OMV - Updates and Plug-in install broken
Not sure if this is the right place but I just did a fresh install of stretch-openmediavault-rock64-0.9.14-1159-armhf.img on my Rock64. Now I can not update the system or install any plugins using the OMV Control Panel. I was able to update the system using Putty but i never had to do this with previous install (stretch-openmediavault-rock64-0.8.3-1141-armhf.img). Below is the log file from my most recent attempt to install shellinabox
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export DEBIAN_FRONTEND=noninteractive; apt-get --yes --allow-downgrades --allow-change-held-packages --fix-missing --allow-unauthenticated --reinstall install openmediavault-shellinabox 2>&1' with exit code '100': Reading package lists... Building dependency tree... Reading state information... The following NEW packages will be installed:   openmediavault-shellinabox 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 13.3 kB of archives. After this operation, 157 kB of additional disk space will be used. Err:1 https://dl.bintray.com/openmediavault-plugin-developers/arrakis stretch/main armhf openmediavault-shellinabox all 3.4   502  Bad Gateway Err:1 https://dl.bintray.com/openmediavault-plugin-developers/arrakis stretch/main arm64 openmediavault-shellinabox all 3.4   502  Bad Gateway E: Failed to fetch https://dl.bintray.com/openmediavault-plugin-developers/arrakis/pool/main/o/openmediavault-shellinabox/openmediavault-shellinabox_3.4_all.deb  502  Bad Gateway E: Internal Error, ordering was unable to handle the media swap <<< *************************************
Any suggestions are greatly appreciated.
Thanks for reading.
Tom
Tongue RockPro64 Ethernet NOP After Debian 11 Install... MattDralle 1 4,726 10-30-2021, 06:10 AM
Last Post: Rocklobster
  How can I install tvheadend server un rock64? gedas07 12 22,737 08-25-2018, 01:06 PM
Last Post: gedas07
  Install seems to always corrupt Lenny 2 5,504 06-02-2018, 10:05 AM
Last Post: Lenny
  OMV - broken networking Mentaluproar 4 8,774 03-28-2018, 08:34 PM
Last Post: Mentaluproar
  [Issue] Can't install the LibreElec Port from Raybuntu k0Lm_ 1 4,999 03-23-2018, 04:31 PM
Last Post: k0Lm_
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 4,041 03-16-2018, 05:40 PM
Last Post: pine3228
  How to install OpenGL pine3228 8 18,697 01-01-2018, 11:27 AM
  How to install and boot ROCK64 from eMMC? kershaw 32 91,251 08-15-2017, 07:41 AM
Last Post: MarkHaysHarris777
  paypal broken? dkryder 7 13,136 07-04-2017, 04:14 AM
Last Post: pfeerick
