MicroSD Card Reuse
You can reuse the same MicroSD card multiple times and with multiple different images, right? I should be able to flash different images to the same MicroSD card many times before it stops working, right?
Seems obvious, but I thought I'd get some verification. Anyone have problems reusing a MicroSD card with the same or different image files?
No problems at all, you can flash it as many times as you like.
(12-07-2022, 08:03 AM)_radv_ Wrote: You can reuse the same MicroSD card multiple times and with multiple different images, right?  I should be able to flash different images to the same MicroSD card many times before it stops working, right?
Yep, SD cards are just really small solid state disks... However be careful if you go to use the SD card as a boot drive daily, they can only be written to so much before they go read only. I got a few months out of a few cards in a row before I figured out what happened. I'm using the emmc now.. It might have just been the type of cards I bought (non of them where high endurance ones).
@chainingsolid
Maybe I'm having a similar problem.
Assuming you've tried to boot your device with an image on a card that's gone read only: what happens?  It skips the card and boots directly from the emmc, right?  Can you even write (i.e. flash) an image to the card?
@chainingsolid
_radv_, mind that you also have to wipe U-Boot from the card if you don't want to boot from that card. Formatting the drive, deleting the partition table or the partition won't be enough -> https://wiki.pine64.org/wiki/PinePhone_I..._from_eMMC
@chainingsolid
Its been a while, so I've forgotten some info, but once the SD card goes read only it will not accept any writes. I believe it failed to boot at all as the boot loader sees a bootable SD card but the kernel just dies cause it can't write anything. I don't think it would try the EMMC if the SD card failed. I think the SD card has to be free of a bottable partition totally to use EMMC. You can still insert the card into a computer/laptop and copy data off it. My current setup has the SD card slot empty.
  PinePhone - boot from microSD laserpyramid 9 8,454 05-03-2024, 10:09 AM
Last Post: laserpyramid
  install iso from sd card to emmc aular 2 3,367 03-11-2024, 10:24 PM
  How To Share The External MicroSD Folders and Files On A Network? pinephoneuser22 5 5,756 02-10-2024, 08:47 AM
Last Post: jakfish
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,021 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 8,961 06-11-2023, 12:30 AM
Last Post: AndyM
  rough estimate of expected microSD installation life? andrewp907 7 8,284 06-10-2023, 07:55 PM
  Device Unable To Read MicroSD Card _radv_ 19 17,068 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 4,276 12-21-2022, 05:37 PM
Last Post: thismarty
  TF = MicroSD? _radv_ 1 2,668 12-09-2022, 09:08 AM
Last Post: fxc
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 4,083 11-23-2022, 05:19 AM
Last Post: _radv_
