Survey for Model B Owners: Stereo Audio HAT
Hello PINEfriends,
I'm considering designing a stereo audio board for the Quartz64 Model B, and wanted to gauge whether there's any interest in this.
The board would most likely be based around TI's PCM3060 audio codec, as it has good performance and mainline drivers. Additionally, an SPDIF output from the Quartz64 Model B's GPIO header would also be exposed as TOSlink. I also envision there being an external mute control based on the TI TS5A22362 to eliminate any power up/power down popping noises.
So here are a few questions for people to answer:
  • If you are a current or prospective owner of a Quartz64 Model B, would you be interested in such a board?
  • At which price point?
  • How would you prefer your analog audio output, balanced with a hybrid XLR/6.35mm connector? Or single-ended/unbalanced with 3.5mm or RCA style connector?
  • Do you want SPDIF as TOSlink or RCA?
  • Do you need single-ended/unbalanced stereo analog audio input?
  • What kind of heatsink do you use on your Model B?
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
Bit late to the party, but in case it's still useful I've responded below.
(12-07-2022, 08:44 AM)CounterPillow Wrote: If you are a current or prospective owner of a Quartz64 Model B, would you be interested in such a board?
Yes, but only once proper hardware-accelerated video decoding was implemented (e.g. netflix at full quality/speed through a browser), so I could replace my current setup (both video and audio use cases).   Unfortunately looks like 4k video decoding is still a way off.
Quote:At which price point?
Practically? Needs to be under the price of an equivalent USB DAC (under as the USB unit would be more flexible).
Quote:How would you prefer your analog audio output, balanced with a hybrid XLR/6.35mm connector? Or single-ended/unbalanced with 3.5mm or RCA style connector?
I don't think I have a strong preference.  A simple 3.5mm is slightly more practical, but it's also easy to adapt from a 6.35.
Quote:Do you want SPDIF as TOSlink or RCA?
TOSlink.
Quote:Do you need single-ended/unbalanced stereo analog audio input?
No.
Quote:What kind of heatsink do you use on your Model B?
None currently, although (an equivalent to) the smallest variety on the Pine64 store will come in time.
  Quartz64 Model A fan TeutonicTovarish 2 4,980 07-08-2024, 07:19 AM
Last Post: p1x3l3d
  A large 3d printable case for Model A, or a dimensioned drawing of the PCB? Randomuser 1 2,895 05-24-2024, 08:11 AM
  Is the USB 3.0 port still an issue for Q64 model A? andreas1107 3 5,536 12-11-2023, 09:27 AM
Last Post: diederik
  SOQuartz Model A baseboard Real-Time Clock stormwyrm 1 3,179 11-19-2023, 01:04 AM
Last Post: stormwyrm
  SD card slot in Quartz64 model B psic4t 1 4,061 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 3,737 10-13-2022, 07:43 PM
Last Post: dml-pc
  3D Model / Technical Drawings pitchbent 2 5,601 10-05-2022, 02:01 PM
Last Post: pitchbent
  RockPro64 NAS case compatibility (Model A) flocke 2 6,409 06-12-2022, 10:33 AM
Last Post: flocke
  Case for the Quartz64 Model B? kuleszdl 1 5,561 06-05-2022, 02:43 PM
Last Post: CounterPillow
