Unofficial Pinephone Battery Case
(02-22-2022, 05:18 PM)TRS-80 Wrote: Do any of these work on regular (original) PinePhone?  I am not sure what the differences are between the body of that and the Pro (if any).
The case in my post fits the original Pinephone.
The cheapo case in my post fits the PPPro.  Other posts seem to indicate that the Pro and original have the same dimensions.
I've tried this case a handful of times with my PPPro and definitely don't think it is worth the money. For me it only really fir and worked without the back on which meant I couldn't change the volume of hit the power button. With the case on I had a really hard time even getting it to fit and would say it wasn't worth the hassle as the charging was inconsistent with the back case on as it kept cutting out. Might work better on the regular pinephone but for the pro it seemingly only works if the back case if off.
(02-16-2022, 12:39 PM)slvr Wrote: I made a 3d printable spacer to fill the gap. Haven't tried it in a galaxy s20 ultra case yet though.
https://www.thingiverse.com/thing:5247600
Works on the PinePhone Pro with the Amazon link! Weird thing about the case though-- it doesn't charge with a MacBook charger. It only takes the 5V USB-C output from my desktop. Any guesses as to what's going on there?
Is there any way to use wired headphones with this?
Hi all!
This thread inspired me to make a 3D-printable PinePhone back cover with all the necessary extensions, bevels and buttons to properly fit into a Galaxy S20 Ultra battery case. Credit to Remotheman for his PinePhone back cover (which my model is based on).
Model and more info on Thingiverse
  Can't detect the phone's battery shanewilliam 1 319 01-19-2026, 12:03 PM
Last Post: zetabeta
  what stopped pinephone pro? heocb 1 372 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 4,524 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 8,483 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 2,204 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 1,733 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 2,953 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 2,074 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 2,040 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 1,410 06-26-2025, 11:47 AM
Last Post: zetabeta
