[Megapixels] Flash strobe, pictures viewer and MPCamera error 22
Hi all,
I'm in bookworm mobian and do all latest available updates/upgrades on repo.
I have megapixels with 1.6.0-1+b1 version.
As suggest, i have installed necessary packages "dcraw" and "imagemagick".
In log, flash strobe is not openned.
Failed to open /sys/class/leds/white:flash/flash_strobe
And when i clicked on picture small icon to launch the picture viewer, it returned to me this error.
display-im6.q16: unable to open X server `' @ error/display.c/DisplayImageCommand/412.
Moreover, some camera log give error 22 as described follow.
MPCamera: VIDIOC_SUBDEV_S_FRAME_INTERVAL error 22, Argument invalide MPCamera: VIDIOC_QBUF error 22, Argument invalide
Thanks a lot for your feedback.
All log megapixels from term are here.
megapixels Found config file at /usr/share/megapixels/config/pine64,pinephone-1.2.ini Adding camera rear from config Adding camera front from config Failed to open /sys/class/leds/white:flash/flash_strobe MPCamera: VIDIOC_SUBDEV_S_FRAME_INTERVAL error 22, Argument invalide Initialized OpenGL ES 2.0 TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/0.dng TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/1.dng TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/2.dng Making thumbnail TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/3.dng Post process /tmp/megapixels.SXpdil to /home/home/Images/IMG20230317080048.ext (save-dng 1) MPCamera: VIDIOC_SUBDEV_S_FRAME_INTERVAL error 22, Argument invalide MPCamera: VIDIOC_QBUF error 22, Argument invalide display-im6.q16: unable to open X server `' @ error/display.c/DisplayImageCommand/412. display-im6.q16: unable to open X server `' @ error/display.c/DisplayImageCommand/412.
(03-17-2023, 07:17 AM)freelectro Wrote: Hi all,
And when i clicked on picture small icon to launch the rooftop snipers viewer, it returned to me this error.
Flash Strobe Issue:
The error message indicates that the flash strobe is not being opened. This could be due to a hardware or configuration issue. Make sure that your device's camera supports a flash strobe and that it is functioning correctly. Additionally, check the configuration files for Megapixels to ensure that the settings for the flash strobe are properly configured.
X Server Error:
The error message "unable to open X server" suggests an issue with the X server, which is responsible for managing graphical display on Linux systems. Make sure that the X server is running and accessible. If you are running Megapixels from a terminal, try launching it from a graphical user interface (GUI) environment to see if the error persists.
VIDIOC_SUBDEV_S_FRAME_INTERVAL and VIDIOC_QBUF Errors:
These errors indicate problems with video input/output control (VIDIOC) operations. It could be caused by incompatible or incorrect camera drivers or configurations. Make sure that you have the appropriate camera drivers installed and configured correctly for your device. You may need to check the Megapixels documentation or seek support from the Mobian or Megapixels community for further assistance.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,693 06-23-2026, 01:12 AM
Last Post: Mary_Davis
Exclamation Cannot flash the modem firmware anonymous 9 13,935 12-17-2025, 01:42 AM
  pinephonepro.ini for Megapixels biketool 1 3,379 01-04-2025, 04:26 PM
  ModemManager debug mode? (Needed to flash modem) calinb 1 5,933 02-27-2023, 04:18 PM
Last Post: calinb
Exclamation The document viewer Evince cannot be reinstalled anonymous 0 2,011 09-08-2022, 05:09 AM
Last Post: anonymous
  Megapixels doesn't work Glenn 4 8,092 08-28-2022, 03:19 PM
Last Post: vortex
  Megapixels and Pinhole Zebulon Walton 0 2,258 06-15-2022, 04:53 PM
  Fast image viewer? vusra 0 2,111 04-25-2022, 04:09 AM
Last Post: vusra
  Error - megapixels not opening user641 17 25,373 03-29-2022, 03:43 PM
Last Post: bcnaz
  Flatpak error during apt update user641 0 2,642 02-14-2022, 08:35 AM
Last Post: user641
