Axolotl on PinePhone / Mobian
i said elsewhere, but maybe repeat.
i manage to install and register signal on waydroid x86_64 on a laptop. however, no camera support, so it means no linking to other apps, like signal-desktop. waydroid also requires wayland support, which may not be straitforward.
I have signal-desktop on my PC (RockPro64) and all my PinePhone installs. Compile once on the RockPro for aarch64 and install everywhere else :-)
Thank you both for your replies! Smile
I think I will also try to use Signal desktop if I have a working ever Linux smartphone again.
(My both PinePhones went bad and are just annoying electronic waste now I'm afraid, so Axolotl currently doesn't really matter for me anymore...)
Again, thanks!
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
...and it works again! Texts are visible here since yesterdays regular Mobian updates - It's seems some component/framework(?) which was used by Axolotl in the background was buggy/wasn't compatible anymore... and is fixed now. Smile
...it's somehow wierd (but nice! Wink ) that Axolotl on Mobian STILL works here... (last version is from Oct 27 2022, I waiting for a critical change on the Signal infrastructure that finally kills Axolotl any day, but so far it still works! Smile )
how do i remove nanu-c axsolotl,  now that there is a deb package?
ezik
(03-22-2023, 12:05 AM)shulamy Wrote: how do i remove nanu-c axsolotl,  now that there is a deb package?
ezik
sudo apt-get purge axolotl # if previous does not work, don't use as first option sudo dpkg purge axolotl
you could use "aptitude" or other software manager program as well.
i don't recommend auto-updating for beta products like pinephone (pro).
but
"E: Unable to locate package axolotl"
  the app exist in the pinephone but doesn't work properly
 ezik
dpkg can not find axolotl package as well
(with the command sudo dpkg --purge axolotl)
ezik
(03-22-2023, 04:58 AM)shulamy Wrote: but
 ezik
ezik
now i stat to have feeling that there is multiple overlapping installation, like flatpak, appimage, snap or even compiled from source. try to uninstall all of them, but given precise instructions might be inaccurate.
there was tow but both were from deb packge "axolotl_1.6.0-1_arm64.deb"
ezik
i tried (again) with the "software" gui an this time it removed the second axsolotl
ezik
  Printing from Mobian johnd 3 5,134 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,092 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,114 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,827 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,342 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,623 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,304 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,569 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,306 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 5,004 04-29-2025, 02:10 PM
Last Post: mdk
