PBP Debian 11 GRUB install error
Hi all.
I have a Pinebook pro with SPI tow boot flashed.
I'm trying to install Debian 11 on eMMc from the official stable release. At the end, GRUB installation ends with an error.
After this failure, the installation media stops loading, and I flash it again every time.
I tried installing rEFInd on the ESP partition, but it doesn't seem to work, all drivers say "program has returned 0" and then reboot.
Installing GRUB from chroot doesn't work either.
I know the new release of Manjaro boots in uEFI mode using GRUB, how can I get Debian to do the same?
upd.
So, I was able to manually make changes to the boot partition and GRUB now starts up.
But after selecting Debian, the boot process starts and I only see a black screen.
Any ideas?
I solved all the problems, Debian is installed from the official image, Tow-boot loads GRUB from which Debian starts normally.
Thank you all for your help Smile
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 5,207 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 3,369 05-23-2022, 08:49 AM
Last Post: 98cwitr
  wrong launguage install chadace 1 6,481 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 10,484 03-18-2020, 09:42 AM
  Rock64 with Debian netinst usb Bloris 6 15,118 12-03-2019, 12:37 PM
Last Post: madalin
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 26,845 05-15-2019, 02:55 PM
Last Post: Thatoo
  The Debian Jessie User Accounts? jesse1234 6 12,784 01-20-2019, 06:07 PM
Last Post: zer0sig
  Creating bootable Debian backup image Drago 3 10,069 12-11-2018, 03:42 PM
Last Post: evilbunny
  Rock64 suitable for headless TVHeadend install? elsmandino 3 10,291 06-26-2018, 11:37 AM
Last Post: Luke
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,819 04-15-2018, 07:37 AM
Last Post: bunkerWHz
