Unable to set default apps
I can't set the default apps in settings; they're all grayed out. Also, text files are not even recognized when I click on one in Portfolio.
Anyone know the secret to getting this stuff working as it should?
[edit] I should clarify that this is on Phosh.
Judging by the lack of response, I guess I should just use a different distribution.
(09-23-2022, 05:18 PM)Barugon Wrote: Judging by the lack of response, I guess I should just use a different distribution.
I had the same issue a week ago.
But somehow after a os update and reboot it's works and I was able to chose defauts app.
Ivaylo
(09-24-2022, 06:13 AM)olyavi Wrote: Hi,
Ivaylo
I'll give it another go.
Reinstalled pmOS and I still get the same problem.
This is still an issue. Sad
(12-02-2022, 06:57 PM)Barugon Wrote: This is still an issue. Sad
Same here. You're not alone.
Workaround is to install Nautilus and plug in mouse.
Open Nautilus and choose some file with file type for your needs (for example .pdf) and then press right button of the mouse.
It will open dialog where you can choose the default application to open pdf files Smile.
You can also edit mimeapps.list from your /home/user/.config folder but the upper one is easier solution.
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 3,924 11-22-2023, 10:16 AM
Last Post: zetabeta
  How to choose which Waydroid Apps can appear on PostmaketOS Home Screen? Avisando 6 10,589 05-28-2023, 10:54 PM
Last Post: Avisando
  Help with ssh and setting default apps jojuma 2 5,805 09-10-2022, 07:55 AM
Last Post: jojuma
  closing apps rather than leaving them running (phosh) lordearl 7 14,538 02-03-2022, 09:14 PM
Last Post: parry
  What is the default pin!? ThatWasLeftHanded 3 12,707 09-08-2021, 09:01 AM
Last Post: walter1950
  Disabe Bluetooth by default Alejandro.SU 1 4,687 11-09-2020, 10:59 AM
Last Post: Lousy Fisherman
  What is default password? quixote 6 27,778 11-03-2020, 08:55 AM
Last Post: wibble
  Resize apps for postmarket OS zeb11 8 18,518 09-26-2020, 04:21 PM
Last Post: ragreenburg
  Unable to mount root partition PostmarketOS lanawwas 0 5,138 09-06-2020, 07:42 AM
Last Post: lanawwas
  unable to boot the phone with PM OS after battery has completely discharged nieral 1 5,343 08-24-2020, 06:34 AM
Last Post: PureTryOut
