Real-time linux kernel
#31
(05-29-2016, 02:35 AM)Artyom Wrote: @umiddelb. Hi again. Аs I said earlier we need new kernel. As far as I understand we need kernel version 3.18.11. Additionally, you can read here:
https://patches.linaro.org/patch/47092/
https://patches.linaro.org/patch/47646/
Hm, I wouldn't go for the 3.18 kernel since a mainline kernel (4.7) is about to be issued in the next couple of weeks.
#32
Read links. And tell me what you think.
#33
As i undestand in the nex few week we have new kernel (4.7) with Pine64 support? I am right?
#34
Sunxi developers currently work hard on the mainline kernel development. For the status, you can check on Sunxi site or participate if you interest to contribute. Kudos to Sunxi community.
#35
Hi TLLIM. Please post link.
#36
Hi @all,
since we have a more or less working 4.9 mainline kernel, I was able to apply the latest PREEMPT_RT patches against 4.9.6.
You will find the kernel sources here and a ready to extract kernel image here. If you want to modify some of the kernel configuration parameters, I can give you some advice how to do this and how to build a kernel on your own Pine64.
Cheers
Uli
#37
I'm wanting to build a rt system for digital audio (squeezebox) using a pine64+ (2GB) running Armbian base system.
I've been trying to apply the https://www.kernel.org/pub/linux/kernel/...s/rt/3.10/
patch-3.10.104-rt117 patch set on the Armbian 3.10.104 source tree, following the procedure outlined in the developer guide.
https://docs.armbian.com/Developer-Guide...eparation/
The patches are applied successfully, but I am facing a number of problems with the build.
There were failures in various IP tunnelling modules, which I have simply removed from the config, as I don't need them, but now I'm struggling with:
MODPOST vmlinux.o        │
 │ WARNING: modpost: Found 2 section mismatch(es).        │
 │ To see full details build your kernel with:        │
 │ 'make CONFIG_DEBUG_SECTION_MISMATCH=y'        │
 │   GEN     .version        │
 │   CHK     include/generated/compile.h        │
 │   UPD     include/generated/compile.h        │
 │   CC      init/version.o        │
 │   LD      init/built-in.o        │
 │ drivers/built-in.o: In function `mbus_pmu_remove':        │
 │ arisc_dram_crc.c:(.text+0x1d38): undefined reference to `hwmon_device_unregister'        │
 │ arisc_dram_crc.c:(.text+0x1d38): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `hwmon_device_unregister'                │
 │ drivers/built-in.o: In function `mbus_pmu_probe':
Can anyone suggest how to fix it?
I want to stay with 3.10.104 as vanilla doesn't support the LCD interface (which I need for the touch screen).
BR.
--Marius--
#38
(02-08-2017, 03:06 AM)Learnincurve Wrote: Hi,
MODPOST vmlinux.o        │
 │   GEN     .version        │
BR.
--Marius--
You may try to enable CONFIG_HWMON=y in your config.
Cheers
Uli
#39
Thanks umiddelb!
Compilation goes through now, with CONFIG_HWMON compiled in, rather than as a loadable module.
#40
(02-08-2017, 02:33 AM)umiddelb Wrote: Hi @all,
Cheers
Uli
Great job Smile
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,361 03-28-2020, 06:20 PM
Last Post: ty1911
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,598 11-13-2019, 09:41 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 95,698 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,195 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,651 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 72,507 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,899 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,358 09-25-2018, 03:39 PM
Last Post: bjbb17
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,409 06-21-2018, 05:45 PM
Last Post: evilbunny
  linux distribution hazerty 3 10,347 04-01-2018, 02:48 PM
Last Post: dkryder
