO for the aarch64 architecture.
Then you need to download a BIOS
wget https://releases.linaro.org/components/kernel/uefi-linaro/latest/release/qemu64/QEMU_EFI.fd
Last thing to prepare is a virtual harddrive to install Alpinelinux
qemu-img create -f qcow2 alpine.qcow2 8G
This makes a 8G virtual hard disk in a file named alpine.qcow2, the qcow2 format being a format which appears to be 8G to the guest (VM), but only actually writes to the host any sectors which were written to by the guest in practice.
Install Alpinelinux
With all in place you can now start qemu from the .iso file and then install Alpinelinux to your virtual harddrive
qemu-system-aarch64 \
-machine virt -cpu cortex-a57 \
-m 1024M -nographic \
-bios QEMU_EFI.fd \
-drive format=raw,readonly=on,file=alpine-standard-3.17.3-aarch64.iso \
-drive file=alpine.qcow2,media=disk,if=virtio
A small explanation. The first line is qemu for the aarch64 architecture. The second line describes the cpu. Then memory of 1024M is assigned. 512M is also fine. No graphics is supported. Next is the bios and then the two drives. The ISO file and the virtual harddrive.
Later I show how to use kvm and smp. They could also be used here, but this keeps is simple.
Once Alpinelinux has booted login like this:
user: root
passwd: <leave empty>
Once logged in you can straight away start the install process.
setup-alpine
Please see the Alpine Docu  and Alpine Wiki for details of the installation process.
You will be asked a bunch of questions, most of them will be default. Things to notice:
  • maybe set your timezone
  • you will be asked which drive you want to use: vda
  • what kind of installation you want: sys
Run Alpinelinux
After the system is installed successfully, you can poweroff. To restart the system you don't need the ISO file anymore. The command after installation is:
-bios QEMU_EFI.fd \
SMP
If you want qemu to use more than one cpu add the [backcolor=#f6f8fa]-smp 2[/backcolor] switch. This gives two cpus, more is possible.
KVM
For Kvm to work you either have to add your user in Manjaro to the kvm group, or run qemu with sudo.
Also:
  • add -accel kvm
  • you can switch [backcolor=#f6f8fa]-cpu[/backcolor] to host
If you use KVM there appears to be a bug that sometimes creates this error message:
Quote:qemu-system-aarch64: kvm_init_vcpu: kvm_arch_init_vcpu failed (0): Invalid argument
Just repeat the start command until it works.
-accel kvm -machine virt -cpu host -smp 2 \
-bios QEMU_EFI.fd \
Edit See comment from jpalus below for a better way to call qemu with kvm.
That's it. I am sure there is still much to improve, but it works.
References
https://drewdevault.com/2018/09/10/Getti...-qemu.html
(05-03-2023, 01:41 PM)Surehand53 Wrote: If you use KVM there appears to be a bug that sometimes creates this error message:
-bios QEMU_EFI.fd \
That's not the best advice. qemu with KVM acceleration needs to be run on the same CPU core type throughout its entire lifecycle. That means in case of multi cluster setups qemu needs to be forced to run within single cluster. In case of Pinebook Pro that means setting CPU affinity to either A53 or A72 cores. While repeating start command may work eventually, the VM won't be stable and will crash/hang the moment it will be rescheduled to different core type.
In order to set CPU affinity you can use taskset but unfortunately it needs additional privileges (root or CAP_SYS_NICE). One way to run qemu on Pinebook Pro restricted to A72 cores with sudo is:
sudo taskset 30 sudo -u user qemu-system-aarch64 -enable-kvm ...
For more details see manpage for taskset.
-bios QEMU_EFI.fd \
So,  just started playing with qemu.  So I ask this out of complete ignorance.  Do you need taskset when using qemu to emulate another arch?  I built qemu from scratch since the manjaro-repos are broken and don't let you install qemu-full or qemu-system-i386.  (Trying to test a Win95 VM for some older win95 games.)
(05-06-2023, 04:21 AM)korreckj328 Wrote: So,  just started playing with qemu.  So I ask this out of complete ignorance.  Do you need taskset when using qemu to emulate another arch?  I built qemu from scratch since the manjaro-repos are broken and don't let you install qemu-full or qemu-system-i386.  (Trying to test a Win95 VM for some older win95 games.)
taskset is needed only when using KVM acceleration which can't be used for archs different than native one so no need to use taskset for i386 emulation. It will be slow though. Depending on your needs you might consider using box86 instead for better performance.
This seems to be a bug on the RK3399 that you need to use a single core type for KVM. On the RK3588S I can use any combination of cores for virtual machines and it works correctly.
If you use libvirt then it can be set in the XML:
<vcpu placement="static" cpuset="4-5">2</vcpu>
(05-09-2023, 01:23 PM)slyecho Wrote: This seems to be a bug on the RK3399 that you need to use a single core type for KVM. On the RK3588S I can use any combination of cores for virtual machines and it works correctly.
Works the same way (boot failure / unstable if run across different core types) for me on Amlogic S922X (Odroid N2+) as well Rockchip RK3588 (Rock5B). RK3588 is still running vendor kernel so not sure how representative it is but if I set CPU affinity to 1 A55 core and 1 A76 core than it sometimes fails to boot VM with hardware exception and even if it boots one core is fully utilized at all times even when idle which is not the case if CPU affinity is set to single core type.
I was running Armbian with 5.10.110-rockchip-rk3588
It works well with Linux guests and NetBSD. Windows 11 was a bit unstable and sometimes failed to boot but the core selection didn't matter.
