Phone calls with no sound
Hello, I have contantly having phone call issues with no sound on both parts. When I make the call it usually does not work, but an icoming call i happens all the time. What could it be?
(10-08-2022, 11:01 PM)user641 Wrote: Hello, I have contantly having phone call issues with no sound on both parts. When I make the call it usually does not work, but an icoming call i happens all the time. What could it be?
Phosh?
After 0.20 (the one with swipe gestures) Phosh or Phoc crashes quite a lot. (I am not sure which - but the point is UI crashes and it is hard to notice because it will bounce back up quite fast)
It is all ready fixed in newer versions but if you are using Phosh 0.20 it was really difficult to use it as a phone Big Grin. For example the issue is gone with Manjaro which uses newer version by default.
With Arc, Mobian and PMOS stable UI crashes many times a day (I made tests earlier this month so things might be different today).
And when the Phosh/Phoch crashes there is odd loop where "old" Pulseaudio is still alive but Phosh/Phoc reboot from crash starts "new" Pulseaudio and it ends up to situation that you don't have working sound at all. I think this happens more often if call/sms/mms wakes phone up from suspend.
Phosh?
I see thanks for your detailed answers. I will wait patiently for the next updates then, I saw on github that phosh 0.21.1 is being released to arch.
I've been using phosh 0.21.0-3 and phoc 0.21.1-1 since danctnix released them on 15th September. Never had a crash (that I'm aware of). I never had a crash with v 0.20 either. 0.21 is much smoother for me in use. Since that time (and a megi kernel update) battery life if much better.
I do get occasional problems with audio calls though and that is because audio output gets set to "dummy". I have no explanation for this. We all signed up for these "quirks", right? Wink
I find a more or less daily reboot keeps things working more smoothly.
Arch Phosh (PP); firmware: 0.7.1; ADSP: 003
(10-10-2022, 03:22 AM)cone9 Wrote: I do get occasional problems with audio calls though and that is because audio output gets set to "dummy".
That's exactly the problem I am having.
Just noticed these updates in [danctnix-testing]...
modemmanager-1.18.12-1 phosh-0.21.1-1 telegram-desktop-4.2.4-1
I haven't used the testing repo before but telegram-desktop had started segfaulting the last few days, so I've updated using testing. All working great so far. A modemmanager update can't hurt either.
Quickest way to fix the "dummy" output problem is to just reboot.
(10-10-2022, 04:03 AM)cone99 Wrote: Just noticed these updates in [danctnix-testing]...
Also the kernel to 6.0: https://github.com/dreemurrs-embedded/Pi...e1b770f8e3
(10-10-2022, 04:26 AM)user641 Wrote: Also the kernel to 6.0: https://github.com/dreemurrs-embedded/Pi...e1b770f8e3
Yes, forgot to mention that. My phone has a newer kernel than my desktop now! I normally hang back on desktop kernel updates until .3
I saw that you have biktorgj modem's firmware, me too, but how to check the ADSP version?
Are you using the suggestions modifications on alsa as written here from 160 to 90%? https://github.com/the-modem-distro/pine...ETTINGS.md
(10-10-2022, 04:46 AM)user641 Wrote: I saw that you have biktorgj modem's firmware, me too, but how to check the ADSP version?
With biktorgj's firmware you can just text "version" to the modem. I love that. Send "help" for all commands. Seriously good! I've added the modem to my contacts and text that contact. Modem number is +223344556677.
I've applied all the "Recommended settings" for my PP.
  Still No Calls or SMS AndyM 3 5,576 03-10-2023, 05:27 AM
Last Post: AndyM
  No audio on calls after using wired headset Zebulon Walton 2 4,764 12-07-2022, 07:35 PM
  phone and plasma oihantto64 3 6,102 10-22-2022, 04:51 PM
Last Post: Chief
  Phone no longer works at all AndyM 2 4,216 10-19-2022, 12:08 AM
Last Post: AndyM
  no audio ring on non chatty calls nemsys 0 2,403 08-14-2022, 03:23 PM
Last Post: nemsys
  Incoming calls only vibrate, phone is not ringing lacriz 4 7,503 05-31-2022, 11:40 PM
Last Post: hannescam
  archplasma: phone et discover broken? oihantto64 3 5,769 05-14-2022, 03:38 PM
Last Post: oihantto64
  Last update bricked my pine phone :( lacriz 6 9,749 01-25-2022, 07:52 AM
Last Post: kqlnut
  2 weeks after installation during calls people hear me but i don`t hear anyone 7horns7eyes 10 16,473 01-22-2022, 08:16 AM
Last Post: kmsgli
  auto-brightness problem phone screen going to completely dim DonF22 6 16,348 05-11-2021, 07:00 PM
Last Post: Timothy_Ecc
