Modem is always visible/connected but stops working after a while
Sad
my Mobian-PinePhone has a new and very serious issue since a few days Sad :
After a reboot the modem (sms, calling, mobile data) works for a while, but soon (after the phone goes to sleep I guess?) the modem completely stops working.
Very strange: It is still visible in the phosh top bar (with signal strength, settings and in modem manager! It's not 'gone', it's just not working/doing anything. Sad
Never read anything about this specific problem.
Do you think this is a hardware or a Mobian issue? Sad
Best Regards,
dante404
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Most of the time this is configuration problem.
What is not working? You don't receive calls or sms?
Network connection is not working?
What is your carrier (I don't need to know but some carriers are working better than others - as far as I know there are more problems in USA because you need to register your Phone/Modem before full 4G access or something)
Can you try in terminal:
sudo systemctl suspend
and wait a while and press power button - are you having the problem now?
If yes it is something related to suspend or more precise waking from suspend.
I don't get many calls anyway so I don't know for sure about calls (have to test), but (old) SMS suddenly are recieved after an reboot, and mobile data (surfing via Firefox, using Axolotl) only works temporary after a reboot. I guess calls will also only work just after a reboot then... but have to test.
Provider is called 'Congstar' (prepaid), which in fact is just a brand of T-Online/German Telekom (the biggest provider here in germany).
(10-27-2022, 02:27 PM)alaraajavamma Wrote: Can you try in terminal:
I will try this and check!
Thank you! Smile
Set power/control to "on" in /usr/lib/udev/rules.d/80-modem-eg25.rules. Mobian sets it to "auto" for the stock firmware instead.
ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/control}="on"
ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/autosuspend_delay_ms}="3000"
ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/wakeup}="enabled"
ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/persist}="0"
(10-28-2022, 06:04 AM)rx137 Wrote: Set power/control to "on" in /usr/lib/udev/rules.d/80-modem-eg25.rules. Mobian sets it to "auto" for the stock firmware instead.
Interesting! So I should set it definitively to "on"? Or only when using the open source modem firmware? (I'm still on stock modem firware at the moment.)
Will setting this to "on" instead "auto" reduce battery life?
Thank you for your reply! Smile
Set it to on whether you're using stock or otherwise. This fixed the issue you're describing for me. Presumably it reduces battery life to some degree or other, but that's moot if the modem doesn't work otherwise..
(10-28-2022, 06:33 AM)rx137 Wrote: Presumably it reduces battery life to some degree or other, but that's moot if the modem doesn't work otherwise..
...hm, kind of. If you have to make an emergency call (for example) and can restart the egm manager (or the whole phone) to get it to work, that's still better than having a useless phone with a complete discharged battery (and I don't want to take a second battery with me wherever I go)...
At the moment my PP battery barely makes it through a work day... with 10-15% remaining when plugging in at home. No room for wasting battery life time here.
It would also be just a ugly workaround for a new problem (modem sleep and wakeup did work before).
But thank you for the hint!
  Latest firmware for PinePhone modem! Subsentient 106 240,354 04-03-2026, 08:37 AM
Last Post: baptx
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 4,734 04-10-2023, 10:19 PM
Last Post: lupyuen
  Outbound sms not working Stubb 0 2,370 12-18-2022, 10:00 PM
Last Post: Stubb
  Downsides of the open-source modem firmware? alpineduck 4 6,617 10-25-2022, 05:28 PM
  Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! kop316 201 333,847 03-24-2022, 03:16 AM
Last Post: as365n4
  HowTo: Get a passcode from DUO Mobile working on the Pinephone kop316 2 7,150 01-16-2022, 03:46 PM
Last Post: michel_luc
  Problem Flashing the modem Firmware loreson 0 2,592 12-22-2021, 10:31 AM
Last Post: loreson
  Solutions to modem / connection problems Anna 3 6,733 12-10-2021, 01:42 AM
Last Post: AntonReiser
  Python3 Bridge SMS/MMS to Matrix using Modem Manager and MMSD FutureBucket 3 7,102 02-10-2021, 08:09 PM
Last Post: kop316
  Nav buttons and status drawer no longer visible (KDE Community Edition) heatsink 6 12,130 02-04-2021, 06:09 PM
Last Post: bshah
