Manjaro plasma-mobile Beta 13
in Beta 13 the desktop will always be configured with Halycon Layout after a restart and the wallpaper will always default to what beta 13 came with. You can change your settings but after restart they will be gone.
(11-16-2022, 12:36 AM)Uturn Wrote: in Beta 13 the desktop will always be configured with Halycon Layout after a restart and the wallpaper will always default to what beta 13 came with. You can change your settings but after restart they will be gone.
Yes, this is a known problem Smile
https://github.com/manjaro-pinephone/pla...tag/beta13
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
now tried unstable where the Layoiut cannot even be accessed. Shows a blank screen instead. Maybe that's better so we know it does not work. But then, I don't like Halycon. Sure that could also be changed in terminal.
yesterday installde dosme updates but Halycon still keeps coming back and desktop images still do not stay. I tried latest unstable and there it seems to work ok. But else, it is unstable probably.
now Beta 14 is out in Github, but Discover nor pacman -Syyu will update yet.
now I don't quite understand how we can find a beta14 factory image on Github but my pinephone does not update anything.
Wink
(12-21-2022, 03:31 AM)Uturn Wrote: now I don't quite understand how we can find a beta14 factory image on Github but my pinephone does not update anything.
Probably the image will be published after the updates have been made available for the previous image...
thank you - hopefully after additional testing! What gets published on GitHub makes not always a running system. I tried without luck Factory Image 202212201610.
there was a update yesterday, but desktop sitll will always boot with *halycon* and not save *folio* nor any desktop image. Also, it has a sleep problem, crashes instead of wake up ;(
new updates are in but still plasma crashes when switching the desktop to *folio*. The part setting of a lockscreen image works, but after unlock the phone goes back to Halycon and it's default desktop decoration.
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 14,914 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 2,620 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 7,442 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 2,412 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 12,336 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 5,159 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 2,730 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 12,764 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 2,651 02-22-2023, 03:37 AM
Last Post: acrux
  Can't install Manjaro thorensjubilee 1 2,622 02-09-2023, 08:17 AM
