reset button under back cover, below the camera
there is a reset button under the back cover, below the camera
What is it good for?
I checked the user manual and the https://wiki.pine64.org/wiki/PinePhone. Neither of these are giving any clue.
https://forum.pine64.org/showthread.php?...ight=reset
says that there is no factory reset, so what is it then?
I believe it's a hard reboot, like pushing the reset button on a desktop computer, in the event the software is completely locked up.
The schematic shows it operating directly on the A64's reset line, so it's rebooting the processor without directly affecting other parts. That _may_ make it a safer hard reset than just pulling the battery if your modem has the stock firmware, assuming there isn't a side effect of that reset causing a hard reset on the modem. I imagine it could make some low level development easier too.
The stock modem firmware is an embedded linux with has a filesystem mounted read-write, and if you're unlucky it can be corrupted if the modem isn't shut down cleanly before power is removed. The community firmware avoids this by not mounting the filesystem read-write.
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 5,610 07-16-2023, 11:14 AM
Last Post: kebab
  volume down button issue sapphire 0 1,789 05-20-2023, 06:25 AM
Last Post: sapphire
  PinephonePro camera calibration conundrum orbital 0 2,181 07-06-2022, 09:09 AM
Last Post: orbital
  Camera on manjaro arm transfer76 7 11,283 03-18-2022, 10:11 PM
Last Post: Ant
  Selling original PinePhone postmarkedOS edition, 3GB RAM, keyboard cover + more ajtakrajta 4 6,776 02-23-2022, 10:34 AM
Last Post: lot378
  Help - Factory Reset ?? sej016 4 8,636 12-09-2021, 06:42 AM
Last Post: sej016
  reset to factory default jacques@abstraction.ch 1 7,434 09-03-2021, 04:32 AM
Last Post: jlucas
  Problems with Pinephone camera ov5640 wfk 0 2,551 06-29-2021, 01:53 AM
Last Post: wfk
  modem and login/reset issues dhawk 1 4,337 06-23-2021, 05:04 PM
Last Post: 33YN2
  Manjaro Phosh Beta 10...how to get button labels on Angelfish? INSTRUCTIONS WITHIN patrio 4 10,396 06-11-2021, 07:10 AM
Last Post: patrio
